MO2500's '97 TJ Build up - Page 280 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > MO2500's '97 TJ Build up
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 07-15-2013, 05:35 PM   #4186
JJeeper09
How did you try and clean it out? Brake cleaner?
Try the Saginaw box one more try. I think maybe it had some debris in it.
[URL="http://www.jeepforum.com/forum/f22/project-do-right-1147962/"][B]Rubicon Build[/B][/URL]
JJeeper09 is offline   Reply With Quote Quick reply to this message
Unread 07-15-2013, 05:39 PM   #4187
MO2500
MO2500's Avatar
Brake clean, compressed air, and a magnet. It was 2-3am though, odds are pretty high that I could have missed a shaving or two
ODonnell Motorsports
Build Thread
Instagram: @omsmike
MO2500 is online now   Reply With Quote Quick reply to this message
Unread 07-19-2013, 02:35 PM   #4188
MO2500
MO2500's Avatar
With the heat wave this past week and the 110* heat index today, doing anything outside has been pretty miserable. I did however pick up a couple of things.
First was a sweet score. Bought a U.S. made ATL 22 gallon fuel cell that will fit perfectly in the back of my Jeep. It's a SP122a, retails for $845 + shipping from Summit, got it for $175 shipped Dual pickups, ATL premium foam, angled fill, and 1" vent. Just needs a little TLC (cleaning and paint). I'll need to build a mount for it but I'm pretty happy with the find, much cheaper than I originally planned so I had to pick it up.
I also received some exhaust parts so I can redo my disaster of a straight pipe I threw together before Moab. Still might have some noise when I'm standing on it but hopefully fixing all the holes/gaps and adding some type of muffler will make it a heck of a lot more tolerable while crawling.
Build Thread
Instagram: @omsmike
Unread 07-19-2013, 02:43 PM   #4189
IEcrawlerTJ01
Good deal on the cell
Would def swap out the foam for waynes baffles ASAP. I know of too many people that have run foam and had it end there race prematurely because the foam just took a ****
Check out waynes plastic baffles if you have not seen them yet
[CENTER]SAVVY,CURRIE,GOODYEAR
Nuff said...[/CENTER]
IEcrawlerTJ01 is offline   Reply With Quote Quick reply to this message
Unread 07-19-2013, 02:44 PM   #4190
Imped
Imped's Avatar
Nice cell dude....and I agree with Wayne's baffles. I wish I could run them in my cell.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 07-19-2013, 02:47 PM   #4191
MO2500
MO2500's Avatar
I followed the development of them, they are definitely in my plans
Build Thread
Instagram: @omsmike
Unread 07-19-2013, 03:09 PM   #4192
MO2500
MO2500's Avatar
Well, you could, it wouldn't hurt lol
Edit: well, except the fuel level float on the stock TJ pump lol
Build Thread
Instagram: @omsmike
Unread 07-19-2013, 03:12 PM   #4193
Imped
Imped's Avatar
There ya go.
OlllllllO
Float Test Build
IndyORV
Unread 07-19-2013, 03:14 PM   #4194
AngryTJ
awesome find on the tank mike
[SIZE="5"][COLOR="Blue"]Follow me on Instagram @ Tarantula_TJ[/COLOR][/SIZE]
[URL="http://www.jeepforum.com/forum/f22/angrytjs-97tj-05-rubicon-build-1271051//"][SIZE="4"][B]
Tarantula_TJ Build[/B][/SIZE][/URL]
AngryTJ is offline   Reply With Quote Quick reply to this message
Unread 07-19-2013, 03:30 PM   #4195
IEcrawlerTJ01
Good deal man
I was gonna run them in my rci but really want to keep the fuel guage as well
Unread 07-19-2013, 03:43 PM   #4196
JJeeper09
Good deal man
As much as I have the amount of miles I get in my cell down to around 10 or so, I like my gauge too.. Haha
Unread 07-26-2013, 08:34 PM   #4197
MO2500
MO2500's Avatar
Going wheeling in the morning
Round 2 on the steering box mod. Picked up a used steering box from the junkyard for $25. This one is from a mid 90s Grand cherokee I think, it has a little quicker ratio which I think I will like, 3 turns lock to lock vs the 3.5 turns of a TJ box.
