Mikes 05 Unlimbited Rubicon Build - Page 9 - JeepForum.com
post #121 of 154 Old 03-12-2014, 03:26 PM
bobthetj03
Make your next purchase a good set of adjustable lower control arms, ie...Currie, Metal Cloak to name two. If you got the caps, get front uppers too. Your caster shouldn't effect the shimmy/DW issue.
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #122 of 154 Old 03-12-2014, 04:56 PM
dongalonga
Check the Toe as well. Basically bring it to a shop and have the entire alignment checked then post your alignment sheet. I would be surprised if it wasn't something to do with that or wheel balance. You very well could have lost a wheel weight or two.
The only other thing I can think of is if your track bar bolt is slightly wallowed. Did you replace the factory bolt with a Class 12.9? Here are the exact spec for the bolt: M10x1.50x75mm Class 12.9
dongalonga is offline
post #123 of 154 Old 03-12-2014, 04:58 PM Thread Starter
mgclark6
Definitely next on the list! With new tires and new lift it will be at least six months before my account recovers.
mgclark6 is offline
post #124 of 154 Old 03-14-2014, 07:22 PM Thread Starter
mgclark6
Finally had my first chance to flex out on my buddies Jeep!
mgclark6 is offline
post #125 of 154 Old 03-14-2014, 09:16 PM
dongalonga
The poor YJ wants to flex like that
post #126 of 154 Old 03-14-2014, 09:20 PM Thread Starter
mgclark6
Yea, i think the YJ frowned a little when i climbed on top of her.
My buddy was like..wtf are you doing? WHY? WHY? How will this be cool?
mgclark6 is offline
post #127 of 154 Old 03-16-2014, 10:26 AM
G Beasley
Nice flex out of the OME stuff ...
G Beasley is offline
post #128 of 154 Old 03-16-2014, 10:42 AM Thread Starter
mgclark6
Beasley, if i do control arms next and on a budget. Which two should i replace first, or do all four front first or all four lowers first? Thinking about giving metal cloaks new arms a try. 1000.00 is a bit much but if i can break it down into 2-4 purchases i might be able to get started.
mgclark6 is offline
post #129 of 154 Old 03-16-2014, 12:30 PM
dongalonga
Rear uppers and front lowers first. Allows you to adjust pinion angle and caster. Personally, I would save up and do them all at once. This allows you to do the install in one shot as well as one alignment.
post #130 of 154 Old 03-16-2014, 05:13 PM Thread Starter
mgclark6
I might go ahead and get front lowers. The alignment shop i used has a 6 month garauntee, so as long as i get em all done before then it wont cost me any more for alignments. I know my loving wife wouldn't go for 1000.00 mod again.
mgclark6 is offline
post #131 of 154 Old 03-16-2014, 05:38 PM
dongalonga
What she doesn't know won't hurt you...until she finds out
post #132 of 154 Old 03-16-2014, 07:48 PM
G Beasley
Keep an eye out for a good set of used arms , they come up now and then . And I would do the lowers first on the front and the uppers on the rear like DL suggested.
post #133 of 154 Old 03-17-2014, 12:15 AM Thread Starter
mgclark6
Oh, but she will find out! And it WILL hurt! I gotta plan it slow. 250.00 at a time is better than 1000.00 all at once, LOL
mgclark6 is offline
post #134 of 154 Old 03-17-2014, 12:17 AM Thread Starter
mgclark6
Cool, thats a starting point! I cant afford another big mod unless i buy her some useless bling.
mgclark6 is offline
post #135 of 154 Old 03-18-2014, 11:13 PM Thread Starter
mgclark6
My death wobble is gone....two days of driving on same roads that caused it. I replaced both front axle u joints and driver side front wheel bearing.
The slight "angry sparrow" noise i heard before is a bit louder now. A chirping noise between 5-15 mph. I know ive read about this noise before. Is it front driveshaft u joints? Or could i have pinched a needle bearing in the axle u joint? I heard it before replace ing them but it seems louder now.
At least the wobble is gone.
Always something to replace/fix/diagnose. Jeep Jam isn't until August, but dd til then.
mgclark6 is offline
