MO2500's '97 TJ Build up - Page 45 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > MO2500's '97 TJ Build up
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!Memorial Day Sale at Under Cover Fabworks! 15% Discount o
Unread 02-12-2011, 10:41 AM   #661
bluestarguy
Great build!! I'm hooked. Subscribed so I can keep up.
bluestarguy is offline   Reply With Quote
Unread 02-13-2011, 11:27 AM   #662
MO2500
Fabramicator
MO2500's Avatar
Thanks man
My Jeep Build
Useful tech links:
Stu-Offroad - great technical write-ups!
What's a CV shaft and why do I need one?
Driveline 101
TJ Specs
-Mike-
MO2500 is offline   Reply With Quote
Unread 02-13-2011, 11:57 AM   #663
flatlander757
Hey Mike, what "level" of Bend Tech did you use? I'll need something for a cage/chassis soon if things go right
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Build thread here.
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline   Reply With Quote
Unread 02-13-2011, 03:23 PM   #664
MO2500
Fabramicator
MO2500's Avatar
I used Bend-Tech EZ3D. It's worked really well and has made everything come out to the exact dimensions I designed it to. The only down side to not having the Pro version is each piece has to be designed individually, there is no assembly view like there is in Pro. So you can't design the whole cage or chassis all in one shot and then go out and bend everything. I started with measuring, designing and bending the B-pillar. Once that was where I wanted it, I took measurements, designed the C-pillars, and bent them. Then I took measurements, designed the A-pillars, and then bent them, ect, ect...
I think it would be nice to have Bend-tech Pro for the sole reason that you can design the whole thing and see the final product before you get started. You could also change and modify things until you are happy with the design before you go out and bend any of that expensive DOM.
I only had an idea in my head and a few crappy sketches of my design and as it came together it changed quite a bit. With Pro you can see if pieces are all going to fit together before even starting.
My Jeep Build
Useful tech links:
Driveline 101
TJ Specs
-Mike-
Unread 02-13-2011, 03:40 PM   #665
flatlander757
Thanks! I think I'll definitely get "Pro" in that case then
Build thread here.
Currently Jeepless.
Unread 02-13-2011, 03:44 PM   #666
MO2500
Fabramicator
MO2500's Avatar
If your considering building a tube chassis I definitely would. I'll upgrade to Pro before the next cage or chassis gets built I just went with EZ-3D to save a little on my first project because I knew the cost to upgrade is only the difference in Pro and 3D
My Jeep Build
Useful tech links:
Driveline 101
TJ Specs
-Mike-
Unread 02-13-2011, 05:44 PM   #667
mferrari
DelmarvaOffroad.com
mferrari's Avatar
If you are going to do a chassis then get Pro. Even with cages I suggest getting Pro as well. I have turned out pre-bent cages for customers that are un assembled but completely bent by just building in Bend-Tech then cutting and bending as prescribed. When I did my chassis it was dead on from start to finish!
Michael Ferrari
Team 120 - DOR Racing - Racing for Operation Homefront
Operation Homefront (OHF) provides emergency financial and other assistance to the families of our service members and wounded warriors.
Thanks to our Sponsors:
Delmarva Offroad - F-O-A Shocks - BD Turnkey Engine - Under Cover Fab - Jer-C Transmissions - Quigley Driveshafts
Delmarva Offroad
You call it rolling, we call it R&D! 443-951-JEEP
mferrari is offline   Reply With Quote
Unread 02-13-2011, 07:46 PM   #668
MO2500
Fabramicator
MO2500's Avatar
Gerald added the lower valance cover to my package. Thanks for the heads up Fuzz
Can't wait for the new goodies but I need to finish my dang cage first lol
My Jeep Build
Useful tech links:
Driveline 101
TJ Specs
-Mike-
Unread 02-13-2011, 07:56 PM   #669
Sgt.Fuzz
Can't wait to see it installed. That's on my short list too.
[COLOR="Blue"]My build: [url]http://www.jeepforum.com/forum/f22/fuzzbucket-build-1126577/[/url][/COLOR]
Sgt.Fuzz is offline   Reply With Quote
Unread 02-14-2011, 10:38 AM   #670
MO2500
Fabramicator
MO2500's Avatar
My short list just keeps getting longer lol.
The list:
- Finish cage; X at the B-pillar, A to B bars, seat and harness mounts
- Make cage tie-ins
- Pull dash and center console
- Pull cage and finish weld the whole thing
- Raptor line the tub
- Prime and paint the cage and frame.
- Paint corners and tailgate skin while I'm painting other things
- Install everything back in the jeep; cage, dash, seats, harnesses
- Pull old gas tank
- Mount and plumb the fuel cell
- Relocate rear upper spring perches and install new coils
- Install front currie bumps and install new coils
- Install corner armor and tailgate skin
- Also want to make the windshield frame easily removable for wheeling trips so I can leave it at home.
- And finally, get a few good extinguishers and fab some quick release mounts for fire safety. I'v been reading too many stories about rig fires and my buddies truck caught fire going down the highway a few months ago and burned to the ground on the shoulder. His truck was an '03 and not a POS at all. They are not sure what caused the fire. But anyway, it made me think that it can happen to any vehicle at any time. Not just Jeeps that go offroad. I carried a small 2.5lb extinguisher before and a larger 5lb stowed in the back but I want some more quality stuff.
Hope to accomplish this by the end of March so that it's ready to wheel by April. Then I will begin collecting for the D44 (and most likely HP30) project.
My Jeep Build
Useful tech links:
Driveline 101
TJ Specs
-Mike-
Unread 02-14-2011, 10:46 AM   #671
Imped
Imped's Avatar
That's a pretty good list man. Luckily, April is still ~45 days away. My list has grown thanks to you....*** hole I've been putting a lot more time and research into cages.
OlllllllO
Float Test Build
IndyORV
If you see a dead picture link of mine and would like it fixed, please PM me the link to the post and I'll fix it. Thanks
Imped is offline   Reply With Quote
Unread 02-14-2011, 10:48 AM   #672
MO2500
Fabramicator
MO2500's Avatar
That's a pretty good list man. Luckily, April is still ~45 days away. My list has grown thanks to you....******* I've been putting a lot more time and research into cages.
Glad I could help
My Jeep Build
Useful tech links:
Driveline 101
TJ Specs
-Mike-
Unread 02-15-2011, 02:17 PM   #673
MO2500
Fabramicator
MO2500's Avatar
Maybe someday
My Jeep Build
Useful tech links:
Driveline 101
TJ Specs
-Mike-
Unread 02-18-2011, 08:48 PM   #674
MO2500
Fabramicator
MO2500's Avatar
Some goods
Ready to get to work tomorrow. I'm hoping to get the cage close to complete this weekend.
My Jeep Build
Useful tech links:
Driveline 101
TJ Specs
-Mike-
Unread 02-18-2011, 10:12 PM   #675
mferrari
DelmarvaOffroad.com
mferrari's Avatar
Man the cell looks fimilar. I may require you to keep the orange on it!
Michael Ferrari
Delmarva Offroad
4 link , air bags , coilovers , emc , jeep tj , koh , low rider , mid arm , pimp fabrimication , rock crawler , ultra4
