MO2500's '97 TJ Build up - Page 305 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > MO2500's '97 TJ Build up
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line50" LED CREE Light Bar Pair With Wiring KitTeraflex JK LCG PRE-RUNNER KIT! ULTIMATE OFF ROAD PERFORMA
Unread 12-04-2013, 11:06 PM   #4561
duc202
duc202 is offline   Reply With Quote Quick reply to this message
Unread 12-04-2013, 11:09 PM   #4562
duc202
Unread 12-05-2013, 10:34 AM   #4563
Shobes
Man I love the way that Jeep looks, making a new bumper?
My "hard way" build - [URL="http://www.jeepforum.com/forum/f22/tj-rubi-9s-learning-hard-way-1483373/"]http://www.jeepforum.com/forum/f22/tj-rubi-9s-learning-hard-way-1483373/[/URL]
Shobes is offline   Reply With Quote Quick reply to this message
Unread 12-05-2013, 01:19 PM   #4564
Kodiak17
Looks clean! Sending you mine
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline   Reply With Quote Quick reply to this message
Unread 12-05-2013, 01:28 PM   #4565
AngryTJ
AngryTJ's Avatar
Originally Posted by duc202 View Post
sick Bike
Tarantula_TJ Build
2015 Colorado Trip
AngryTJ is offline   Reply With Quote Quick reply to this message
Unread 12-05-2013, 02:01 PM   #4566
84jeepcj7rock
Jeep is looking great! I'm curious, do you have any bump steer? Your drag link looks steep from that angle. Does the ram assist help keep that to a minimum?
84jeepcj7rock is offline   Reply With Quote Quick reply to this message
Unread 12-05-2013, 02:31 PM   #4567
MO2500
MO2500's Avatar
You can say that I actually never even got around to finishing the bumper last winter. I went ahead and chopped the front tube off because I want to move it forward about 2" and rotate the steering box a bit to fix some issues with my intermediate shaft clearing the frame. Once all that's taken care of I'll get the winch mounted and finish out the front tube work.
sick Bike
Thanks
The steepness of the drag link has nothing to do with bump steer. As long as the drag link and track bar are identical lengths and perfectly parallel to one another there won't be any bump steer.
However, pay zero attention to my steering setup in the above pictures. I cut the steering box mount and rotated the steering box which misaligned my drag link and track bar. The Jeep is also sitting roughly 2" higher all around at the moment because I pulled everything from the interior, transmission, transfer case, fuel cell, seats, ect and the extra height is making the angles look much worse than they were.
Moving the steering box around means I will most likely be re-doing the entire draglink and track bar setup but here are some pictures of how it was setup. There was never bump steer because of identical length track bar and drag link and mounted at exactly the same angle.
Instagram @omsmike
MO2500 is offline   Reply With Quote Quick reply to this message
Unread 12-05-2013, 02:40 PM   #4568
84jeepcj7rock
I agree that having equal length and angle trac bar and drag links helps minimize issues but it will still push the entire axle to the passenger side during compression. Now that I think about it more, I guess it doesn't matter. If it were perfectly flat, the axle would move to the driver side during compression or droop.
Unread 12-05-2013, 03:25 PM   #4569
MO2500
MO2500's Avatar
As long as the track bar pushes the entire axle the same as the drag link would push the knuckle throughout the suspension travel (same length and parallel), bump steer is non existent. If the angles are really steep and the axle shifts side to side a lot it can cause handling issues but it wouldn't be bump steer technically. I haven't really noticed any strange handling with my setup like it is but while I'm moving things anyway I may try to get mine a little bit flatter at ride height if I can. With 7.5-8" of up travel it's tough to get things flat at ride height and still clear each other at full bump. At full bump right now my drag link and track bar angle very slightly the other direction believe it or not.
Instagram @omsmike
Unread 12-05-2013, 03:31 PM   #4570
duc202
love that last picture
Unread 12-05-2013, 05:01 PM   #4571
1 ton yj
What did you put on the bottom edge of the hood? I just cut mine at that line last week and I've already cut myself twice on it.
1 ton yj is offline   Reply With Quote Quick reply to this message
Unread 12-05-2013, 05:35 PM   #4572
MO2500
MO2500's Avatar
Automotive door edge trim. You should be able to find it at most auto parts store chains. I picked mine up at a pep boys or advance auto out in Colorado last year.
Instagram @omsmike
Unread 12-05-2013, 06:29 PM   #4573
Imped
Imped's Avatar
"Bump steer" is a result of differing arcs between the track bar and drag link. As long as the links travel in the same arcs, there will be no perceived bump steer, regardless of the operating angles of said links.
OlllllllO
Float Test Build
IndyORV
Imped is online now   Reply With Quote Quick reply to this message
Unread 12-05-2013, 07:46 PM   #4574
aw12345
aw12345's Avatar
Originally Posted by MO2500 View Post
Hmm, that sounds interesting. I don't know if I can swing a huge western journey again next year but I will say that I've been eyeing the Dirt Riot race at Crandon, WI August 2-3, 2014. Looks like it might be a pretty cool event and my girlfriend has family about an hour from the race in Wisconsin. Not sure if that works out with the late August trip you are talking about but maybe we could figure something out where I do a little racing and then some wheeling in the nearby states before heading back East.
From Wisconsin to South Dakota isn't that bad a stretch. I am not set on dates yet, since I haven't bid my vacation weeks yet. We can do some research on trails in the black hills. Can always try to hook up with some Colorado Jeepers on the way home to hit Carnage canyon and the trail near it. It's been quite some time since a big road trip. Have to research a bit, but looks like under 1300 miles and on the way back Colorado isn't to hard to hit up
aw12345 is offline   Reply With Quote Quick reply to this message
Unread 12-05-2013, 08:26 PM   #4575
REDLYNER
Mall Crawling Racer
REDLYNER's Avatar
we figure something out where I do a little racing and then some wheeling in the nearby states before heading back East.
I'm quoting this for future reference .
REDLYNER Racing #4550
HANKOOK TIRES * Rugged Radios * Savvy Offroad * Raceline Wheels
Clayton Off Road * Olympus Off Road * High Performance Graphics
Instagram: redlyner4550
REDLYNER is offline   Reply With Quote Quick reply to this message
4 link , air bags , coilovers , emc , jeep tj , koh , low rider , mid arm , pimp fabrimication , rock crawler , ultra4
