Marn's 73 Wagoneer Thread - Page 38 - JeepForum.com
 16Likes
post #556 of 1819 Old 05-10-2011, 09:50 AM
Louie4
Looks great to me. I think mild body lifts are always good. The ones that replace the old worn mounts and add a little height, not the hard plastic pucks.
The stabilizer bushing is key. The nut stripped off mine and every time I started out in first gear the shifter would shake really bad, to the point that it hit that bone on the outside of my wrist and it hurt like no other.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #557 of 1819 Old 05-10-2011, 09:55 AM
MountainMan864
Heck yeah slap a 2'' body lift doesnt even cost a bill. Make them replace that bushing.
MountainMan864 is offline
post #558 of 1819 Old 05-10-2011, 11:23 AM
robert_hollis
My 79 Cherokee had a 3" BL on it when I got it. I'm not a BL fan, but yeah, you can't tell it's there unless you actually look for it. I'm leaving it on until I finally have the spare cash to replace my current setup with a 6" spring lift from BJ's Offroad.
You read it. You can't unread it!
1978 Cherokee Chief - bought for parts, and sold as a runner
robert_hollis is offline
post #559 of 1819 Old 05-10-2011, 11:46 AM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
kick *** chero, by the way!
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #560 of 1819 Old 05-10-2011, 11:47 AM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
So, I called the shop and this is what the guy who did all the work said
"The bushing? Oh yeah, I found that the other day! When I put it back together, I couldnt remember if there was a bushing there. I THOUGHT there was, but I couldn't find it. I found it, so just come on down and I'll put it back on for you"
Hey, thanks....WERE YOU GONNA TELL ME!?! Or just wait until I screwed up my drive line or cracked my bell housing and made you replace the whole transmission?
-Andrew
Marn is offline
post #561 of 1819 Old 05-10-2011, 11:59 AM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Also, I correctly hooked up my fuel venting system.
I was having problems because the PO removed the whole system, when they removed the stock gas tank.
my aux tank was a closed system with no vent, so the gas cap was vented. I was having issues with the tank bloating, and tons of vapor escaping from the gas cap, and thus dripping dirty gas down the side of the truck in the 95* weather.
I ghetto rigged it, but i think it works. It hasnt been as hot, but we'll see how it performs when it heats up again. Just put the two vent lines into the breather tube, so the vapor will rise and have a way to escape, as well as being sucked away by the carb when the engine is running.
-Andrew
Marn is offline
post #562 of 1819 Old 05-10-2011, 12:00 PM
robert_hollis
Yeah, I don't think I'd be going back to that guy.
post #563 of 1819 Old 05-10-2011, 12:15 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
The owner was the good guy, real knowledgeable, but he didnt do the work.
So I got it home the first day, parked it, walked into the house, walked back out for something and was like "wtf is that?!"
Turns out one of the cooler lines from the tranny was hanging down and resting on the drag link....it was so low it was hanging on my steering. They said "sorry bring it back real quick"
The guy was under it for a minute, I figured he'd bend it and adjust the fitting at the transmission to re-align it. He fixed it and i drove home.
There are about 6 or 8 zip ties holding the lower line to the upper line.....
-Andrew
Marn is offline
post #564 of 1819 Old 05-10-2011, 12:18 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Also, looking at your cherokee just gave me an idea.
The back of my rig is kinda trashed, the rubber floor matt is all ripped up, the side panels arent in very good shape (ripped vinyl, etc). I wanted to herculine at least the back of the truck, but this would be a problem clashing with the vinyl panels...
I saw your truck looks to have some wooden side panels in the back, with speakers in them.
Good idea! Just cut some thin plywood to shape, screw it in, and herculine right over the wood. I could also add some speakers VERY easily back there....It's no fun having 1 speaker in the center of my dash, haha.
-Andrew
Marn is offline
post #565 of 1819 Old 05-10-2011, 01:01 PM
robert_hollis
Those were the factory plywood panels in mine. I'm planning on replacing them with 16g metal, and monstalining the entire inside. I just haven't done it yet, due to laziness. Also, I am considering mounting some slim 8" marine subs in those panels when I do that.
post #566 of 1819 Old 05-10-2011, 01:43 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
"stock plywood" haha
Kinda like the "stock duct tape wire splices" in mine....man, AMC was way ahead of their time.
-Andrew
Marn is offline
post #567 of 1819 Old 05-10-2011, 04:23 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Drives a bit better now :-)
But, the fool stripped the stud for the torque arm, and my transmiossion mount is a lil messed up looking (squished and out of place)...
i'll handle it myself, ordered new ones.
-Andrew
Marn is offline
post #568 of 1819 Old 05-10-2011, 11:16 PM
jeepdog5
jeepdog5's Avatar
sweet GW! keep up the good work.
jeepdog5 is offline
post #569 of 1819 Old 05-11-2011, 06:51 AM
tj98
Great to hear it's back on the road!
98 TJ - Sold
99 TJ - Mine
10 JKU - Sold
14 JK Unlimited - Wife's
tj98 is offline
post #570 of 1819 Old 05-11-2011, 11:56 AM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
vibes are still there, still kinda crazy. it's going back to the shop.
-Andrew
Marn is offline
1973 , build up , dr. marneaus , grand wagoneer , jeep , wagoneer
73 Wagoneer JYDToo Jeep Builds 9 06-15-2010 06:27 PM
84' Wagoneer (XJ) TheBrute Jeep Builds 4 05-01-2010 08:14 AM
My 89 Wagoneer SCFishinGuy Jeep Builds 1 01-28-2007 04:06 PM
1987 Wagoneer mopar_man Jeep Builds 3 05-29-2002 09:53 AM
My '86 Wagoneer CHVYPWR Jeep Builds 2 08-02-2001 03:20 AM
