MO2500's '97 TJ Build up - Page 33 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > MO2500's '97 TJ Build up
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FS: Wranger BRIGHT License Plate LED! Just $3! Great valueTime To Save On Yukon Lockers!
Unread 01-13-2011, 01:10 PM   #481
Imped
Imped's Avatar
Originally Posted by TheMiser3 View Post
But for a factory warranty to be voided, they have to prove that the breakage was directly due to any modifications that you've done to the jeep. But I understand that if people are unknowledgeable and/or unwilling to argue a point with a dealership, than this could be a problem as well. IDK, I look at the cost of some of the **** that gets done to my jeep, like changing diff fluid, ****ers charged me ~300 dollars to change my front and rear diff fluid... I could have done that **** for less than $100. I guess my desire to fabricate my own **** as well as do all my own work is based both in a desire to learn about my jeep, and not pay someone else an assload of money to do simple tasks.
In the sense of JK vs. TJ DIY'ers, it's easy.....most JK owners are noobs, most of whom have more dollars than sense. Bolting on parts is hard enough, let alone thinking past that point. Let's be honest, most people are brought up thinking that anything to do with cars should be "left to the pros." In reality, that's a bunch of crap and 99% of the stuff can be done with hand tools and cost MUCH less than the "pros" would charge. Having a true understanding about how the systems in our vehicles works takes a little time and a desire to learn and save money. Unfortunately, that's not too common nowadays. That may be a bit harsh but it's true and evident. There are some solid JKers on here, though and you seem like one of them.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 01-13-2011, 03:10 PM   #482
MO2500
MO2500's Avatar
Today's progress...
Rolled the jeep outside. Looking pretty cool with the chop top and single hoop haha
Was able to duplicate the bends on both c-pillars almost perfectly. Loving this Pro-tools bender and Bend-tech software makes it easy.
New saw cutting tube like butter
Started working on fitting one side
Both sides fitted and just sitting in place. still want to work on the fit a little before I tack them in.
ODonnell Motorsports
Build Thread
Instagram: @omsmike
MO2500 is offline   Reply With Quote Quick reply to this message
Unread 01-13-2011, 04:15 PM   #483
65th
Looks good
2006 Jeep Wrangler- 65th Anniversary Edition- Jeep Green Metallic- 2 inch Budget Boost- 32" BFG All-Terrains - PIAA Fogs
65th is offline   Reply With Quote Quick reply to this message
Unread 01-13-2011, 04:51 PM   #484
MO2500
MO2500's Avatar
Originally Posted by 65th View Post
Looks good
Thanks
It's coming together. Although slower than I would like it to but I don't want to rush to get something like this finished. I'd rather it take months if the quality can be better. At my current rate, I measure and check about 20 times before I make a cut or bend, and then grind a little, check the fit, grind some more, etc. etc...
I think it will pay off though. Plus I only have about 4-5 inches of waste at the moment which is good since DOM isn't cheap.
Build Thread
Instagram: @omsmike
Unread 01-13-2011, 05:19 PM   #485
JJeeper09
Looking good man. I really like the C pillars. and btw 4-5 inches of waste isn't to bad at all. Keep up the good work!
[URL="http://www.jeepforum.com/forum/f22/project-do-right-1147962/"][B]Rubicon Build[/B][/URL]
JJeeper09 is offline   Reply With Quote Quick reply to this message
Unread 01-13-2011, 05:38 PM   #486
2006_Sport
That's gonna look sick when it's done. The slant cage look on TJs is boss.
2006_Sport is offline   Reply With Quote Quick reply to this message
Unread 01-13-2011, 05:57 PM   #487
Sgt.Fuzz
Had no idea you were going to do a fast-back cage. That's gonna look saweeet!
[COLOR="Blue"]My build: [url]http://www.jeepforum.com/forum/f22/fuzzbucket-build-1126577/[/url][/COLOR]
Sgt.Fuzz is offline   Reply With Quote Quick reply to this message
Unread 01-13-2011, 07:05 PM   #488
MO2500
MO2500's Avatar
Thanks fellas
Well...
