MO2500's '97 TJ Build up - Page 279 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > MO2500's '97 TJ Build up
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 07-08-2013, 02:16 PM   #4171
MO2500
MO2500's Avatar
Originally Posted by dayriesw View Post
That is why you have to check all the clearances. Full bump or full droop?
Probably both in a matter of half a second. We hit a pretty big hole at speed. Lu's legs are just too long for my Jeep lol. I'm going to pad the dash bar but my knees never got close all week.
ODonnell Motorsports
Build Thread
Instagram: @omsmike
MO2500 is online now   Reply With Quote Quick reply to this message
Unread 07-08-2013, 03:59 PM   #4172
MO2500
MO2500's Avatar
I finally pulled the jeep out of the garage to clean it up and check it over. With exception to the steering which I still need to fix, everything looks like it held up really well during the trip.
I have some real measurements finally too. As it sits in the pictures, I have 20 1/4" to the belly (21" to the bottom of the frame rail) with the tires @20psi. 7.5" of uptravel in the rear and 7.25" of uptravel up front.
Spring weights are 125/200 in the front w/ 1" of pre-load, and 100/185 in the rear with 2" of pre-load. That should be just about right once I add the winch to the front and the spare mount in the rear to get me 2" of pre-load in the front and 3" in the rear which is spot on with what Wayne recommends.
Spare tire is just thrown up there about where I want to mount it.
Build Thread
Instagram: @omsmike
Unread 07-08-2013, 05:48 PM   #4173
duc202
That rear mounting spot looks good. It looks as though it'll put enough weight back there to keep the *** planted (as if that monstrous rear axle isn't enough) but not to high up to mess w your center of gravity.
Can you post up a mockup of what the mount will look like to support the spare or are you doing it like how Redlyner has his mounted?
White Jeep Club member #253
duc202 is offline   Reply With Quote Quick reply to this message
Unread 07-08-2013, 06:02 PM   #4174
yellow_snocone
The Angry tractor is looking shiny
Military Jeepers
S.W. New Mexico region
[URL="http://www.jeepforum.com/forum/f22/chesters-tj-build-1420405/"][COLOR="Green"]Chester TJ build[/COLOR][/URL]
[URL="http://www.jeepforum.com/forum/f330/rubicon-trail-august-9th-11th-2014-a-1550022/"][COLOR="Blue"]2014 JF RUBICON TRIP[/COLOR][/URL]
yellow_snocone is offline   Reply With Quote Quick reply to this message
Unread 07-08-2013, 06:12 PM   #4175
rusty762
rusty762's Avatar
Looks killer man, just ordered similar springs for mine in back.
Rusty
If I had eight hours to chop down a tree, Id spend six sharpening my axe.- Abraham Lincoln
My Build
My Videos
My Work
Have you hugged a Firefighter today?
rusty762 is offline   Reply With Quote Quick reply to this message
Unread 07-08-2013, 06:31 PM   #4176
143DAD
143DAD's Avatar
Looks awful clean and shinny, don't hate the man who like a clean Jeep, hate him because he dosen't get it dirty. And you definitely get your dirty.
Any color will do as long as its black.
143DAD is offline   Reply With Quote Quick reply to this message
Unread 07-08-2013, 06:45 PM   #4177
MO2500
MO2500's Avatar
Honestly, I'm just going to start building it and it will turn out how ever it turns out just like everything else
But seriously, in my head it will end up a cross between this and Redlyner's.
Just wait until I polish and wax it
I almost sprayed tire shine on it, almost...
I don't mind getting it dirty, but I hate working on a dirty/muddy Jeep. I've got to pull the steering apart and I want to do a little more fab work now that I've had a little break from it all.
Build Thread
Instagram: @omsmike
Unread 07-13-2013, 04:11 PM   #4178
LifeProof
SEMPER FIDELIS
LifeProof's Avatar
This might have been addressed already but I noticed you don't have a cluster set up on the dash. Do you plan on adding any instruments like speedo, temp, tach, etc?
LifeProof is offline   Reply With Quote Quick reply to this message
Unread 07-13-2013, 07:10 PM   #4179
aw12345
Mikey, didn't have time to install that before his trip
aw12345 is offline   Reply With Quote Quick reply to this message
Unread 07-14-2013, 09:05 PM   #4180
MO2500
MO2500's Avatar
Yes, I most definitely need those items and a bunch of other things I still haven't had a chance to finish (kill switch, intercom, radio, ect..). I did the Moab trip without any guages and pretty much figured it would either be running fine or not running at all, that's all I needed to know
Build Thread
Instagram: @omsmike
Unread 07-15-2013, 04:52 PM   #4181
AngryTJ
[SIZE="5"][COLOR="Blue"]Follow me on Instagram @ Tarantula_TJ[/COLOR][/SIZE]
[URL="http://www.jeepforum.com/forum/f22/angrytjs-97tj-05-rubicon-build-1271051//"][SIZE="4"][B]
Tarantula_TJ Build[/B][/SIZE][/URL]
AngryTJ is offline   Reply With Quote Quick reply to this message
Unread 07-15-2013, 04:57 PM   #4182
duc202
watched that video this morning before i headed into work
Unread 07-15-2013, 05:04 PM   #4183
MO2500
MO2500's Avatar
I finally took my steering box apart to see what happened on Helldorado. Things don't look good Not sure if I will just buy another stock box and try again or just hand my next pay check to PSC for one of their boxes.
A piece of the piston broke off. Anyone have any idea why that would happen? I was expecting a broken sector shaft tooth or something but this one seems odd to me.
Housing looks pretty much toast from all the chips and pieces being crushed and ground against the cylinder wall when I tried to turn to the right.
Build Thread
Instagram: @omsmike
Unread 07-15-2013, 05:14 PM   #4184
aw12345
Does the steering gear sit flat against it mount at all 3 bolt locations and the mount doesn't flex allowing the housing to distort?
Only other way for that to happen is that there was a piece of metal in there where it jammed against.
I would check the mount, seems like it happened in the only spot you really needed to crank the steering.
I would use a used box, till you figure out the cause, would be hurtfull to the wallet to destroy a PSC box
Unread 07-15-2013, 05:26 PM   #4185
MO2500
MO2500's Avatar
I'm thinking it's possible that I didn't get all of the shavings out of the box from drilling and tapping. It may be that a shaving jammed the piston and caused it to crack.
The box does sit flat against the mounting bolt sleeves. However, your right, it would suck to have this happen to a brand new PSC box. Just not sure I want to keep wasting money on stock boxes or put it towards the PSC box that is already drilled and tapped. If I can find one at the junkyard I might try one more time.
Are the boxes in Cherokees the same? Wranglers are pretty hard to come by but the local JY is filled with XJs.
Build Thread
Instagram: @omsmike
4 link , air bags , bypass shocks , coilovers , emc , koh , low rider , mid arm , pimp fabrimication , race jeep , ultra4
