Marn's 73 Wagoneer Thread - Page 96 - JeepForum.com
 9Likes
post #1426 of 1761 Old 03-08-2013, 09:57 AM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Makes it worse? How? I must not be following you correctly... You said your pumpkin sits a few inches off to the side, correct? So move your transmission mount an inch in the same direction. That is most definitely not making it worse.
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #1427 of 1761 Old 03-08-2013, 12:12 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
U joint angles need to be parallel. Google image search 'u joint angle' and you will see that your solution is incorrect
By simply cocking the back of the engine to the right you are creating a different u joint angle at the t case than at the axle pinion, thus, incorrect driveline angles.
If I were to pick up my entire engine and move it all to the right that's a different story
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #1428 of 1761 Old 03-09-2013, 12:38 AM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Ok well it may not fix the problem, but it won't hurt I'm sure
Andy, KD8EIA
Grewe02 is offline
post #1429 of 1761 Old 03-09-2013, 06:28 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Out with the old
next to the slightly less old:
Seems Legit.....
But as of right now:
My brake lines are a total mess (need replaced) and I have no shocks, and the e-brake lines on this axle are cut do i need to address that when I do new shoes and drums and hardware.
My exhaust is held in place off to the side with a wire hanger
My front drive shaft is unbolted and held in place with a wire hanger and duct tape (and no i still dont have an inspection cover on my torque converter)
But, it seems to ride and drive fine. Had it up to about 50 in the neighborhood, havent dared to take it on the highway with those rotted 31's and no shocks. But, no weird vibes or anything, so, hopefully upwards of 60 MPH it drives the same.
Phew, i'm beat.
-Andrew
Marn is offline
post #1430 of 1761 Old 03-11-2013, 12:02 AM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Okay, here's how everything looks under the truck.
So, i had to move my muffler over slightly, it was just barely touching the drive shaft before.
-Andrew
Marn is offline
post #1431 of 1761 Old 03-11-2013, 01:05 AM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Looks not so bad
Andy, KD8EIA
Grewe02 is offline
post #1432 of 1761 Old 03-11-2013, 04:22 PM
robert_hollis
I think you addressed this, but I've forgotten. Do you plan to eventually go with a disc brake upgrade for the new rearend?
You read it. You can't unread it!
1978 Cherokee Chief - bought for parts, and sold as a runner
robert_hollis is offline
post #1433 of 1761 Old 03-11-2013, 04:32 PM
1MoparMan
Very Nice!
In the Market for a YJ again!
Past rides: 1990 YJ 2.5, 2005 GC 5.7, 2006 Rubicon, 88 Corvete C4
Current rides: 2003 Ram 2500 4x4 CTD, not so stock. 2009 Ford Focus SES (wife's)
1MoparMan is offline
post #1434 of 1761 Old 03-11-2013, 05:16 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Originally Posted by Grewe02 View Post
Looks not so bad
thats sort of what i figured
No, i do not.
-Andrew
Marn is offline
post #1435 of 1761 Old 03-13-2013, 05:05 PM
MountainMan864
Damn your **** is crooked.
MountainMan864 is offline
post #1436 of 1761 Old 03-13-2013, 09:01 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
painted two rims tonight, these are going to look NIIIIICE with the dig dishes.
speaking of dog dishes...i have a plethora...
-Andrew
Marn is offline
post #1437 of 1761 Old 03-14-2013, 01:29 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
How many coats did you use on the rims? And what kind of rattle can?
Andy, KD8EIA
Grewe02 is offline
post #1438 of 1761 Old 03-14-2013, 01:48 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
38 coats, krylon fusion.
No, its 2 coats, and i didnt prime because I wanted to shoot white over white, and there was no rust or anything.
Its duplicolor wheel paint. I've had great luck with it in the past. Being white, it'll be super easy to touch up as well. pull the wheel and shoot another coat, done.
I just sanded down and removed any discoloration, leveled any chips, then whiped the wheels down with Prep-all, and painted away.
on my magnum the wheels had some weird clear coat from the factory that I couldnt remove, so I used self etching primer, then dupilcolor regular car paint, then duplicolor wheel clear coat. Held up perfect for a good 2 years. I had 1 or 2 nicks from like hitting it with a tire iron or something, but other than that, it was great.
-Andrew
Marn is offline
post #1439 of 1761 Old 03-14-2013, 09:50 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Before (black steelies were 'aite' but didnt really do it justice)
After:
SA-WEET!
So, with all this axle stuff I stuck the rear in to test it out, and I had to get my good tires swapped over for a full speed road test. I figured Ii'd refurb the rims before putting the tires on.
I've always loved the vintage look, I know these arent correct to the year of my wag, but I prefer them over the full hub caps.
Sorry if i'm tootin' my own horn, but they came out great! I am not sure if i will redo the paint on the dog dishes.
-Andrew
Marn is offline
post #1440 of 1761 Old 03-15-2013, 08:57 AM
MountainMan864
Def. a 70's look not a modern look by any means lol.
1973 , build up , dr. marneaus , grand wagoneer , jeep , wagoneer
73 Wagoneer JYDToo Jeep Builds 9 06-15-2010 07:27 PM
84' Wagoneer (XJ) TheBrute Jeep Builds 4 05-01-2010 09:14 AM
My 89 Wagoneer SCFishinGuy Jeep Builds 1 01-28-2007 05:06 PM
1987 Wagoneer mopar_man Jeep Builds 3 05-29-2002 10:53 AM
My '86 Wagoneer CHVYPWR Jeep Builds 2 08-02-2001 04:20 AM
