mburgess00's 1979 CJ5 SBC upgrade/build - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > mburgess00's 1979 CJ5 SBC upgrade/build
Unread 03-08-2013, 10:15 AM   #1
mburgess00
1979 CJ5
So, I'm just getting started on this build. I thought I'd put it up here in case any body would like to follow along. If not, carry on .
This is what I started with:
I just obtained this, which I'll be rebuilding (and of course, documenting):
Stand by for updates!
mburgess00 is offline   Reply With Quote Quick reply to this message
Unread 03-09-2013, 09:47 AM   #2
Luckyirish2440
Just don't change the color.
Have fun!
Luckyirish2440 is offline   Reply With Quote Quick reply to this message
Unread 03-09-2013, 06:36 PM   #3
mburgess00
1979 CJ5
It was a snowy day here in Colorado, and the garage was decently warm, so I spent some time out there and got the engine completely disassembled.
The lower end is in remarkably good shape. You can even still see the crosshatch pattern in the cylinders. The heads, on the other hand, are at least filthy, if not worse. Anybody have any opinions on head casting 10110810 on a SBC?
Unread 03-18-2013, 09:15 AM   #4
mburgess00
1979 CJ5
new toy
I got a new toy this weekend:
It's an SM465, complete with bellhousing, clutch, flywheel, and np205 transfer case.
I'm not going to be able to use the np205 because of the long adapter between the sm465 and np205, so I'll be looking to sell it (anyone looking for one?).
Stay tuned...
Unread 03-19-2013, 06:24 PM   #5
mburgess00
1979 CJ5
Santa came in March this year!
Edit: sadly the radiator is dented, but summit is sending me a new one.
Unread 03-19-2013, 11:38 PM   #6
titanjeep
1980 CJ5
Subscribed. Looking forward to following this one.
Air Force Jeep Club - Tail# JF183RV
2003 KJ
1980 CJ5
1988 Wagoneer
titanjeep is offline   Reply With Quote Quick reply to this message
Unread 03-20-2013, 08:45 AM   #7
CjHouch
CjHouch's Avatar
1976 CJ5
New parts look good. Going to follow along too.
Greg
CjHouch is offline   Reply With Quote Quick reply to this message
Unread 03-21-2013, 09:02 AM   #8
mburgess00
1979 CJ5
Quick tip for those that may rebuild a small block chevy. If you plan on reusing pistons, check the depth of the oil ring groove before ordering rings.
I was not aware that there was a shallow or deep configuration. It appears that deep is the more common type, but I have shallow. With the deep oil ring installed, the piston would not go into the cylinder
Unread 03-22-2013, 09:08 PM   #9
mburgess00
1979 CJ5
I have a short block (mostly, need oil pan and timing gear yet)!
Unread 03-26-2013, 07:33 AM   #10
mburgess00
1979 CJ5
I got the heads installed last night as well as the timing gear, and got the valves "adjusted" - hydraulic lifters are so easy!
Unread 03-26-2013, 10:20 PM   #11
gmalone
I went with a 1991 chevy 4.3 v6 and removed the coil and throttle body and replaced it with a cast iron intake from a 1987 chevy astro van and finished it off with a edelbrock 1400 series 600 cfm carb. This bolted right up with the t-176 after installing 152 tooth flywheel and new clutch kit. Transdapt made my bolt-on motor mounts for arount $80.00. Using the same tranfer case. 5.9 psi electric fuel pump mounted on frame near tank. Had to purchase an electronic distributor out of Tn. for around $85.00 and set the time. This was fairly easy to do.Had to do no mods to front or rear drive shafts. They went right back in perfectly.
gmalone is offline   Reply With Quote Quick reply to this message
Unread 03-26-2013, 10:25 PM   #12
titanjeep
1980 CJ5
I don't suppose you have a write-up somewhere on this swap?
2003 KJ
1980 CJ5
1988 Wagoneer
Unread 03-27-2013, 08:24 AM   #13
mburgess00
1979 CJ5
I get that people have different tastes, but why get rid of the TBI? That's actually a major reason for this swap IMO. Believe it or not, it is easier emissions-wise here to swap the whole engine to get TBI than just go junkyard TBI.
Unread 04-01-2013, 01:40 PM   #14
mburgess00
1979 CJ5
I got the intake manifold and rear main seal installed over the weekend! Sorry, no pics were taken
Unread 04-01-2013, 05:21 PM   #15
Copperhead89
I see you've got a 4 bolt main block. Nice!
My YJ/CJ V8 Magnum Build: http://jeepforum.com/forum/f22/magnum-force-mopar-mans-build-1412306/
Copperhead89 is offline   Reply With Quote Quick reply to this message
cj5 , sbc
