mild mj - JeepForum.com
post #1 of 60 Old 10-31-2011, 10:32 PM Thread Starter
cody4359
1987 MJ Comanche
mild mj
well this is my new baby. got tired of trying to finish my other one, and found its alot cheaper to buy things somewhat built. it came with RE 5.5" long arm with ACOS, rear soa with an 8.8 with disks. front has a powertrax no slip and teraflex high steer. gears are 4.10s and it has the 97+ swap. worn 35" toyos and 2.5" exhaust with flomaster 40 series.
cody4359 is offline
post #2 of 60 Old 10-31-2011, 10:35 PM
teamgreen666
very nice find. keep them both 1 for trails and 1 for the street
teamgreen666 is offline
post #3 of 60 Old 10-31-2011, 10:36 PM Thread Starter
cody4359
1987 MJ Comanche
since then i have swapped out the base model dash for one with full guages, replaced the front pinion bearings, made a inner steering box reinforcement plate and added a kevins offroad steering box brace. while i was doing the pinion bearing i put on a G2 diff cover and outter axle tube seals. got rid of the 35"s for some meteric 33"s (cooper STT), threw on some hood vents and a banks torque tube.
cody4359 is offline
post #4 of 60 Old 10-31-2011, 10:39 PM Thread Starter
cody4359
1987 MJ Comanche
temporary wheels/tires
1st outting
also had to add some spidertrax wheel spacer in the rear
cody4359 is offline
post #5 of 60 Old 10-31-2011, 10:48 PM Thread Starter
cody4359
1987 MJ Comanche
other than that i have swapped the 5.5" coils for 4.5" and raised the ACOS, added "fatmat" to the roof and rear of the cab. tranny temp guage and cooler and JKS adjustable bumpstops. looking at swapping in a dakota tank to get rid of the xj tank behind the axle and in the garage in now have a HP dana 30 with a detroit truetrack, and a rear xj dana 44 with an eaton e-locker both having 4.56 yukon gears. currently awaiting a quote on chromo axles and a sye.
my favorite pic
cody4359 is offline
post #6 of 60 Old 10-31-2011, 10:50 PM
ajf1994
Sexy MJ! Wish I had one.
-SupportOurTroops-
High School Jeepers #361
Parrothead Jeep Club #46
37,xxx Miles
Originally Posted by XJ-Tim View Post
my welds look like popcorn with sprinkles.
Originally Posted by Benjamin Franklin
Beer is proof that God loves us and wants us to be happy.
ajf1994 is offline
post #7 of 60 Old 11-01-2011, 06:03 AM
jeepin ruby
Sweet! I like it all! Would really look killer with a nice front bumper. Keep up the good work!
2012 JKU Altitude Edition... under construction!
2005 WK limited... The wifes.
jeepin ruby is offline
post #8 of 60 Old 11-01-2011, 12:21 PM Thread Starter
cody4359
1987 MJ Comanche
i have a warn hs9500i thats waiting to go on once i make a bumper. need a little more motovation and a few more fab tools. plan on doing front/rear bumpers and a set of rock rails.
cody4359 is offline
post #9 of 60 Old 11-01-2011, 09:38 PM Thread Starter
cody4359
1987 MJ Comanche
started on the rails today. nothing fancy, maybe the next set will get some tubing added on.
cody4359 is offline
post #10 of 60 Old 11-05-2011, 05:51 PM Thread Starter
cody4359
1987 MJ Comanche
got them finished up
cody4359 is offline
post #11 of 60 Old 11-18-2011, 07:21 PM Thread Starter
cody4359
1987 MJ Comanche
got a few more goods. terra 2 low, AA sye and a case spreader.
last person to work on it put way to much rtv on the case halves, also a bit of metal shavings.
also tried out the rails and was satasfied. didnt move much at all and i had the passanger side off the ground.
cody4359 is offline
post #12 of 60 Old 11-21-2011, 09:14 PM Thread Starter
cody4359
1987 MJ Comanche
had a new cv driveline made, intalled Brown dog Offroad motor brackets and drove it.
cody4359 is offline
post #13 of 60 Old 12-12-2011, 06:37 PM Thread Starter
cody4359
1987 MJ Comanche
got my new bumper/winch on along with a tool box and CB installed. soon ill get my other axle sleeved and gusseted then do 4.56 with an ARB and i have a rear dana 44 with 4.56 and E-locker that needs the perches welded on
cody4359 is offline
post #14 of 60 Old 12-12-2011, 07:33 PM
stretchj
You have good taste sir, looks great!
1994 YJ 2.5L AX5 231 - SOA AAL HP30 F8.8 4.88's 35's - SOLD
2000 XJ 4.0L AW4 242 - 4.5 RC Flipped Leafs for Stretch Comp Cut 35's - SOLD
1988 MJ 4.0HO AW4 231 - HP30 C8.25 - BDS 6.5 LA 35 KM2 - 99 XJ clip and interior - SOLD
1997 TJ 4.0L AX15 231 HP30 F8.8 - NEW PROJECT
stretchj is offline
post #15 of 60 Old 12-13-2011, 01:12 AM
PitchblakToxic7
Where are you in Washington?
PitchblakToxic7 is offline
tj on 37s with mild lift miguelitojeep97 Jeep Picture Requests 62 08-14-2016 02:31 PM
Mild Red '08 JK LBrook Jeep Builds 44 05-15-2013 09:00 AM
A very mild JK kurtfriedrich Jeep Builds 3 09-16-2010 03:09 PM
well, another 97 SE mild build up cmorganf64 Jeep Builds 14 12-08-2007 06:21 PM
