Marn's 73 Wagoneer Thread - Page 66 - JeepForum.com
 13Likes
post #976 of 1807 Old 01-17-2012, 03:53 PM
robert_hollis
Trust me, it'll be a vast improvement.
Maybe not so much on modern rigs where everything is wired correctly, but even now I'm still used to driving with my horrible old wiring system (the headlight switch would get burning hot, i could smell it if the lights were on for more than 15 minutes).
I wired in some relays to take the load off the switch and get the power alot closer to the headlights and that alone made a big difference. I'm sure adding the H4's will be wayyyyy better than the original 7" sealed beams before i did the relays.
Also, the cost was hardly anything. I paid 40 bucks shipped for the bulbs and housings. it's all plug and play seeing as i did the relays.
Lemme know how that turns out. I may do the same thing when I finally get around to putting round headlights in my rig...
You read it. You can't unread it!
1978 Cherokee Chief - bought for parts, and sold as a runner
robert_hollis is offline
post #977 of 1807 Old 01-17-2012, 03:59 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Nope, i'm not gonna tell you.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #978 of 1807 Old 01-17-2012, 04:21 PM
MountainMan864
I'm going with a 1" Body lift.
Well good luck to ya but more lift=better and us dodge people with ramchargers put 2'' body lift on and its not that big of a deal. Look into Borgeson steering shafts they might make a kit for your FSJ. Plus you could probably fit some 35'' KM2s since they run small.
MountainMan864 is offline
post #979 of 1807 Old 01-17-2012, 04:36 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Not in my world. I dont want more lift, i just want my tires to fit.
I also dont want to install something new or modify my steering, i'd rather rub.
-Andrew
Marn is offline
post #980 of 1807 Old 01-17-2012, 04:57 PM
LilSteve97TJ
I like this build a lot. My dad had 2 wagoneers while i was growing up, i'd love to get another and slowly restore it like you've done.
97 TJ
98 Taco
LilSteve97TJ is offline
post #981 of 1807 Old 01-18-2012, 02:21 AM
robert_hollis
You leave me no alternative, but to send my attack cat after you... If he doesn't purr you to death, then he will claw your stomach to ribbons as you try to pet him!
post #982 of 1807 Old 01-18-2012, 09:42 AM
treyladut
waggy
i have a 77 waggy that i am thinking about buying a 91 or 92 grand waggy for body parts.do yall know if body parts interchange like the doors and fenders thanks
treyladut is offline
post #983 of 1807 Old 01-18-2012, 11:54 AM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
They should fit but i think the latches and whatnot will not match and will have to be interchanged on the doors.
other body panels should fit just fine.
-Andrew
Marn is offline
post #984 of 1807 Old 01-18-2012, 02:38 PM
robert_hollis
There are a few threads about that topic over on IFSJA.org
The front floor pan is slightly different. The latches on the doors and tailgate are different. The wiring, trans, tcase, axles are all different. the front valence is somewhat different. the taillights are different, so the rear is slightly different for the mounting. The side markers are different, but that shouldn't affect the body. Pretty much everything will swap with some modification, though.
post #985 of 1807 Old 01-18-2012, 03:44 PM
treyladut
Waggy
I really just need the doors off of it.I would have to make custom hinges to fit it?I have one door on my waggy rusted on the back drivers side.and he is selling it for just parts.this is my first time with a waggy I had a yj and tj before.would it be a pain in the butt to swap doors.
post #986 of 1807 Old 01-18-2012, 03:53 PM
treyladut
I sorry for being a pain with the ? About the waggy.my wife is not to happy with me going to bring another one home.
post #987 of 1807 Old 01-18-2012, 04:03 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
No worries about asking questions, i'm glad to help where i can but im not sure about fitting the parts and the hinges. go join up over on IFSJA.org. they have a lot more technical info over there. I stick around here for the crowd and i keep my build thread on this website vs. ifsja.
-Andrew
Marn is offline
post #988 of 1807 Old 01-18-2012, 04:12 PM
robert_hollis
I am not 100% certain on this, but I believe the hinges will work. It's the latches that may well be different. I know Jeep changed the latch design once or twice, but I cannot tell you what years.
post #989 of 1807 Old 01-18-2012, 04:26 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Got a line on another set of reverse lenses (so they match) and also got 2 matching window cranks to install. One of mine the knob is no longer chrome and another one has no knob.
Also apparently the correct gas cap connector for my new filler neck is being forwarded on to me so thats cool! I shouldnt have to use the plumbers special.
Waiting on a shipping quote as well for a 78 gas tank skid.
Robert, do you have a gas tank skid?
-Andrew
Marn is offline
post #990 of 1807 Old 01-18-2012, 04:45 PM
robert_hollis
I only have the factory one. You can see it in the many pics on my picasa page. I keep saying (to myself) I'm gonna move my tank up, and fab up a nice heavy duty skid, but that may never happen.
1973 , build up , dr. marneaus , grand wagoneer , jeep , wagoneer
73 Wagoneer JYDToo Jeep Builds 9 06-15-2010 06:27 PM
84' Wagoneer (XJ) TheBrute Jeep Builds 4 05-01-2010 08:14 AM
My 89 Wagoneer SCFishinGuy Jeep Builds 1 01-28-2007 04:06 PM
1987 Wagoneer mopar_man Jeep Builds 3 05-29-2002 09:53 AM
My '86 Wagoneer CHVYPWR Jeep Builds 2 08-02-2001 03:20 AM
