Mikes 05 Unlimbited Rubicon Build - Page 8 - JeepForum.com
post #106 of 154 Old 03-01-2014, 09:10 PM
G Beasley
Hopefully you used some anti seize as you were putting everything back together . How far along are you with the lift install ? And where are the pictures ?
G Beasley is offline
post #107 of 154 Old 03-02-2014, 09:16 PM Thread Starter
mgclark6
It's done and got it aligned today! Covered with road salt right now, supposed to get warm enough to wash later this week. Pictures soon!
mgclark6 is offline
post #108 of 154 Old 03-02-2014, 09:36 PM
samuraisavr
I'm just down 75 from you in Monroe. I see a lot more salt coming our way before the weather lets up. I've been following the build for a while and the LJ is sick. Post up them pics when you have time, we don't mind a little dirty jeep porn.
Just
Empty
Every
Pocket
samuraisavr is offline
post #109 of 154 Old 03-03-2014, 11:59 PM Thread Starter
mgclark6
I'll take some tomorrow. Is that a 2dr in your avatar? Looks a lot like the one i helped my daughter build. Shoulda kept that one for myself!
mgclark6 is offline
post #110 of 154 Old 03-07-2014, 08:46 AM Thread Starter
mgclark6
Finally got around to a few pics. this is the Old Man Emu 2.5" lift with 1" BL MML. Found this ramp behind a warehouse. I think it would go higher, i was paranoid of getting cought. They probably wouldn't have cared though.
mgclark6 is offline
post #111 of 154 Old 03-07-2014, 12:07 PM
michigan37
2010 JK Wrangler
Looks great! Do you have any pictures of it sitting flat? Also, did you go with any bump stop extensions?
michigan37 is offline
post #112 of 154 Old 03-07-2014, 04:30 PM Thread Starter
mgclark6
Here is before and after
And yes, i did bumpstop. When flexing it looks like i could run up to 34" tires with no rubbing. I might take one puck out up front and check again.
mgclark6 is offline
post #113 of 154 Old 03-09-2014, 10:51 PM
G Beasley
Very nice ! Were you surprised at how much better it rode ?
post #114 of 154 Old 03-10-2014, 12:09 AM Thread Starter
mgclark6
Oh yea! Ride is amazingly smooth! 65mph just glides down the highway and great around town too
mgclark6 is offline
post #115 of 154 Old 03-10-2014, 11:54 AM
dongalonga
Very clean LJ. I had DPGs Super Ultimate on my TJ and absolutely loved it. Enjoy and keep it shiny side up. Not sure if you did control arms yet, but take Beasley's advice and go JJ or MC. You will be much happier in the long run.
dongalonga is offline
post #116 of 154 Old 03-10-2014, 02:43 PM Thread Starter
mgclark6
Yea, no control arms yet. His advice is as good as gold! When money allows, they will be my next mod.
mgclark6 is offline
post #117 of 154 Old 03-12-2014, 03:11 PM Thread Starter
mgclark6
First trip out of town and first shakedown since lift and noticed a bit of what they call the Death Wobble. In my case it is initiated by rough road or a pothole. Did a lot of reading and have a list of things to check before ill feel safe at highway speeds
Check torque on new JKS tracbar, CHECK
Dry steer and look/feel all steering joints for play. CHECK
Inspect all control arm bushings. CHECK
Make sure lug nuts are tight. CHECK
Inspect front driveshaft U-Joints CHECK
During inspection i found right front axle U-Joint needs replaced (gonna warm up this weekend so im gonna stop till i have more free time, why does it always drop 20* when i need to work on my Jeep?)
Other things i need to CHECK off my list:
Replace front axle u-joint that i found bad.
Loosen all control arms like the lift instructions said to do in the first place, then re-torque with weight on axles. (I think this is my main problem)
Check wheel bearings.
Buy a angle thingie and check camber.
Im using this as a guideline... http://www.automotiveforums.com/t936...ent_bible.html This guy did a nice write-up!
But i am always open to suggestions.
'05 LJ Rubi 2.5" DPG OME 1.25" BL, 1" MML, Rokmen TT skid, F&R JKS adj trackbars, JKS extended rear sway links, JKS front disco sway links
Edit, 255/85/16 tires are new and were balanced less than 2000 miles ago
mgclark6 is offline
post #118 of 154 Old 03-12-2014, 03:55 PM
dongalonga
Get you wheel balance checked. With my last TJ that was the cause of all of my shimmy issues. Once that is good get some control arms. Your caster may be off and causing some issues as well.
post #119 of 154 Old 03-12-2014, 04:07 PM Thread Starter
mgclark6
Thanks,
Tires are new and were balanced 2000 miles ago.
I may have confused the word camber, with the word caster. Still learning the terminology
mgclark6 is offline
post #120 of 154 Old 03-12-2014, 04:23 PM
dongalonga
Yeah if your camber is off something is bent....badly!
