Mikes 05 Unlimbited Rubicon Build - Page 6 - JeepForum.com
post #76 of 154 Old 01-17-2014, 02:22 PM Thread Starter
mgclark6
Now for the reason i wanted to update my thread.....Finally got my tires. Cooper Discoverer ST 255/85/16, equal to about 33.2"x10". Great in snow (better than the Duratracs that were on it)
Clearance will be tight, no offroading till i lift another 2", but no rubbing when turning. Lift is next!.....soon!
mgclark6 is offline
post #77 of 154 Old 01-17-2014, 08:53 PM
G Beasley
Tires look good , time for a tax refund lift !
I have a pair of 1.5"coil spacers somewhere in the garage if you want them ?
G Beasley is offline
post #78 of 154 Old 01-17-2014, 09:12 PM Thread Starter
mgclark6
I've been planning on the OME ultimate kit from Dirk at DPG, I wonder if 1.5 would be tall enough to stuff those skinny tires into the wheel wells? Did you run them with stock track bars with no problems?
That would save money to finish my 4.6 Stroker....you got me thinkin now.
mgclark6 is offline
post #79 of 154 Old 01-17-2014, 09:18 PM
G Beasley
I never ran them , not even sure where they came from ! I dont think they would hurt , and other than a slightly off center axle they should help a bit . Its just two of them , so you will have to come up with two more . As to the Ultimate lift , skip the JKS arms and get some with Johnny Joints or the Metal Cloak joints . My JKS arms started clunking at very low mileage , and while on paper the design is good the Clevite bushings just dont last .
post #80 of 154 Old 01-19-2014, 09:16 PM Thread Starter
mgclark6
Now that i have some free time, here is the long version of my stroker story.
Once i had everything together and in Jeep it was GREAT! I was loving the power! And i only dropped to 13mpg. Cruising down the highway i developed an engine noise. pulled the engine (again) and before tearing down completely i found that my exhaust manifold was cracked. Awesome right? Now i have an excuse for the borla header ive been researching. A week later, header arrived and got everything back in Jeep.....Same noise!
So, pulled the engine (again) and tore everything apart to find my #6 piston was seizing up on the wrist pin. Piston slap, was the noise i was hearing. I was told that stock injectors would be fine....but i was told wrong. I was running too hot/lean, whatever. Im still learning.
I ordered a new piston and the 24# injectors that i should have started with. Reassembly is pretty quick now, getting good at this. During first drive after install i had a terrible squealing noise that i can assume was small bits going through my oil gallery and taking out my bearings. Total frustration had set in and i started researching crate engines.
A few days later i decided on ATK crate and i paid extra to keep my core. My stroker project is put on hold until a later date. I will wait until the weather warms up before i even tear it apart.
I did however, talk to the shop that did my machine work. He said $75.00 to check all tolerances and mic everything and another $150.00 to assemble. Im hoping that bearings are the parts that i will need.
Im new at this, Im still learning. One thing i learned, is that when you have an engine out, on a stand, CHECK EVERYTHING! It might cost a bit more for gaskets, but it will save you in the long run. Another thing is CLEAN EVERYTHING! The smallest debris can cause a lot of trouble.
Then, i got my new tires.
Okay, all caught up on my build thread now, lol.
mgclark6 is offline
post #81 of 154 Old 02-14-2014, 01:12 AM Thread Starter
mgclark6
I got my valentine some new floor mats, an underseat ccw drawer/lockbox and a new subwoofer! I love you Jeep!
mgclark6 is offline
post #82 of 154 Old 02-14-2014, 07:54 AM
AdamH07
1981 CJ8
Nice looking LJ rubi. How far away are you from the lift do you think?
'81 CJ8 Scrambler
'82 CJ8 Scrambler
AdamH07 is offline
post #83 of 154 Old 02-14-2014, 08:59 AM
michigan37
2010 JK Wrangler
Awesome looking LJ! What part of ohio are you in? I'm in West Chester. If you go with the spacer lift, I have a track bar bracket laying in my garage that you can have, bought it when I put my lift on, but ended up getting a JKS adjustable track bar. If we're close, we can meet up.
michigan37 is offline
post #84 of 154 Old 02-14-2014, 05:19 PM Thread Starter
mgclark6
Going to wait for warmer weather. Probably March or April.
mgclark6 is offline
post #85 of 154 Old 02-14-2014, 05:20 PM Thread Starter
mgclark6
I'm not too far. Bout an hour north in Tipp City.
mgclark6 is offline
post #86 of 154 Old 02-14-2014, 05:32 PM
G Beasley
What lockbox did you get ?
post #87 of 154 Old 02-15-2014, 01:52 PM Thread Starter
mgclark6
I got the bestop box that can be used with fold and tumble seat
mgclark6 is offline
post #88 of 154 Old 02-15-2014, 08:31 PM
G Beasley
Unless they have changed it , be prepared for some chopping . I like mine a lot , but I had to cut the fold and tumble out of mine to get it to clear . In retrospect I wish I had lifted the seat instead and that would have eliminated the seat frame chopping .
post #89 of 154 Old 02-16-2014, 05:13 PM Thread Starter
mgclark6
Oh, not happy to hear that. I spent the extra money hoping this one would fit. Im too busy to test fit now, but I'll let you know how it works.
mgclark6 is offline
post #90 of 154 Old 02-16-2014, 05:38 PM
G Beasley
Heres a link to the seat chopping I needed to clear the Bes Top drawer .
http://www.jeepforum.com/forum/f22/j...l#post13702222
