Marn's 73 Wagoneer Thread - Back in action! - Page 96 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Marn's 73 Wagoneer Thread - Back in action!
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 03-08-2013, 09:57 AM   #1426
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Makes it worse? How? I must not be following you correctly... You said your pumpkin sits a few inches off to the side, correct? So move your transmission mount an inch in the same direction. That is most definitely not making it worse.
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline   Reply With Quote Quick reply to this message
Unread 03-08-2013, 12:12 PM   #1427
Dr. Marneaus
Station Wagoneer
Dr. Marneaus's Avatar
1973 FSJ Wagoneer
U joint angles need to be parallel. Google image search 'u joint angle' and you will see that your solution is incorrect
By simply cocking the back of the engine to the right you are creating a different u joint angle at the t case than at the axle pinion, thus, incorrect driveline angles.
If I were to pick up my entire engine and move it all to the right that's a different story
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread: Marns '73 Wagoneer Thread ----- The Camper Build Thread: Marns 1980 Jayco JayFinch6 Build Thread
Dr. Marneaus is offline   Reply With Quote Quick reply to this message
Unread 03-09-2013, 12:38 AM   #1428
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Ok well it may not fix the problem, but it won't hurt I'm sure
Andy, KD8EIA
Unread 03-09-2013, 06:28 PM   #1429
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Out with the old
next to the slightly less old:
Seems Legit.....
But as of right now:
My brake lines are a total mess (need replaced) and I have no shocks, and the e-brake lines on this axle are cut do i need to address that when I do new shoes and drums and hardware.
My exhaust is held in place off to the side with a wire hanger
My front drive shaft is unbolted and held in place with a wire hanger and duct tape (and no i still dont have an inspection cover on my torque converter)
But, it seems to ride and drive fine. Had it up to about 50 in the neighborhood, havent dared to take it on the highway with those rotted 31's and no shocks. But, no weird vibes or anything, so, hopefully upwards of 60 MPH it drives the same.
Phew, i'm beat.
-Andrew
Unread 03-11-2013, 12:02 AM   #1430
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Okay, here's how everything looks under the truck.
So, i had to move my muffler over slightly, it was just barely touching the drive shaft before.
-Andrew
Unread 03-11-2013, 01:05 AM   #1431
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Looks not so bad
Andy, KD8EIA
Unread 03-11-2013, 04:22 PM   #1432
robert_hollis
I think you addressed this, but I've forgotten. Do you plan to eventually go with a disc brake upgrade for the new rearend?
You read it. You can't unread it!
[URL="http://picasaweb.google.com/hollisr4/TJ?feat=directlink"]2006 TJ[/URL]
[URL="http://picasaweb.google.com/hollisr4/1979JeepCherokee?feat=directlink"]1979 SJ[/URL]
1978 Cherokee Chief - bought for parts, and sold as a runner
robert_hollis is offline   Reply With Quote Quick reply to this message
Unread 03-11-2013, 04:32 PM   #1433
1MoparMan
Very Nice!
In the Market for a YJ again!
Past rides: 1990 YJ 2.5, 2005 GC 5.7, 2006 Rubicon, 88 Corvete C4
Current rides: 2003 Ram 2500 4x4 CTD, not so stock. 2009 Ford Focus SES (wife's)
1MoparMan is offline   Reply With Quote Quick reply to this message
Unread 03-11-2013, 05:16 PM   #1434
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Originally Posted by Grewe02 View Post
Looks not so bad
thats sort of what i figured
No, i do not.
-Andrew
Unread 03-13-2013, 05:05 PM   #1435
MountainMan864
Damn your **** is crooked.
MountainMan864 is offline   Reply With Quote Quick reply to this message
Unread 03-13-2013, 09:01 PM   #1436
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
painted two rims tonight, these are going to look NIIIIICE with the dig dishes.
speaking of dog dishes...i have a plethora...
-Andrew
Unread 03-14-2013, 01:29 PM   #1437
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
How many coats did you use on the rims? And what kind of rattle can?
Andy, KD8EIA
Unread 03-14-2013, 01:48 PM   #1438
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
38 coats, krylon fusion.
No, its 2 coats, and i didnt prime because I wanted to shoot white over white, and there was no rust or anything.
Its duplicolor wheel paint. I've had great luck with it in the past. Being white, it'll be super easy to touch up as well. pull the wheel and shoot another coat, done.
I just sanded down and removed any discoloration, leveled any chips, then whiped the wheels down with Prep-all, and painted away.
on my magnum the wheels had some weird clear coat from the factory that I couldnt remove, so I used self etching primer, then dupilcolor regular car paint, then duplicolor wheel clear coat. Held up perfect for a good 2 years. I had 1 or 2 nicks from like hitting it with a tire iron or something, but other than that, it was great.
-Andrew
Unread 03-14-2013, 09:50 PM   #1439
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Before (black steelies were 'aite' but didnt really do it justice)
After:
SA-WEET!
So, with all this axle stuff I stuck the rear in to test it out, and I had to get my good tires swapped over for a full speed road test. I figured Ii'd refurb the rims before putting the tires on.
I've always loved the vintage look, I know these arent correct to the year of my wag, but I prefer them over the full hub caps.
Sorry if i'm tootin' my own horn, but they came out great! I am not sure if i will redo the paint on the dog dishes.
-Andrew
Unread 03-15-2013, 08:57 AM   #1440
MountainMan864
Def. a 70's look not a modern look by any means lol.
1973 , build up , dr. marneaus , grand wagoneer , jeep , wagoneer