I was planning to do something close to this. This is Gerald's (Savvy) 2003 and I like the line of the cage. That was the plan till today.
Now I'm considering doing something like this but slightly different with my own twist.
So, I guess it comes down to should I keep it fastback like it is now and just add the diagonals or bump it out like the first pic? Space is not an issue. I'm not planning to run a backseat or anything. I also believe both designs are strong structually. I'd like to hear your guys input
I kinda like the fastback look now over my original design...
Edit: I'm only talking about the C-pillar design/bracing, not the rest of those cage designs. I changed the pics to some better ones to show what I'm talking about.
Build Thread
Instagram: @omsmike
Unread 01-13-2011, 07:17 PM   #489
JJeeper09
I like the look of the first one because it is clean and balanced. But the second one is going to suit you a little better. Nothing will penetrate that one... Need more pictures man can't wait
Unread 01-13-2011, 07:44 PM   #490
Sgt.Fuzz
I definitely like the fast-back better. It has a nice retro look to it.
Unread 01-13-2011, 10:06 PM   #491
flatlander757
So after reading this build thread as well as flatlander's and jbennett and a few others, I notice a lot more custom work going on with TJs than with any of the JK builds that I've been able to find. Is there a reason for this that i'm missing? I just don't understand why almost everything you see done to a JK is bolt on and purchased... Are there any thoughts to this?
I think it's partially what Imped said, and also the fact that they're just too new at this time.
Just 3 years ago when I joined JF, there was nowhere near this much awesome fab work going on in TJs.
JKs are at the most 4 years old now... so they have just started getting out of their warranties. They still cost quite a bit, and will until the next Jeep revision comes out.
Also it really doesn't help that JKs have so many creature comforts and electronic gizmos(read: TPMS, ABS, traction control, etc) that it takes that much more work to make custom modifications -not- interfere with that crap.
And also, JKs come with a horrible motor(torque-wise... not dependability wise), so if you want a badass JK, you had BETTER plan on swapping out the engine... which is even more money. The 4.0 is plenty fine when geared right.
JKs don't come with a 4cyl because the V6 is slow enough.
I think those are primary contributing factors.
edit: If I got my hands on a JK I would void so much warrantay it would be silly.
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Build thread here.
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline   Reply With Quote Quick reply to this message
Unread 01-13-2011, 10:52 PM   #492
MO2500
MO2500's Avatar
Truth
Well that's one for keeping the lines of the fastback and kind of one vote for the other design (but maybe fastback because it might "suit [me] better" lol )
Any other opinions or suggestions from you guys? I appreciate input so far
Build Thread
Instagram: @omsmike
Unread 01-13-2011, 11:10 PM   #493
JJeeper09
Since you already started with the same b pillar as the second one.. stay on that route. The more you become familar with the tube bending you might start adding even more supports much like the second one..
Seeing this is tempting me to get a bender myself
Unread 01-13-2011, 11:20 PM   #494
MO2500
MO2500's Avatar
Basically I'm just looking at the C pillar designs on those two cages. I am definitely adding a bunch more structural supports throughout the entire cage (I'm a little less than 20ft into the 100ft of DOM I bought ) But I also see what your saying since it might look different being that the one is built A/C-pillar vs. the traditional B-pillar. I personally think the bent B-pillar is stronger which is why I went that direction. Many will argue that either design is strong. I guess it's personal preference really.
Build Thread
Instagram: @omsmike
Unread 01-13-2011, 11:23 PM   #495
JJeeper09
Do you ever plan on having rear passengers again... If you had CAD you could make different designs. Only access i have to it is at would, and I'm not allowed to do jeep stuff anymore
4 link , air bags , bypass shocks , coilovers , emc , koh , low rider , mid arm , pimp fabrimication , race jeep , ultra4
