Marn's 73 Wagoneer Thread - Back in action! - Page 62 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Marn's 73 Wagoneer Thread - Back in action!
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 01-12-2012, 09:07 AM   #916
73pumpkin
1973 FSJ Wagoneer
The chute pack would look way stylish!
73pumpkin is offline   Reply With Quote Quick reply to this message
Unread 01-12-2012, 11:12 AM   #917
Dr. Marneaus
Station Wagoneer
Dr. Marneaus's Avatar
1973 FSJ Wagoneer
Originally Posted by SuperMud View Post
Is ur d30 closed knuckle?
Yah, it's closed knuckle.
an you do me a big favor?
Can you get pictures of how your gas tank mounts to the truck? There should be 3 mounts. One on the front at the skinny end of the tank, one on the passenger side of the tank that has a bracket coming off of the crossmember, and one down at the fat end of the tank, just to the driver side of the filler tube on the tank.
Those are all the mounts, 3 in total. One at the front, one at the back, and one on the side next to the driveshaft.
Also can you try to get some pictures of the whole thing, so i can kind of see how it supposed to be positioned?
Thanks so much.
Those are all the mounts, 3 in total. One at the front, one at the back, and one on the side next to the driveshaft.[/quote]
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread: Marns '73 Wagoneer Thread ----- The Camper Build Thread: Marns 1980 Jayco JayFinch6 Build Thread
Dr. Marneaus is offline   Reply With Quote Quick reply to this message
Unread 01-12-2012, 02:33 PM   #918
73pumpkin
1973 FSJ Wagoneer
I'll take some pictures and post them. If they are not descriptive enough, I'll take more.
Unread 01-12-2012, 05:28 PM   #919
73pumpkin
1973 FSJ Wagoneer
I took some quicky pictures. Some are not so good. My jeep does not have any lift and i have 4" of snow around it. I'll try to take bette ones if you need them later. i may have to jack it up a bit. Here is the rear mount first.
Unread 01-12-2012, 05:32 PM   #920
73pumpkin
1973 FSJ Wagoneer
Here is the side mount. I don't see any bolts on this one. It seems to be just a wide strap maybe tack welded fast or wraped.
Unread 01-12-2012, 05:36 PM   #921
73pumpkin
1973 FSJ Wagoneer
Here is the front mount. These are especialy blurry.
Unread 01-12-2012, 05:44 PM   #922
73pumpkin
1973 FSJ Wagoneer
Here are two views of the entire tank. I may have a minute leak in my tank or it may be just grime from the rear differential. I'll check it out more thoroughly later. Can a person get a new tank for a 73 Wagoneer? I have also taken pictures of the fill hose arrangement.
rear-view-gas-tank.jpg   front-view-tank.jpg   fill-hose-rear-tank.jpg   fill-hose-over-rear-frame.jpg
Unread 01-12-2012, 07:41 PM   #923
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Can you get pictures of the side mount and the rear mount?
I've discovered that i have the front mount.
-Andrew
Unread 01-12-2012, 09:45 PM   #924
robert_hollis
Lovely
You read it. You can't unread it!
[URL="http://picasaweb.google.com/hollisr4/TJ?feat=directlink"]2006 TJ[/URL]
[URL="http://picasaweb.google.com/hollisr4/1979JeepCherokee?feat=directlink"]1979 SJ[/URL]
1978 Cherokee Chief - bought for parts, and sold as a runner
robert_hollis is offline   Reply With Quote Quick reply to this message
Unread 01-13-2012, 12:28 AM   #925
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Some dumb guy with a cherokee replied over on IFSJA but he only got me crappy pics...not nice ones like these.
Just kidding bob....
-Andrew
Unread 01-13-2012, 01:15 AM   #926
robert_hollis
I just hope it was an XJ. That's the only REAL Cherokee...
Unread 01-13-2012, 09:05 AM   #927
73pumpkin
1973 FSJ Wagoneer
That Vegas sand does a nice job of scouring away mud and grime. We get a nice undercoat of bentonite mud here in Wyoming. It makes a good glue. I asked if new tanks for 73s were available. Does anyone know if they are?
Unread 01-13-2012, 11:34 AM   #928
robert_hollis
bjsoffroad.com sells a poly tank for around $200. I believe it will look different, but fit in the same space. Or, if you plan on modding and wheeling it, you may want to go with an aftermarket (or even old suburban) tank that fits in the spare tire spot. Several guys have done that.
Unread 01-13-2012, 12:36 PM   #929
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
they are avail, but they;re slightly different, mount differently, and need some sort of rigging to get the fill hole connected to the fill tube, but yes. like 225 shipped.
-Andrew
Unread 01-13-2012, 12:36 PM   #930
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
on another note...
Saw this 79 j-10 honcho this morning and called the guy, told him i'd have him cash by noon....
he said it was already sold.....
Wait for it....
for $1300.
Interior was PERFECT had a clean looking 360 under the hood, q-track, but needed a new th400 (new, not rebuilt, the front DS let go and broke the hell out of the transmission case). Body was pretty decent, only damage was right there on the front fender and the missing bumper.
Sad. So sad, i pounched on it but just missed it.
-Andrew
1973 , build up , dr. marneaus , grand wagoneer , jeep , wagoneer
