MG's 2000 2Dr Build "Greyhound" - Page 5 - JeepForum.com
post #61 of 77 Old 03-16-2011, 12:33 PM Thread Starter
mg2000xj
Originally Posted by 1990JEEPXJ
i would love to have a similar XJ for DD duty. i love silver XJ's with some dark tint though. looks good dude
I had to find a better dd, I'm heading out your way for school next fall. The green one couldn't handle heading across the country.
-Morgan
'00 Silverstone 2 Door XJ
Utah Jeep Crew Member #119
mg2000xj is offline
post #62 of 77 Old 03-16-2011, 12:58 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
yeah i understand man. mine isnt an optimal DD really anymore. but it does the job until i graduate. where are you going to school out here?
1990JEEPXJ is offline
post #63 of 77 Old 03-16-2011, 01:18 PM
makemusic116
Love the Jeep man especially the color. If you don't mind my asking where did you pick up the factory fog light switch? I am looking to use the same setup with the factory switch to keep it looking clean on the inside.
2000 Cherokee Sport
4.25 Inch Rough Country Hybrid Lift
265/75/15 Wild Country XTX Sports
Flowmaster Super 44
My Build Thread...Everyday XJ
Build Total So Far: $1,738.87
makemusic116 is offline
post #64 of 77 Old 03-18-2011, 09:36 PM
2000BB6
who made your BB???
2000 XJ
2000BB6 is offline
post #65 of 77 Old 03-18-2011, 09:42 PM Thread Starter
mg2000xj
Not exactly real close but on your half of the US. Either U. of Utah or U of Nevada, Reno.
Well I got one from a part out on here in the classifieds but it was shot. Then I found one locally on craigslist. I lucked out and got a brand new one for half the price of used ones.
Originally Posted by 2000BB6 View Post
who made your BB???
Mix and match. Bought a set of brand new RC 1.5-2" shackles and then found a set of spacers on craigslist. Got it done for under $75
-Morgan
mg2000xj is offline
post #66 of 77 Old 03-18-2011, 09:45 PM
2000BB6
i like how it sits, better than mine lol
2000 XJ
2000BB6 is offline
post #67 of 77 Old 03-18-2011, 10:02 PM Thread Starter
mg2000xj
I need to get the rear up a little higher, its either just even or a little low in the ***.
-Morgan
mg2000xj is offline
post #68 of 77 Old 03-18-2011, 10:23 PM
OilTownXJ
Thats a clean looking 2Dr!
OilTownXJ is offline
post #69 of 77 Old 03-20-2011, 09:40 AM
2000BB6
haha its funny because i have a spare tire in my XJ and its a moab with the MTR
2000 XJ
2000BB6 is offline
post #70 of 77 Old 04-08-2011, 11:22 AM
4DoorXJ
Updates????
4DoorXJ is offline
post #71 of 77 Old 04-08-2011, 12:02 PM Thread Starter
mg2000xj
Not a whole lot to update. Just been driving it a lot.
Took it on a major roadtrip trip to South Carolina, 16 hours roundtrip without a single issue.
Got some C4X4 tow hook brackets from 4DoorXJ, need to buy some hooks and Ill get them installed soon.
I'm quickly going broke so I have my spare axles up for sale, hp30, xj44 and I also have a set of eccos on 30x9.50s if anyone is interested.
I'm still looking for a hitch locally and that will be about it for a while. Still unemployed due to my surgery. Hopefully I can get back to work/find a new job soon.
-Morgan
mg2000xj is offline
post #72 of 77 Old 06-20-2011, 05:00 AM
Joshharris98xj
Originally Posted by mg2000xj
Logan, I just want it to be as cute as yours, that's my main goal for the build.
Started the stereo install tonight. I started with cleaning up the wiring harness from my other xj. It was all hooked up and ready to go but the wiring was a mess, this is what I ended up with.
