Marn's 73 Wagoneer Thread - Back in action! - Page 27 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Marn's 73 Wagoneer Thread - Back in action!
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 03-17-2011, 07:41 AM   #391
DINOCAVE
formerly CPT Jeep
DINOCAVE's Avatar
Love the thread. Love your Wagoneer. Quietly watching because I would love to restore/modernize one with a EFI engine and all the amenities of a modern SUV. Maybe one day. After the lottery.
DINOCAVE is offline   Reply With Quote Quick reply to this message
Unread 03-17-2011, 08:00 PM   #392
Dr. Marneaus
Station Wagoneer
Dr. Marneaus's Avatar
1973 FSJ Wagoneer
doesnt take the lottery, only takes about 15 grand to buy a mint 1991 Grand Wagoneer.
Leather heated/power seats, AC, good stereo system, overhead console, etc etc.
I updated my calculations on the amount I've poured into the Wagoneer the other day. I'm quickly approaching the point where I have put more into it than I paid for, hahah.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread: Marns '73 Wagoneer Thread ----- The Camper Build Thread: Marns 1980 Jayco JayFinch6 Build Thread
Dr. Marneaus is offline   Reply With Quote Quick reply to this message
Unread 03-19-2011, 12:28 PM   #393
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
And so it begins....by removing 4 bolts at the drive shaft.
-Andrew
Unread 03-19-2011, 02:21 PM   #394
gixxerphil
Marn,
Here's the photoshop of the pic I borrowed
Thought you might like it
m416 trailer build
TJ Tech BOOT CAMP
TJ SPECS
Originally Posted by elephantrider View Post
can you get a good pic of your muff set up ?
gixxerphil is offline   Reply With Quote Quick reply to this message
Unread 03-19-2011, 08:19 PM   #395
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
That's pretty slick! I actually like it alot more than I thought I would.
-Andrew
Unread 03-20-2011, 01:43 AM   #396
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
progress!
-Andrew
Unread 03-20-2011, 09:34 PM   #397
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Any work today?
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline   Reply With Quote Quick reply to this message
Unread 03-20-2011, 11:09 PM   #398
alexrule123
Done yet?
2001 Cherokee Limited: My Build Thread
2005 Pontiac GTO 6.0L (DD)
May 2013 COTM
alexrule123 is offline   Reply With Quote Quick reply to this message
Unread 03-21-2011, 12:39 AM   #399
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
bumped to next page.
-Andrew
Unread 03-21-2011, 12:39 AM   #400
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
bumped to next page again.
-Andrew
Unread 03-21-2011, 12:39 AM   #401
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Originally Posted by Grewe02 View Post
Any work today?
Yes! a crap ton, see the above post!
Originally Posted by alexrule123 View Post
Done yet?
No. Gimmie two more weeks!
-Andrew
Unread 03-21-2011, 12:44 AM   #402
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Phew!!!!
This was a hell of a weekend, I can now say, that THIS is by far the MOST work I have ever done to a vehicle in my life.
Summary:
Pulled transmission and transfer case.
Separated trans and transfer case.
Cleaned up the transfer case a lil.
Removed EVERYTHING from the motor and prepped it 100% for removal (radiator, all accessories, exhaust manifolds are all off)
Installed the new steering gear box.
Started out be getting under and pulling off all the cables and linkages for the tranny/transfer case. Not much soing on down there. Pulled the exhaust and drive shafts as well.
Then I pulled the transmission cross member, while supporting the transfer case.
crossmember has what looks like 38 years of oil and dirt all caked onto it. Gross. needs a good cleaning. That electric fuel pump will be coming off as well, it was used to prime the mechanical pump from the auxiliary tank I figure.
Finally got the tranny out.
lots of stuff had to come out first though.
Front pump seal is leaky, which is why inside the bell housing was wet all the time (the ATF on the ground is not from the front pump, I'm just saying)
Woke up on sunday and decided to work some more. Got the tranny and t-case separated.
These things are freakin gross. Tranny will be hot tanked, but i started to clean up the t-case a little. Just sprayed it with degreaser and scraped it and hosed it off. no major improvement, but atleast it isnt greasy and slippery now.
Stuff was nasty under there. This is the transmission mount bracket.
think it was time for a new transmission mount?
My transmission cooler has seen better days, so I figure I'll either replace it or eliminate it.
One trick to an engine removal....it gets way easier with the hood out of the way!
built in hood storage
-Andrew
Unread 03-21-2011, 12:45 AM   #403
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
removed the Power steering pump and bracket, and set it to the side on the fender. Also the radiator is removed in this pic.
found a wasp nest on the engine....
And wellllll, here's a pleasant surprise! Turns out my engine has a 4barrel intake manifold! I'm not sure if its factory, but I know 4bbls were an option in the mid to late 70's, so it could be. either way, bonus!Sadly, this means my carb wont mate with the new motor, so I have a few options here.
got the AC bracket off and set aside with the compressor.
Since i did so much disassembly, I figured i would do something constructive as well. Replaced the steering gear box. That thing was a bear. It bolts to a bracket that bolts to the frame. There is 1 bolt you cannot access on the bracket....so you have to unbolt the whole thing from the frame, then remove the gear box from the bracket. Pain in the butt to get the splines lined up on the steering column again too! So, anyway, i got it in and its all bolted down, just doesnt have the hoses connected yet. that'll come later.
then, finally, removed the exhaust manifolds. Figured the smaller/lighter the engine, the easier it will be to pull.
Yeah, doesnt look like too much work when written out, but it took me two days. So, its ready to be pulled!
I found some interesting stuff.
This massive crack on my bellhousing that has been welded. Weird. Could have been from a bad tranny mount at some point I'm told.
Also, discovered my intake manifold is actually a 4barrel, not running an adapter like I thought. This means my carb wont bolt onto the new engine, so I may just swap the intakes. Not sure yet, but leaning that direction.
At least I have some motivation and constant reminders to get this crap finished. This is what I see when I walk into the garage to get in my car. At least its staring me in the face every day!!!
-Andrew
Unread 03-21-2011, 12:47 AM   #404
hoppa2k6
love this thread. love the wagons....so I've been watching the thread for the past few months (as a non-member...lol). finally chiming in.
Just thought I'd say I really like that photochop gixxerphil did...love the classic woody wagon look currently, but the black photochop shot looks bad azz.
hoppa2k6 is offline   Reply With Quote Quick reply to this message
Unread 03-21-2011, 08:57 AM   #405
tj98
Great work, really enjoying the build (re-build?). Before the replacement engine goes in I can see you spending at least one weekend cleaning and detailing that engine bay.
98 TJ - Sold
99 TJ - Mine
10 JKU - Sold
14 JK Unlimited - Wife's
tj98 is offline   Reply With Quote Quick reply to this message
1973 , build up , dr. marneaus , grand wagoneer , jeep , wagoneer