Marking the holes to be drilled for the assist. Hit the ports perfectly on the first one I did so tried to match them up as best I could.
Drilling holes. Hit the ports dead center again!
Tapping 1/4" NPT
Cleaned EXTREMELY well this time, definitely think I left shavings in the last one because I got a lot of stuff out of this one until it was spotless. Then I installed the #6 JIC fittings
Painted and reassembled with all new o-rings, teflons, and seals. Hoping this one works for a long time!
For the trip to Moab, I tried making a overflow for the radiator with an aluminum water bottle, some fittings and a filter on tip. I sealed it with JB weld. It held up for half the week until the JB weld cracked, then it started slowly leaking coolant. I took care of that problem by installing a overflow I got from Jegs, much better!
The angry tractor needed something done about the hacked together straight pipe I had horribly constructed at 2am the night before leaving. Re-did the exhaust, welded up all the leaks and added this little mini muffler I got from Jegs. It helped make it not so loud at lower RPMs but the tractor still comes out when I get on it
With the steering box re-installed, I started checking things over and quickly figured out that my steering system was terribly out of adjustment. First, I was toed out about 1" Then I discovered what might be why my last steering box broke, I never fine tuned the ram and steering box to work together properly after final assembly, I thought I did, but I guess that's what I get for putting the steering together around 4am after nearly 72 hrs of no sleep It was right during mock up but got messed up during final assembly. The ram was extending about a 1/2" past the boxes limit when steering to the right (remember, my steering box broke when steering hard right!). I think what happen was, when turning hard right, the power piston in the box moves towards the back, between the piston and the rear wall were some shavings from not cleaning the box out well enough. The ram over steered the box, forcing the piston back farther which crushed the shavings and ended up breaking the lip off the piston at the bottom (where the shaving would have settled in the box). Anyway, I should have it fixed now.
The Toe got adjusted from 1" of toe-out to 1/8" of toe-in and the ram and draglink adjusted to get the ram to limit just before the box. After a quick test drive we are looking good and ready to do some wheeling!
Build Thread
Instagram: @omsmike
Unread 07-26-2013, 09:20 PM   #4198
TJRHD
That is way cool.
NOT A HATER
TJRHD is offline   Reply With Quote Quick reply to this message
Unread 07-26-2013, 10:22 PM   #4199
ScottD16
Can't wait to see it wheeling tomorrow it's been way to long
[B][U][SIZE="4"][COLOR="Yellow"]JEEP BUILD[/COLOR][/SIZE][/U][/B] better late than never [URL="http://www.jeepforum.com/forum/f22/yellow-submarine-build-1359779/"]http://www.jeepforum.com/forum/f22/yellow-submarine-build-1359779/[/URL]
I like to do the photography [B][U][SIZE="4"]Flickr[/SIZE][/U][/B]- [URL="http://www.flickr.com/photos/dunklewunkle/"]http://www.flickr.com/photos/dunklewunkle/[/URL]
wheeling pictures and other random stuff [SIZE="4"][B][U]Photobucket[/U][/B][/SIZE] [URL="http://s884.photobucket.com/albums/ac44/scottad16/"]http://s884.photobucket.com/albums/ac44/scottad16/[/URL]
ScottD16 is offline   Reply With Quote Quick reply to this message
Unread 07-27-2013, 05:56 AM   #4200
G Beasley
Looks good , now go have some fun .
G Beasley is offline   Reply With Quote Quick reply to this message
4 link , air bags , bypass shocks , coilovers , emc , koh , low rider , mid arm , pimp fabrimication , race jeep , ultra4
