Mikes 05 Unlimbited Rubicon Build - Page 2 - JeepForum.com
post #16 of 154 Old 03-11-2013, 08:26 PM
G Beasley
Originally Posted by 143DAD View Post
That was a great red Jeep, kids, wife were ok
Yes it was , everything was perfect and it was just starting to grow up .
G Beasley is offline
post #17 of 154 Old 05-08-2013, 06:18 PM Thread Starter
mgclark6
Summer is upon us. Hardtop is hanging from new hoist. Just got another pkg today. JKS 1.25" body lift! Should have time to install this week! Pics to follow.
mgclark6 is offline
post #18 of 154 Old 05-08-2013, 07:55 PM
G Beasley
Get to work mister ! Check out the Rokmen video before you install the body lift , its chock full o' good info .
post #19 of 154 Old 05-14-2013, 08:17 AM Thread Starter
mgclark6
That was an excellent video. Only thing i can add for someone doing BL but not MML, is that its worth it to pull radiator when relocating fan shroud. Entire project took me about three hours. No rusted bolts, no issues for me.
I didnt think a one inch lift would make that much difference, but it did. Very glad i did it. Now I have room for TT skid.
image-396103774.jpg   image-2650815761.jpg   image-1561533996.jpg   image-4286546789.jpg
mgclark6 is offline
post #20 of 154 Old 05-27-2013, 05:37 PM Thread Starter
mgclark6
A few new pics
mgclark6 is offline
post #21 of 154 Old 05-30-2013, 01:40 PM Thread Starter
mgclark6
After offroading last weekend (see pics above), i developed a problem with oil pressure dropping to L after engine is warm, and an engine noise at 3000rpm
Changed oil Mobile1 5W-40 full synthetic and Mobile1 filter. Same problem
Replaced oil pressure sender with aftermarket sending unit. Same problem
Cleaned and installed factory unit, with tee fitting for real gauge. Same problem
Auto meter gauge reads about 7 psi at idle cold 3psi warm.
I also have an engine noise that is noticeable around 3000 rpm. Haven't tracked it down yet. Have only drive about 60 miles since weekend. Leaving it parked till i figure it out.
Next is pull valve cover, to take a look around, not sure what ill see if anything.
Drop oil pan to check pickup tube.
Money is tight but plenty of time.
If anyone has any ideas please chime in. Thanks!
Low oil pressure at idle , engine noise around 3000 rpm ,
mgclark6 is offline
post #22 of 154 Old 05-30-2013, 01:52 PM Thread Starter
mgclark6
Oh also replaced battery, it was time.
A 2" auto meter gauge fits nicely in the ashtray blank, just take your time making the hole.
mgclark6 is offline
post #23 of 154 Old 05-30-2013, 04:11 PM
jefro_97tj
You have my dream jeep,The electric lime green lj rubi 6 speed is just awesome . As for your engine noise have you checked into the OPDA issues with 05-06 I think it is?
jefro_97tj is offline
post #24 of 154 Old 05-30-2013, 06:10 PM Thread Starter
mgclark6
Yes I have, but i don't think low oil pressure is a symptom. I think im looking at bearings as well as OPDA (which i pulled and IS worn, and will also replace)
mgclark6 is offline
post #25 of 154 Old 05-30-2013, 06:12 PM Thread Starter
mgclark6
I actually looked for electric lime green LJ rubicon for about two years. Couldnt find an auto, so i had to learn how to drive a stick with a left leg prosthetic, lol
mgclark6 is offline
post #26 of 154 Old 07-23-2013, 01:31 PM Thread Starter
mgclark6
Little update....
After pulling pan and replacing rod and main bearings, still had low oil pressure. Pulled engine to get to camshaft bearings and found worn cam bearings and loose timing chain. Took block to machine shop to have bearings pressed in, got everything put back together and back in Jeep. Oil pressure is now normal!!
Engine was making piston slap noise at start up. Everything ran great, but i didnt like the noise. My machine shop engine guy said it was normal and probably wrist pin noise. I was not okay with that.
Ordered a new 258 Crankshaft, new rods and .030" over Kieth Black Pistons.....LET THE STROKER PROJECT BEGIN!
mgclark6 is offline
post #27 of 154 Old 07-23-2013, 01:42 PM Thread Starter
mgclark6
Engine came out real easy 2nd time. Took about four hours by myself.
mgclark6 is offline
post #28 of 154 Old 07-23-2013, 01:44 PM Thread Starter
mgclark6
I used blue painters tape to protect my fenders, those fenders can accumulate a lot of tools
mgclark6 is offline
post #29 of 154 Old 07-23-2013, 01:45 PM Thread Starter
mgclark6
Parts everywhere!
mgclark6 is offline
post #30 of 154 Old 07-23-2013, 01:51 PM Thread Starter
mgclark6
Nw crank arrived from Titan Engines. Pistons and rings missing
After a few phone calls, Titan is going to 2day ship the pistons. Not sure where the first set went? Titan has been excellent to deal with! Very knowledgable.
Disappointed about waiting two more days but i should have block to machine shop by weeks end. Titan is still my first choice, I recommend them and ill be using them again for sure!
Chuck is to Titan what Dirk is to DPG Offroad.
mgclark6 is offline
