Mikes 05 Unlimbited Rubicon Build - Page 7 - JeepForum.com
post #91 of 154 Old 02-17-2014, 03:51 PM Thread Starter
mgclark6
Originally Posted by G Beasley
What lockbox did you get ?
I was wrong about the lockbox rand i bought. I looked at the bestop box for so long, but ended up with the tuffy lockbox. It fit without any mods and installed in a few minutes.
I dont know if it would hold a full sized "flashlight" but it holds a compact sr9c with holster just fine.
mgclark6 is offline
post #92 of 154 Old 02-17-2014, 07:33 PM
G Beasley
Glad you got the tuffy , they are supposed to be a much nicer and better fitting box .
G Beasley is offline
post #93 of 154 Old 02-19-2014, 12:52 PM Thread Starter
mgclark6
Just ordered OME ultimate kit from DPGoffroad.com! Now for the wait.
mgclark6 is offline
post #94 of 154 Old 02-20-2014, 07:41 PM Thread Starter
mgclark6
WOW! Dirk is quick! Got the JKS control arms and end links a day after i ordered!
Waiting on springs and shocks.
mgclark6 is offline
post #95 of 154 Old 02-20-2014, 08:13 PM
G Beasley
Same kit I started with , it rides great and flexes just as well . The only complaint I had with the kit was the lack of longevity out of the JKS arms . Mine started clunking at 10k miles .
And Dirk was great to deal with , no complaints there .
post #96 of 154 Old 02-20-2014, 08:52 PM Thread Starter
mgclark6
Ill probably be 90% commuter so hopefully the arms will last me a bit longer. Yea, Dirk is great! Cant wait till the other boxes show up.
mgclark6 is offline
post #97 of 154 Old 02-21-2014, 11:59 AM
bobthetj03
Maybe a certain someone will have better luck with those arms than you did?.
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #98 of 154 Old 02-24-2014, 06:51 PM
G Beasley
He has had no issues and no noise out of them so far ? Maybe I could have gotten away with re greasing and tightening them , but for the cross country runs I make it made sense to upgrade to me .
post #99 of 154 Old 02-25-2014, 06:51 PM Thread Starter
mgclark6
It's here!
mgclark6 is offline
post #100 of 154 Old 02-25-2014, 06:53 PM
G Beasley
It's here!
Time to do work !
post #101 of 154 Old 02-25-2014, 07:04 PM Thread Starter
mgclark6
Got the weekend and next week off. Shouldn't be a problem. Are you still running OME coils? Dirk set me up with 934 (ZJ V8) fronts and 942 (TJ HD)rears with long travel shocks. I trust Dirks setup. Cant wait to get er done! When i get $$ for control arms and ext brake lines, i should be set
mgclark6 is offline
post #102 of 154 Old 02-25-2014, 07:47 PM
G Beasley
I am running Savvy 3" coils now , but they are only a 1/4" taller than the OME's I had . The ride is a little more firm than the OME's but I am happy with it . I am still running the OME long travel shocks , but at some point I will get tuned Fox's from Wayne at Alltech .
I have the extended brake lines from DPG and they are fraying at the bottom from rubbing against the caliper bolt . I plan on replacing them with the YJ hoses for a lot less money and more length .
post #103 of 154 Old 02-28-2014, 07:21 PM Thread Starter
mgclark6
Got the rear springs and rear sway bar extensions installed. Broke three out of four rear upper shock bolts. Left my air hammer at my brothers house, he gonna bring it in the morning. WHAT A STUPID DESIGN! Read a lot! If air hammer doesnt pop the welded nuts off, looks like im gonna have to lift the body up enough to grind them off. Also looks like i might need a bracket for the rear trac bar (the zirk fitting hits the factory bracket on axel side). Im in no hurry and working solo, so i didnt start on the front yet. The rear bumpstop extensions went in very easily. If anyone has a simple solution for the rear shock upper bolts, please chime in!
mgclark6 is offline
post #104 of 154 Old 03-01-2014, 01:04 AM
Laredo-Alex
Yes! I took new bolts, turned them arround and weldet the head of the bolt at the Position the bolt was before. Now i fix the shocks with nuts. That was the easyest and cheapest way. I hope you know what i mean?
Proud member of the LJ-Family :) => 2005 LJ Rubicon - YES!
Laredo-Alex is offline
post #105 of 154 Old 03-01-2014, 07:23 PM Thread Starter
mgclark6
No welder. $40.00 worth drill bits and a few hours later and its done
mgclark6 is offline
