mburgess00's 1979 CJ5 SBC upgrade/build - Page 2 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > mburgess00's 1979 CJ5 SBC upgrade/build
Introducing MONSTALINER UV Permanent DIY Roll On Bed LineNEW ZJ Grand Cherokee Tube DoorsGibson WK HEMI 3" Catback - 5 Day Special!
Unread 04-01-2013, 04:25 PM   #16
mburgess00
1979 CJ5
Originally Posted by Copperhead89 View Post
I see you've got a 4 bolt main block. Nice!
I lucked out in many ways with this junkyard engine. Only thing it didn't have was a roller cam, but it does have the provisions for one - budget just didn't allow for one
mburgess00 is offline   Reply With Quote Quick reply to this message
Unread 04-03-2013, 06:38 PM   #17
mburgess00
1979 CJ5
I got a little time this afternoon to put the oil pan, oil adapter, and crank pulley on. (Pic before crank pulley)
Unread 04-04-2013, 08:59 PM   #18
mburgess00
1979 CJ5
Some valve covers and engine enamel and....
BAM!
Unread 04-05-2013, 05:46 PM   #19
mburgess00
1979 CJ5
Now I get why the adapter kits are so pricey. This thing is a thing of beauty. Paint can and bananas for scale
Unread 04-08-2013, 03:49 PM   #20
mburgess00
1979 CJ5
I took the day off of work, and made some significant progress. Items of interest are:
-York 210 (10 cubic inch) air conditioner pump (top left). Will be used for on board air.
-Delco cs144 alternator for 140 amps of power (top right). Should be a nice upgrade from 105 amps and hold up to a winch nicely
Last edited by mburgess00; 04-11-2013 at 09:43 AM.. Reason: fix units on york displacement
Unread 04-15-2013, 09:33 AM   #21
mburgess00
1979 CJ5
For anyone interested in the inner workings of the SM465, refer to the photo below:
This is before I rebuilt it. Third gear on the countershaft was slid to the left to facilitate removal from the case. Normally it goes right up against 2nd gear.
Unread 04-15-2013, 12:06 PM   #22
rusty762
rusty762's Avatar
Block is looking good!
Rusty
If I had eight hours to chop down a tree, Id spend six sharpening my axe.- Abraham Lincoln
My Build
My Videos
My Work
Have you hugged a Firefighter today?
rusty762 is offline   Reply With Quote Quick reply to this message
Unread 04-15-2013, 03:07 PM   #23
mburgess00
1979 CJ5
Thanks! I'm working on a stubborn pilot bearing, but after that I think it's done!
Unread 04-16-2013, 06:49 PM   #24
mburgess00
1979 CJ5
Quick update - no luck still on the pilot bearing, but the adapter plate came in from Novak today.
View of the gears, installed:
Plate installed temporarily to check end play:
Good view of the third gear spacer from Anaheim Gear on the countershaft through the PTO port:
Unread 04-21-2013, 05:20 PM   #25
mburgess00
1979 CJ5
I finally got that annoying pilot bearing out. Guess luck was just on my side today - I gave it another try with the slide hammer from Auto Zone and it came right out.
Here's a pic with the clutch installed:
Unread 05-03-2013, 02:35 PM   #26
mburgess00
1979 CJ5
Did some serious work on the Jeep today.
First was installing the transmission on the engine:
Then it was on to the Jeep:
The small T150 (at least compared to an sm465):
Gaping hole where an engine used to live:
Unread 07-17-2013, 06:48 PM   #27
GTNMUDY
Dont know how far you are on your install, but when I did mine the distributor was really close to the firewall making it difficult to remove the cap.
I went with a Unilite solid state dist. I gained about 1-2 inches clearance.
Your going to like it.
I have over 110,000 miles on my SBC since I put it in and still runs great.
Hope you ported and polished the heads and intake before you assemble them.
Larry
GTNMUDY is offline   Reply With Quote Quick reply to this message
Unread 01-16-2014, 08:19 AM   #28
mburgess00
1979 CJ5
It's been quite a while, but I made some modest progress this past week.
Here's a couple of pics of me lowering it in to mock up motor mounts, etc.
Unread 02-15-2014, 05:32 PM   #29
mburgess00
1979 CJ5
No hoist!
Engine is resting on the permanent mounts, finally!
And a view of the transmission in the tunnel
cj5 , sbc
