Marn's 73 Wagoneer Thread - Back in action! - Page 53 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Marn's 73 Wagoneer Thread - Back in action!
Unread 10-05-2011, 03:28 PM   #781
Dr. Marneaus
Station Wagoneer
Dr. Marneaus's Avatar
1973 FSJ Wagoneer
Originally Posted by spyder6 View Post
time for a fuel cell
No, time for the OEM tank with a correct fill/vent system.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread: Marns '73 Wagoneer Thread ----- The Camper Build Thread: Marns 1980 Jayco JayFinch6 Build Thread
Dr. Marneaus is offline   Reply With Quote Quick reply to this message
Unread 10-05-2011, 04:05 PM   #782
spyder6
Got that Toyota chit
spyder6's Avatar
2010
i like my idea better, its sexier.
My builds: Bruiser and The Grey
|Forge Overland| or follow us on Facebook
spyder6 is offline   Reply With Quote Quick reply to this message
Unread 10-05-2011, 06:47 PM   #783
robert_hollis
Marn, is your tank metal? I know the later 70's ones are plastic... No clue on when they switched.
Oh, and I posted that 78 Cherokee on CL, so I may not be parting it out afterall.
You read it. You can't unread it!
[URL="http://picasaweb.google.com/hollisr4/TJ?feat=directlink"]2006 TJ[/URL]
[URL="http://picasaweb.google.com/hollisr4/1979JeepCherokee?feat=directlink"]1979 SJ[/URL]
1978 Cherokee Chief - bought for parts, and sold as a runner
robert_hollis is offline   Reply With Quote Quick reply to this message
Unread 10-05-2011, 08:29 PM   #784
73pumpkin
1973 FSJ Wagoneer
You bought that carb on craigslist didn't you? Even though it looked as if it was new in the box. it could possibly have been tried on an old vehicle for a few dirty days and then boxed back up. The other suggestions are most likely correct, but stranger things have happened than a person sticking an item back into its packaging very carefully and claiming that it is new. Good luck.
73pumpkin is offline   Reply With Quote Quick reply to this message
Unread 10-06-2011, 03:21 PM   #785
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Anything is possible, but i sniffed around it and there was ZERO hint of gas, and it was clean as a whistle inside and out.
-Andrew
Unread 10-06-2011, 04:00 PM   #786
bigdhamYJ
That is an absolutely gorgeous Waggy. I am going to go dream about it now...
"Who knew coolant keeps the motor cool?"
Check out my Heep "build"
http://www.jeepforum.com/forum/f22/bigdhamyjs-1993-yj-build-slow-1284516/
bigdhamYJ is offline   Reply With Quote Quick reply to this message
Unread 10-07-2011, 03:19 AM   #787
shoeless
First, good looking truck. I like the simplicity of it vs. the 80's models that had enough vacuum line under the hood to circle the earth.
I ran a 1407 Edelbrock on my '63 Chevy C10. I used to run a Fram fuel filter, a G2 I think, right next to my carb because of the truck's rustastic fuel tank. I would keep a spare as the filters would just get clogged with rust.
Don't know if you got the manual for the carb with the box, but it has a troubleshooting guide in it (page 22 of the manual, 23 of the pdf)
Manual PDF link:
http://www.edelbrock.com/automotive_...ers_manual.pdf
Just FYI, not sure if you are still running that Pro Flow air cleaner setup, but if you are be aware that a backfire up through the carb will melt the foam element and it will drip down into the carb and cause issues.
'05 Rubicon Unlimited
shoeless is offline   Reply With Quote Quick reply to this message
Unread 10-07-2011, 02:26 PM   #788
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Manual PDF link:
Thanks for the tips, but I have removed the proflow a few months ago.
-Andrew
Unread 10-13-2011, 06:30 PM   #789
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Any news on the rusty tank?
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline   Reply With Quote Quick reply to this message
Unread 10-14-2011, 11:03 PM   #790
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
No. I just replaced the filters and cleared out the carb. It runs but I havent driven it around to see if it will flood or anything. No time or interest at thesis juncture. When it's broke it don't cost me anything
-Andrew
Unread 10-20-2011, 10:29 PM   #791
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Well, minor victories I suppose.
I came home today, and apparently was feeling frisky. I fired up the old girl, and let her warm up, then romped her around the block a few times, with zero issues. I got a few strange looks as everyone in the neighborhood who was outside saw 5000 pounds of jeep roaring by, but thats about it.
Pulled into the driveway and let her idle, nice and smooth, but did SMELL a bit funky. I'm going to attribute this to the craptastic gas I got in Ely.
I put a vacuum gauge on it while idling in park, and she was pulling a near perfectly STEADY 18" which is about perfect.
Seems to be healthy?
Last weekendd I picked up a cheap clear fuel filter and threw it inline, up by the gas tank.
And installed a new one up front by the 100% cleaned out carb.
Hopefully she'll keep on purrin, and shouldnt have any gas venting issues in the cooler weather.
-Andrew
Unread 10-20-2011, 11:39 PM   #792
2006_Sport
Good to hear man. Hopefully she'll stay trouble free for a bit.
2006_Sport is offline   Reply With Quote Quick reply to this message
Unread 10-20-2011, 11:53 PM   #793
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Not likely...she's a jeep after all!
I've been pouring all my money into guns lately.
-Andrew
Unread 10-21-2011, 08:12 AM   #794
MountainMan864
Throw $120 bucks for a 2in body lift and call it good. You know you want too.
MountainMan864 is offline   Reply With Quote Quick reply to this message
Unread 10-21-2011, 09:54 AM   #795
Brg0012
1983 CJ7
Man I love the wagoneer. I have always wanted one since I was a kid. I am going to be watching this build.
Brg0012 is offline   Reply With Quote Quick reply to this message
1973 , build up , dr. marneaus , grand wagoneer , jeep , wagoneer