My headunit has ipod controls built in so I can plug it in and never have to actually touch the ipod. On my other xj I ran the cable under the center console and cut a hole in the center console bucket and let it sit in there. I didnt like this because I wasnt able to lock it up without removing it and putting it in the glove box. So where did I run the cable on this one? The glove box of course. I ran the wire behind the headunit, through the dash and into the glove box from the back
To keep the cable from falling back into the dash I drilled two small holes for a zip tie.
Now I can leave the glove box locked while still being able to use my ipod.
I also use my droid for music which means I needed a 3.5mm headphone jack somewhere. In my old xj I had one ran under the center console to the ash tray and left the wire coiled up inside when not in use. I did this pretty much exactly as I had done before.
I drilled the hole in this position only to realize the cable wouldnt fit in the compartment where the ash tray drops into. I redrilled the hole in the rear of the try slightly offset to the left and it fit perfectly.
Put a zip tie around the cable to keep it from sliding back into the center console and we were good to go.
All installed
Next up will be speakers and most likely a new sub and amp. I will swap the Polk components from the old xj into this one and when Im done typing this Im buying a set of Polk coax speakers to match the fronts.
Im going to install the front speakers like I had them on the old xj but I will mount the crossovers inside the door. Like this,
Thanks for looking
That door is amazing
Joshharris98xj is offline
post #73 of 77 Old 06-20-2011, 05:03 AM
Joshharris98xj
Alright guys, here are few more photos of the stereo install. I didnt take as many photos as I should have but you get the idea. If you have any questions let me know.
This is how the jeep looked for a week or two
New speaker wire ran under the trim at the rear of the headliner. Went through the back to the crossover which is now tucked up inside the soundbar behind the speaker
Ran the wires down the c pillar, behind the trim, to the amp mounted on the drivers side trunk wall
The front speaker wires were ran down the door sills under the trim pieces and up through the stock door grommets. The front component crossovers are mounted inside the door panels.
Completed
Rear speakers are covered by the stock grilles
I still need to pull the door panels off and check out what the tweeters are hitting. Something behind them is pushing them out not allowing the tweeter cups to sit flush. I will do this once the weather is nice and Im not on crutches and a leg brace.
I dont ever want to do another 4ch amp/new speaker wire/speaker install again. It was frustrating and a ton of work but I did actually get it to look nice and clean like I wanted.
Here is the trunk as of now, I plan on building a tool box that will match the dimensions of the sub box as well. Thats one of the next projects I will get to.
Id also like to get my windows tinted now that I have some expensive equipment in the jeep. The less thats visible the better.
On a slightly different note, I ordered a 2002 Suburban rear view mirror off ebay. It has a compass and temp sensor I plan on hooking up. should be here in the next few days.
Thanks for looking
Awesome wiring job! It looks good 2 thumbs up
post #74 of 77 Old 06-20-2011, 05:13 AM
Joshharris98xj
Haha you have like 100 jeeps man
post #75 of 77 Old 06-20-2011, 10:43 PM Thread Starter
mg2000xj
Only 1 now, I plan on keeping this one for a while.
I did get a hitch installed the other day and Im ready to throw down for my lift but I really need to save money for school. Priorities priorities
-Morgan
mg2000xj is offline
2009 Rubicon Unlimited build-up, 41" tires ~ 9.5" lift JPTwinz Jeep Builds 71 05-08-2012 09:24 AM
2000 TJ "Chili Pepper Edition" cbrookerd Jeep Builds 11 10-03-2010 04:13 PM
2" or 3" lift on 2000 Jeep Wrangler marineman428 Jeep Builds 3 09-09-2010 12:31 PM
1997 TJ "Angry Wolf" Redneck Body Shop Build NorthWhiteWolf Jeep Builds 389 06-17-2010 06:33 PM
00CherokeeXJ14 Project "Xtreme Urban" Build thread 98GooseXJ14 Jeep Builds 15 02-26-2010 10:27 PM
