Marn's 73 Wagoneer Thread - Back in action! - Page 6 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Marn's 73 Wagoneer Thread - Back in action!
Unread 07-07-2010, 08:51 PM   #76
Apex
Recon death squad
Apex's Avatar
Jeep is still down for the count, gonna try to drill out and tap the manifold tonight. if I fail....I'll be selling it.
Sell it to me...I'll drill it out and then helicoil it.
It isn't like you're talking about a manifold bolt or something...Or you could try starting with a small drill bit and stepping it up one size at a time until you can just pretty much scrape out the left overs...then chase the threads with a tap and clean them up.
Apex is offline   Reply With Quote Quick reply to this message
Unread 07-07-2010, 08:51 PM   #77
Apex
Recon death squad
Apex's Avatar
I wouldn't hesitate to helicoil this either since it isn't a crazy torque on the bolt...I wouldn't helicoil a bolt holding the heads on.
Unread 07-07-2010, 09:30 PM   #78
Dr. Marneaus
Station Wagoneer
Dr. Marneaus's Avatar
1973 FSJ Wagoneer
I just tapped it one size larger. From 5/16ths to 3/8ths.
The offending bolt:
First time I've ever tapped anything...scary...but...TADA!
It threads all the way in to the bottom of the cut I made with just my fingers, nice and smooth. I just made sure to take my time, every step forward I took, I took a step back, and just went slooooow.
I just need to bore out the hole in the housing so i can fit the new fatter bolt through it...and pick up a replacement for the other bolt...i dont trust those old ones anymore, haha.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread: Marns '73 Wagoneer Thread ----- The Camper Build Thread: Marns 1980 Jayco JayFinch6 Build Thread
Dr. Marneaus is offline   Reply With Quote Quick reply to this message
Unread 07-07-2010, 09:31 PM   #79
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
So, before I busted off that bolt, i took it shooting...
and installed a CB...
and installed some gauges (this is why I broke that damn T-stat bolt...temp guage)
-Andrew
Unread 07-07-2010, 10:09 PM   #80
Apex
Recon death squad
Apex's Avatar
Good job, you tapped it correctly if you kept backing it out to clean the threads...
Otherwise the shavings can muck up your fresh threads before you even get a bolt in there.
Unread 07-07-2010, 10:28 PM   #81
DaleII
Looks good Marn, glad to see you got it! Now you have to drill and tap the other side to match!
2005 Silver LJ
DaleII is offline   Reply With Quote Quick reply to this message
Unread 07-08-2010, 12:44 PM   #82
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
-Andrew
Unread 07-09-2010, 01:03 PM   #83
Hoobly_Goob
mmm
looks nice.
"You're out of your mind."
"That's between me and my mind."
Utah Jeep Crew
Hoobly_Goob is offline   Reply With Quote Quick reply to this message
Unread 07-09-2010, 03:00 PM   #84
2006_Sport
You got a nice CB in there, Marn. I have the same one in my Jeep. The PA function is fun
2006_Sport is offline   Reply With Quote Quick reply to this message
Unread 07-09-2010, 06:59 PM   #85
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
It lives!!!!!
Back to your regularly scheduled Build Thread.
Next step: Get it smogged (fingers crossed) and registered (this coming week)
-Andrew
Unread 07-09-2010, 07:03 PM   #86
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
It lives!!!!!
Good to hear... I think you had a typical Jeep moment... But we all knew you wouldnt get rid of it.
-Dave
My CJ7 Build Thread
AustinCJer is offline   Reply With Quote Quick reply to this message
Unread 07-11-2010, 01:41 PM   #87
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Update:
Been fiddling with the carb. It failed emissions badly, so I'm working on that and learning. Hooked up my PCV valve, turned down the idle, leaned out the mixture, blah blah blah.
There are so many little things this truck needs, weather stripping, window channels, door locks...that kinda stuff. All in good time I suppose. I've got a rattling or knocking sound coming from the motor though, so thats taking priority. She runs fine, and it seems to be a rather intermittent noise, so...hopefully I can figure it out.
Anyway, here are a few more pics:
Antenna
Installed a new Pro-Flow that my buddy had sitting in his garage (yes, its backwards)
And, picked up a crapy automotive multimeter for super cheap...it'll get the job done.
-Andrew
Unread 07-14-2010, 08:00 PM   #88
1jack5
looking good, keep it up! I love this build
1jack5 is offline   Reply With Quote Quick reply to this message
Unread 07-14-2010, 08:20 PM   #89
DaleII
You know Marn, you should just find some old geezers or old time guys that know carbs pretty well. Anyone that used to be a mechanic would be a good person to ask about a carb. I know my Dad was a diesel mechanic, but still knows his way around a carb a little bit. Ask them to help you out a little bit or show you some of the stuff. Learn how it works.
If you ever find yourself a couple hours down the I-15 let me know, and depending where you're at we can work something out.
2005 Silver LJ
Unread 07-14-2010, 09:17 PM   #90
Kenbo-Slice
Go to Barnes and Noble and buy a book on the carburetor thats in the Jeep. I did that for the Quadrajet on my truck.
Kenbo-Slice is offline   Reply With Quote Quick reply to this message
1973 , build up , dr. marneaus , grand wagoneer , jeep , wagoneer
