Marn's 73 Wagoneer Thread - Back in action! - Page 95 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Marn's 73 Wagoneer Thread - Back in action!
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 02-27-2013, 08:44 AM   #1411
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Those are going to look so "right" on the waggy.
06 WK Hemi Overland.. stock DD
87 MJ project on 37s.. Waggy axles, 6 speed, flipped D300 and Bobbed 10" so far. 3 link coming soon.
Sold:
05 LJ.. Low and on 37s
79 FSJ.. 360/4speed on 38s
85 CJ-7 Renegade
Buy my AEV Pintler TJ Beadlocks. See the classifieds.
dayriesw is offline   Reply With Quote Quick reply to this message
Unread 02-27-2013, 11:15 AM   #1412
Dr. Marneaus
Station Wagoneer
Dr. Marneaus's Avatar
1973 FSJ Wagoneer
I agree. :-)
Also got the front end up on stands so its ready to be worked on
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread: Marns '73 Wagoneer Thread ----- The Camper Build Thread: Marns 1980 Jayco JayFinch6 Build Thread
Dr. Marneaus is offline   Reply With Quote Quick reply to this message
Unread 02-27-2013, 07:12 PM   #1413
dayriesw
dayriesw's Avatar
1987 MJ Comanche
What front axle do you have installed now?
Sold:
85 CJ-7 Renegade
Unread 02-27-2013, 08:42 PM   #1414
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
this is on hold, I dont think the rear axle is going to work. Long story. I'm an idiot.
-Andrew
Unread 02-27-2013, 09:28 PM   #1415
MountainMan864
Info on why please.
MountainMan864 is offline   Reply With Quote Quick reply to this message
Unread 02-27-2013, 10:01 PM   #1416
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Originally Posted by MountainMan864
Info on why please.
Narrow track and wide track quadra-trac axles are different. The NT have more offset than the WT. I have an NT set and I'm currently running a centered transfer case.
My current axle is offset 3.5" to clear the gas tank. The new axle is offset 6.5".
From what I'm being told, this is too much and will cause driveline vibes and issues.
-Andrew
Unread 02-28-2013, 02:01 AM   #1417
XJAbuzer
I agree. :-)
Attachment 574196
Are you going to paint the wheels tan to match the body or are you going with white. Personally, I think tan would be best.
Abuzed 2000 Cherokee...black -n- blue build
My Youtube Channel
1979 CJ-5 304 V-8, T-150 3 speed, Dana 20, Dana 30 front, AMC 20 rear, Sold
Anyways, I wanna go wheelin'!
XJAbuzer is offline   Reply With Quote Quick reply to this message
Unread 02-28-2013, 07:54 AM   #1418
MountainMan864
Ouch. Betcha wont make that mistake again. Well try and sell em and make a buck.
Unread 02-28-2013, 01:48 PM   #1419
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
i'm going to throw the offset axle under the truck and see how it rides, before i put a penny into it or the front.
back up plan may involve swapping to small bearing spindles, and ford hubs/rotors in the front, then regearing my current D44, as nothing is being gained by swapping my rear axle, the only reason for swapping the rear is to keep the gears the same.
-Andrew
Unread 02-28-2013, 05:41 PM   #1420
dayriesw
dayriesw's Avatar
1987 MJ Comanche
PMd.
Sold:
85 CJ-7 Renegade
Unread 02-28-2013, 06:31 PM   #1421
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Originally Posted by dayriesw View Post
PMd.
Uh, my axles are not for sale.
-Andrew
Unread 03-07-2013, 06:20 PM   #1422
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
So, I'm going to toss the rear axle under my truck this weekend, and see how it drives, if there are turrible vibes, etc. Then i will either scrap the project or proceed forward with the swap as originally planned. Fingers crossed.
picked up new wheel cylinders, and got one side done before it got dark yesterday. I just need to get these on before i can do the swap so everything runs right. Also picked up a new brake hose and u joints for the drive shaft.
I hate drum brakes.
But look, here I am using the correct tool to avoid getting 16 stitches like last time.
-Andrew
Unread 03-07-2013, 10:34 PM   #1423
robert_hollis
My Cherokee is running a centered D20 with a lift, and can manage 70 without wild vibes... I think, as long as your gas tank is cleared, you'll be fine. But that's just a guess...
You read it. You can't unread it!
[URL="http://picasaweb.google.com/hollisr4/TJ?feat=directlink"]2006 TJ[/URL]
[URL="http://picasaweb.google.com/hollisr4/1979JeepCherokee?feat=directlink"]1979 SJ[/URL]
1978 Cherokee Chief - bought for parts, and sold as a runner
robert_hollis is offline   Reply With Quote Quick reply to this message
Unread 03-08-2013, 09:39 AM   #1424
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
I still don't know why you can't move your transmission mount off to the side by an inch
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline   Reply With Quote Quick reply to this message
Unread 03-08-2013, 09:51 AM   #1425
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Because that creates an even worse driveline angle. U joint angles need to be parallel. Do some research man!
-Andrew
1973 , build up , dr. marneaus , grand wagoneer , jeep , wagoneer
