Marn's 73 Wagoneer Thread - Back in action! - Page 9 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Marn's 73 Wagoneer Thread - Back in action!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 08-15-2010, 03:03 PM   #121
jblox
i love wagoneers. crawled!
jblox is offline   Reply With Quote Quick reply to this message
Unread 08-15-2010, 04:59 PM   #122
Geister
im subbing to his thread. the wagoneer is awesome.
"If you don't fear death, then death will fear you"--Whitt
Geister is offline   Reply With Quote Quick reply to this message
Unread 08-15-2010, 09:39 PM   #123
Dr. Marneaus
Station Wagoneer
Dr. Marneaus's Avatar
1973 FSJ Wagoneer
Well, took her on her maiden voyage to test the waters, so to speak.
Look how happy I am...
Plan was to roll down across the hoover dam and take a 5 or 6 mile trail out to Lake Mohave on the AZ side, but across the dam one side of the highway was closed so I couldn't access the trail head.
Turned around and went to a lesser known beach on lake mead. It was nice, a few boats around but we were the only car there.
Just a crappy dirt road down to the beach with some nice views.
Then just a beach area with boats in the background.
OVerall it was about a 140 mile trip, jeep did great. It was about 109 near the lake, but then we went down to Nelson, NV and it got hotter, above 110. Jeep was getting HOT on big hills at highway speeds. I was trying to keep it going on the ups and downs at about 50mph on the road to nelson, but temp got up to around 225...EEK. Slowed down to about 40 and it dipped below 210 and stayed there.
Also, cleaned out the underside a little bit the other day. I thought i had a can of de-greaser, but apparently didnt. Still alot better than before.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread: Marns '73 Wagoneer Thread ----- The Camper Build Thread: Marns 1980 Jayco JayFinch6 Build Thread
Dr. Marneaus is offline   Reply With Quote Quick reply to this message
Unread 08-16-2010, 08:16 PM   #124
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Well, I eventually discovered a loose bolt on my flexplate, which pretty much kinda sorta solved the noise I was hearing...
But, there was still some noise "left over" if that makes any sense. A constant tick tick tick tick tick tick!
So, I made some more wonderful videos for you all.
You can hear it well from outside or under the truck, but this video best captures the noise as I was able to rev it right there. It sounds like its coming from upper driver side, a little bit back.
Clearly it increases to a instant tick at high rpms, then rattles and settles back into rhythm as it idles down.
This happens when warm or cold (read: with high or low oil pressure). Ticks with 65PSI on cold start, ticks with 25psi on warm high RPM.
Sounds maybe like a loose rocker to me? But I'm simply judging my the sound my lady's 69 nova made, and by youtube videos.
I guess my plan is to hope it's a rocker or pushrod, rather than a lifter....as that should be much easier to replace! This weekend I'll yank the valve cover and give 'er a looksee...
but in the meantime any guidance is appreciated!
-Andrew
Unread 08-18-2010, 07:08 PM   #125
1jack5
These things are just plain awesome! Especially with MT's. keep this thing up!
1jack5 is offline   Reply With Quote Quick reply to this message
Unread 08-18-2010, 08:05 PM   #126
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
I'm plannin on it! I work on it a little every day, and drive it on the weekends.
-Andrew
Unread 08-18-2010, 10:51 PM   #127
DaleII
My first check would just be to see if it was a rocker tick. That's what it seems like. Pull the valve cover and see if any of them are loose. If it's just loose you might be able to get away with just tightening it down correctly.
2005 Silver LJ
DaleII is offline   Reply With Quote Quick reply to this message
Unread 08-21-2010, 04:36 PM   #128
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
So, today I flushed my radiator out (I've got 3 gallons of anti freeze that I need to dispose of...any advice?)
Then adjusted the clamps on some of the fuel fill neck to hopefully keep it from dripping gas all the time when its full...
I got all excited and found an air nozzle on my bumper with lines going towards the shocks, and thought i had adjustable shocks...well, no, I don't, the lines were cut off and didn't go anywhere, so they must have done that when they put in the lift, so I ripped all that crap out.
Disconnected the trailer harness from the plug on my bumper, no need to keep it connected. I want to remove the trailer brake module from under my dashboard soon, but i need to remove the steel brake line from the master cylinder to it...and dont know how to cap it.
Then listened around some more for my strange noise with my new stethoscope, maybe its the fuel pump?
Then poked a hole half the side of a dime through the floor where I saw some rust. (small patch, under the rear rubber floor mat...still amazingly rust free for a 37 year old truck).
Then I went grocery shopping in the wagoneer. (insert jokes here).
Next items on the list are to fix my headlight switch, which went out, bypass the ammeter, bolt down my jerry can holder, and a million other things.
-Andrew
Unread 08-21-2010, 09:33 PM   #129
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Alrighty, it cooled down so I went back outside before it got dark to look into my headlight issue.
I saw what a wonderful rats nest the previous owners left me. In order to get to the switch I had to unbolt the brake box (which I want gone...but its tied into the master cylinder?) and figured since I was down there I'd make some changes.
Pulled out the selector switch for the fuel gauge....could switch between the two gas tanks. And just hard wired the lead from the aux tank to the gauge.
Pulled out the switch and disconnected my electric fuel pump (from when the aux tank was actually auxilary...) and pulled the wires for that.
It still looks like this, after removing a few switches and wires....gotta love rednecks. I think i see like 1 section of original wiring under there, haha.
then this is what I get to deal with under the hood...dear god, what a damn mess haha. Oh well, I'm slowly sorting through it.
-Andrew
Unread 08-21-2010, 11:40 PM   #130
1jack5
WOW, I hate when people do half a stuff like that, got pissed because I found 2 old wires that went to no where in my Jeep when I bought it. Well on the bright side looks like you will have something to work on the next couple weeks.
Why did you disconnect the trailer wiring, don't plan on pulling anything? Also one more question, you own two station wagons? at least both have v8's.
Unread 08-22-2010, 12:22 AM   #131
ujehed
Gave my baby a wash...and started a little special something...
No waggy is complete without a hood emblem.... adds 13.8 hp and cant remember the torque specs, you get the idea
ujehed is offline   Reply With Quote Quick reply to this message
Unread 08-22-2010, 12:29 AM   #132
ujehed
This sounds like an extremely small exhaust leak to me? Just an idea. Love the wag.
Unread 08-22-2010, 12:34 PM   #133
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Yeah, I've been getting alot of that, gonna check the manifold bolts today.
-Andrew
Unread 08-22-2010, 12:37 PM   #134
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Yup, no desire to tow with this waggy, it has a hard enough time starting and stopping itself and running warm as is, haha. Maybe like a little M101 trailer, but thats it.
And yes, I own two station wagons....and i wheel them both.
-Andrew
Unread 08-23-2010, 01:45 PM   #135
tj98
Great build Marn, one of my grade / high school buddies dad used Waggies as a rural postal delivery vehicle. He went through a few of them and one was this color.
I didn't see a clear pic of your master cylinder, if your trailer controller is hooked up like the ones I've removed from pickups your going to have to bleed the brakes to remove it. I usually wait until I have to replace the master cylinder and get rid of it then. On the ones I've removed I take the "T" out and plumb the brake line back into the master cylinder.
98 TJ - Sold
99 TJ - Mine
10 JKU - Sold
14 JK Unlimited - Wife's
tj98 is offline   Reply With Quote Quick reply to this message
1973 , build up , dr. marneaus , grand wagoneer , jeep , wagoneer
