Marn's 73 Wagoneer Thread - Page 49 - JeepForum.com
 16Likes
post #721 of 1819 Old 08-20-2011, 10:37 AM
MountainMan864
Well if you have to buy a new carb time to upgrade.
MountainMan864 is offline
post #722 of 1819 Old 08-20-2011, 07:05 PM
robert_hollis
Its in Sparks, but still, they must have put it on a truck that night. thats service!
Ah k. Close enough for gubment work...
That sucks about the carb. I've had similar experiences with motorcycle carbs before, and I alway just ended up tossing the carbs in the parts washer for a week or so.
So far I've been lucky in only destroying two motorcycle carbs when stuff got stuck.
You read it. You can't unread it!
1978 Cherokee Chief - bought for parts, and sold as a runner
robert_hollis is offline
post #723 of 1819 Old 08-21-2011, 02:16 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Damn Marn. Maybe it's a sign.... someone up there is telling you to go with fuel injection!
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #724 of 1819 Old 08-21-2011, 05:02 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Someone up there is telling me all these fools on craigslist dont answer their damn emails.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #725 of 1819 Old 08-21-2011, 05:45 PM
austinaubinoe
Hey dude are you have trouble getting on the IFSJA site? I think my college blocked it somehow Worked fine 2 days ago.
austinaubinoe is offline
post #726 of 1819 Old 08-21-2011, 06:49 PM
robert_hollis
I've been off and on it all day. Works fine.
post #727 of 1819 Old 08-22-2011, 01:36 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Nah, works like a charm for me!
-Andrew
Marn is offline
post #728 of 1819 Old 08-23-2011, 09:03 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
K, got the new carb into the truck, tirned the key to fill the bowls, backed off. touched the key once and it fired up instantly, and idled awesome, barely had to adjust anything to get it to purr like a kitten.
Also threw on a 1" spacer.
Call me mr. edelbrock...I found a brand new one cheap on CL, so am returning the one that arrived today from summit..
For those of you who missed it, I was rebuilding my old carb, but the shop before me over tightened and stripped one of the primary jets, so i tried getting it out, it got more stuck, then i tried an easy out, and it broke, then tried drilling it and that damaged the body.
Anyway, it sucks, i looked forward to cleaning up my carb for cheap, but i guess this will be for the better, this thing should be perfect for a while. PLUS i have a crap load of edelbrock parts now that should interchange between the two (screws, linkages, floats, pretty much everything but venturies and jets/rods) I'm pretty sure I'll have to change the jets and rods though to get it to pass emissions, but we will see how it tests.
The old carb was a mess. When i took it off, the gasket was all wet in a few places, not sure why or how that happened, it didnt spill when i picked it up. Perhaps it was leaking.
Anyway...the old carb definitely needed some attention:
Here's the gas that poured out of the carb (i verified that CLEAN gas was going in. I guess it was pretty narsty in there.
Anyway, the new one is in and running, just gotta see how the overall truck is running and what the emissions test results are.
-Andrew
Marn is offline
post #729 of 1819 Old 08-23-2011, 09:46 PM
robert_hollis
So shiny, it hurts my eyes!
post #730 of 1819 Old 08-23-2011, 09:54 PM
JC_Sahara
Such a sweet build!!! Cant wait to see more!
My Build Thread:
JC_Sahara is offline
post #731 of 1819 Old 08-23-2011, 11:15 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Right? No worries, it'll be all dirty and dusty before long.
Thanks!
-Andrew
Marn is offline
post #732 of 1819 Old 08-24-2011, 01:07 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Marn is this the same model carb you had before?
Andy, KD8EIA
Grewe02 is offline
post #733 of 1819 Old 08-24-2011, 04:00 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Yes and no. I had a 1403 performer. Now i have a 1406 performer. The 1403 is 500cfm, the 1406 is 600cfm. But yes, they are both Edelbrock performers.
I was thinking about going holley, but i know nothing about them as far as adjustments and tuning. I would have loved a truck avenger, but i didnt have $400 + shipping and tax for one. I barely had the $300 for the carb i ordered...
Which is why i'm thankful I found this brand new in box unit for $190 cash. I'll be returning the other one that i ordered.
-Andrew
Marn is offline
post #734 of 1819 Old 08-24-2011, 07:44 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Okay, I'm PSYCHED!
The whole point of trying to rebuild my old carb was to get closer to passing emissions. Yes, 1973's still have to smog here in clark county, NV.
Well, my Edelbrock 1403 (500cfm, which was jetted lean two stages btw) was damaged and i couldn't rebuild it, so i picked up a new 1406.
Threw it on the truck yesterday, drove it over to the emissions place today. Sadly they got rid of their "no pass no pay" rule...so i had to cough up the dough.
Anyway. PREVIOUS test failures (this was with only about 10 minutes of driving from a cold start)
Idle Speed CO: 7.53% (3.5% limit)
High Speed CO: 6.10% (3.5% Limit)
Idle Speed HC: 944ppm (700 ppm limit)
Then backed off timing 2*, put in new plugs, new cap and rotor, ran a bottle of Heet, and got it nice and hot before testing
failures:
idle speed CO 6.85%
High Speed CO 5.66%
Idle Speed HC 1138ppm (woah! got worse!)
Finally replaced the carb, switched over to timed vacuum advance, ran a bottle of Heet, and didnt do anything to get it hotter than normal.
Failures:
Idle speed CO 5.72%
SOOOOOO, all that is failing is my idle CO, which means I'm too rich at idle, which SHOULD be able to be adjusted with the idle mixture screws, correct? Can i bring it down enough like that, or do i need to mess with timing as well? It's adjusted for best vacuum right now, and idles smooth, but if i turn the screws in any further it starts to bog down. I understand that running for emissions and running for best idle is not the same, but will leaning it with the idle mixture screws until it runs like crapola get it to the point where it will pass?
Or does leaning it out too much cause missing, thus causing me to fail emissions due to HC? If it will cause it to miss, can this be remedied by retarding my timing even more, past 10*?
Just looking for some tips, I'd rather take it there and fiddle with it than drop it off at my mechanic for a day and pay them 85 bucks an hour just to turn some knobs on my carb.
That being said, pretty crazy that a 360 with NO emissions equipment (other than a cat) is that close to passing.
-Andrew
Marn is offline
post #735 of 1819 Old 08-26-2011, 06:32 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Annnnnnndddddd......
Smogged. Registration comes tomorrah!
-Andrew
Marn is offline
1973 , build up , dr. marneaus , grand wagoneer , jeep , wagoneer
73 Wagoneer JYDToo Jeep Builds 9 06-15-2010 06:27 PM
84' Wagoneer (XJ) TheBrute Jeep Builds 4 05-01-2010 08:14 AM
My 89 Wagoneer SCFishinGuy Jeep Builds 1 01-28-2007 04:06 PM
1987 Wagoneer mopar_man Jeep Builds 3 05-29-2002 09:53 AM
My '86 Wagoneer CHVYPWR Jeep Builds 2 08-02-2001 03:20 AM
