Marn's 73 Wagoneer Thread - Page 95 - JeepForum.com
 16Likes
post #1411 of 1819 Old 02-27-2013, 07:44 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Those are going to look so "right" on the waggy.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #1412 of 1819 Old 02-27-2013, 10:15 AM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
I agree. :-)
Also got the front end up on stands so its ready to be worked on
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #1413 of 1819 Old 02-27-2013, 06:12 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
What front axle do you have installed now?
16 Taco
dayriesw is offline
post #1414 of 1819 Old 02-27-2013, 07:42 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
this is on hold, I dont think the rear axle is going to work. Long story. I'm an idiot.
-Andrew
Marn is offline
post #1415 of 1819 Old 02-27-2013, 08:28 PM
MountainMan864
Info on why please.
MountainMan864 is offline
post #1416 of 1819 Old 02-27-2013, 09:01 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Originally Posted by MountainMan864
Info on why please.
Narrow track and wide track quadra-trac axles are different. The NT have more offset than the WT. I have an NT set and I'm currently running a centered transfer case.
My current axle is offset 3.5" to clear the gas tank. The new axle is offset 6.5".
From what I'm being told, this is too much and will cause driveline vibes and issues.
-Andrew
Marn is offline
post #1417 of 1819 Old 02-28-2013, 01:01 AM
XJAbuzer
I agree. :-)
Attachment 574196
Are you going to paint the wheels tan to match the body or are you going with white. Personally, I think tan would be best.
1979 CJ-5 304 V-8, T-150 3 speed, Dana 20, Dana 30 front, AMC 20 rear, Sold
Anyways, I wanna go wheelin'!
XJAbuzer is offline
post #1418 of 1819 Old 02-28-2013, 06:54 AM
MountainMan864
Ouch. Betcha wont make that mistake again. Well try and sell em and make a buck.
post #1419 of 1819 Old 02-28-2013, 12:48 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
i'm going to throw the offset axle under the truck and see how it rides, before i put a penny into it or the front.
back up plan may involve swapping to small bearing spindles, and ford hubs/rotors in the front, then regearing my current D44, as nothing is being gained by swapping my rear axle, the only reason for swapping the rear is to keep the gears the same.
-Andrew
Marn is offline
post #1420 of 1819 Old 02-28-2013, 04:41 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
PMd.
16 Taco
dayriesw is offline
post #1421 of 1819 Old 02-28-2013, 05:31 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Originally Posted by dayriesw View Post
PMd.
Uh, my axles are not for sale.
-Andrew
Marn is offline
post #1422 of 1819 Old 03-07-2013, 05:20 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
So, I'm going to toss the rear axle under my truck this weekend, and see how it drives, if there are turrible vibes, etc. Then i will either scrap the project or proceed forward with the swap as originally planned. Fingers crossed.
picked up new wheel cylinders, and got one side done before it got dark yesterday. I just need to get these on before i can do the swap so everything runs right. Also picked up a new brake hose and u joints for the drive shaft.
I hate drum brakes.
But look, here I am using the correct tool to avoid getting 16 stitches like last time.
-Andrew
Marn is offline
post #1423 of 1819 Old 03-07-2013, 09:34 PM
robert_hollis
My Cherokee is running a centered D20 with a lift, and can manage 70 without wild vibes... I think, as long as your gas tank is cleared, you'll be fine. But that's just a guess...
You read it. You can't unread it!
1978 Cherokee Chief - bought for parts, and sold as a runner
robert_hollis is offline
post #1424 of 1819 Old 03-08-2013, 08:39 AM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
I still don't know why you can't move your transmission mount off to the side by an inch
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #1425 of 1819 Old 03-08-2013, 08:51 AM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Because that creates an even worse driveline angle. U joint angles need to be parallel. Do some research man!
-Andrew
Marn is offline
1973 , build up , dr. marneaus , grand wagoneer , jeep , wagoneer
73 Wagoneer JYDToo Jeep Builds 9 06-15-2010 06:27 PM
84' Wagoneer (XJ) TheBrute Jeep Builds 4 05-01-2010 08:14 AM
My 89 Wagoneer SCFishinGuy Jeep Builds 1 01-28-2007 04:06 PM
1987 Wagoneer mopar_man Jeep Builds 3 05-29-2002 09:53 AM
My '86 Wagoneer CHVYPWR Jeep Builds 2 08-02-2001 03:20 AM
