Marn's 73 Wagoneer Thread - Back in action! - Page 100 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Marn's 73 Wagoneer Thread - Back in action!
Zone Offroad Body and Suspension Lift Kits, Brackets, DiscJeep Wrangler Framless, Bowless, Trektops 92-95 YJ, 97-06 Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 05-02-2013, 02:31 PM   #1486
Sundowner
I'm cheap/poor/dont care, so, oem chevy parts it is.
Use whatever works, says me.
If it's worth doing, then it's worth [I]over[/I]doing.
The build, the gear, and the mileage: [URL="http://www.jeepforum.com/forum/f22/wasteland-survival-guide-engineering-greta-1344782/"][B]The Wasteland Survival Guide[/B][/URL]
Sundowner is offline   Reply With Quote Quick reply to this message
Unread 05-02-2013, 02:42 PM   #1487
Dr. Marneaus
Station Wagoneer
Dr. Marneaus's Avatar
1973 FSJ Wagoneer
the chevy parts will work because they are exactly the same in every aspect other than the fact that they are about 3" longer, which is desirable. also, they arent in some catalog under "jeep" so they cost about 1/3rd as much.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread: Marns '73 Wagoneer Thread ----- The Camper Build Thread: Marns 1980 Jayco JayFinch6 Build Thread
Dr. Marneaus is offline   Reply With Quote Quick reply to this message
Unread 05-05-2013, 02:40 PM   #1488
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
might as well do something cheap and "fun" in the midst of all this seriously negative crap.
Now i can yell at people when i'm driving.
-Andrew
Unread 05-05-2013, 05:43 PM   #1489
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Nice. Train horns next?
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is online now   Reply With Quote Quick reply to this message
Unread 05-05-2013, 05:56 PM   #1490
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Old steering:
It was so mucked up I couldn't get the sleeves to budge even with a 2' pipe wrench.
Got new sleeves.
All done. Ready to go under the jeep.
-Andrew
Unread 05-05-2013, 06:18 PM   #1491
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
before:
After:
-Andrew
Unread 05-06-2013, 07:55 PM   #1492
robert_hollis
Hah, I did the same thing with my truck in HS.... great stress relief in walmart parking lots...
Now i can yell at people when I'm driving.
You read it. You can't unread it!
[URL="http://picasaweb.google.com/hollisr4/TJ?feat=directlink"]2006 TJ[/URL]
[URL="http://picasaweb.google.com/hollisr4/1979JeepCherokee?feat=directlink"]1979 SJ[/URL]
1978 Cherokee Chief - bought for parts, and sold as a runner
robert_hollis is offline   Reply With Quote Quick reply to this message
Unread 05-06-2013, 09:15 PM   #1493
balzer
Great looking axle all shiney and black parts.
I am trying to buy an old 2 door cherokee wide track with the 258 and a 4 speed.........
2001 TJ SE
1971 J4800 gladiator
balzer is offline   Reply With Quote Quick reply to this message
Unread 05-12-2013, 01:03 PM   #1494
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Sent from AutoGuide.com Free App
-Andrew
Unread 05-13-2013, 12:34 PM   #1495
tofuzeppelin
tofuzeppelin's Avatar
That looks better and nicer than any factory pics I have found yet man. Granted their photos are in lower quality but that is not lost when looking at an iconic piece of American history that is NOT hacked up n jacked up.
Just be glad you're not up in the rust belt, you would have given up the ghost after first getting into it.
01 TJ with some stuff
77 SJ Cruzer
Lifes to short for bad coffee and bald tires
tofuzeppelin is offline   Reply With Quote Quick reply to this message
Unread 05-13-2013, 03:04 PM   #1496
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
-Andrew
Unread 05-13-2013, 10:41 PM   #1497
06_footy
1977 J-Series Truck
Dude every time I see your updates. I think to myself "I love this guys jeep".
06_footy is offline   Reply With Quote Quick reply to this message
Unread 05-17-2013, 01:19 AM   #1498
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
So, last night this happened.
I inadvertently removed a blob of rubbery gasket material (with a jack stand) that was apparently sealing up an existing hole from a previous owner.
Great, these tanks are not available, and the poly tanks are not a "direct" fit, they require quite a bit of effort to get em to work.
-Andrew
Unread 05-17-2013, 01:19 AM   #1499
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Well, internets, what do we do?
Do I adhere to the "oh noes! your tank is teh old! It must have teh rusts and holeses!"
Or do we go with EVIDENCE?!
Okay, this took 18 minutes (yes, i timed myself)
Once it was on the ground i did a lil inspection.
OH MY GOD!!!!!!!!!!!!! THE HUMANITY! THERE IS RUST EVERYWHERE!
KILL IT WITH FIRE!!!!!!!!!!!!!
Okay but seriously, there was rust. (the chunks you see are remnants of an old fuel sock that is down in the bottom there, i didn't have any tweezers long enough to get it out)
Man, thats bad. How it stays held together in the parking lot is a wonder, forget about on the trails!
Alright, so about an hour and 3 cans of brake cleaner later(who needs beer when you're huffin' that stuff all night), we have a mostly clean tank.
I pumped it full of water to rinse it out, it's getting dropped at a friend's mechanic, who is a freelance type guy. He said he's repaired many a tank, and will clean it up and fix the 2 leaks (the crack and the broken weld at the vent tube) for me for 2 hours labor, at the "friends and family" rate.
So, i should have a repaired tank by Friday night. I'm dropping it off in the AM.
Then it'll take 18 minutes to bolt back up once my new sending unit arrives.
-Andrew
Unread 05-17-2013, 01:35 AM   #1500
robert_hollis
Yea tank woes!
Keep at it, man.
1973 , build up , dr. marneaus , grand wagoneer , jeep , wagoneer
