Marn's 73 Wagoneer Thread - Page 105 - JeepForum.com
 13Likes
post #1561 of 1805 Old 04-21-2014, 11:08 AM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Originally Posted by 73pumpkin View Post
Hi Marn, I have not been on this site for a long time. I have forgotten how to send you a personal note, so I thought I would post the question on this illustrious thread. I think that you put a set of remote gauges in your Wag at some point. Can you tell me where you connected your oil pressure tube and your water temp sensor? I found the electrical sensor connection for the oil pressure above and behind the oil filter and pump. Does this "bulb" thread out of the oil pump/ filter housing so that the adapter for the oil pressure tube can be threaded in? I noticed a cap on a long, cylindrical or tubular projection under the same housing. Could the new adaptor thread in there? My Chilton manual is not very descriptive about this. It looks as if the oil filter mount can be removed from the timing cover housing on these engines without interfering with the timing or interfering with the pump linkage. Is this true? it also looks as if the filter and pump are high enough on the engine to avoid draining all of the oil. If not, this is certainly no big deal. How about the water temp sensor? I noticed a couple of leftover sensors near the thermostat bulb housing - one actually stabbed in the back of it- from the long ago removed emissions components. These looked like good locations. What did you do?
My gas tank is leaking a tiny bit again. I suppose this is an ongoing issue with these old girls. I'll patch it up again. I have a new radiator on its way also. I plan on putting on an air lift suspension in the rear a little later when the bank account can stand it. The Pumpkin Farmer
how is your axle swap Stage Two going?
Hey man, glad to hear you're still working on the wag.
Yes, unscrew the electrical connector for the oil pressure. There should be a umber of fittings/adapters supplied with whatever gauge you buy that should fit right in.
For the temp sensor, there was a threaded bung in my t-stat housing if my memory serves, so i just installed it right there.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #1562 of 1805 Old 04-21-2014, 11:08 AM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
my unicorn arrived on Frisay, I will be picking it up tomorrow then dropping the shafts to have new bearings installed this week. maybe get it up under the truck this weekend.
-Andrew
Marn is offline
post #1563 of 1805 Old 04-21-2014, 07:01 PM
73pumpkin
1973 FSJ Wagoneer
Thanks for the info Marn. I work on it when I can afford it. I'll be interested to see how your axle swap goes.
73pumpkin is offline
post #1564 of 1805 Old 04-21-2014, 07:11 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
3rd axle is the charm right?
-Andrew
Marn is offline
post #1565 of 1805 Old 04-22-2014, 07:07 PM
73pumpkin
1973 FSJ Wagoneer
Hard to beat the stuff that is really made to fit. Married that skinny polish girl yet?
post #1566 of 1805 Old 04-23-2014, 01:38 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
No not yet.
-Andrew
Marn is offline
post #1567 of 1805 Old 04-24-2014, 12:13 AM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Got this as broke it down.
Then got new bearings pressed on the shafts today.
Then I took this thingy out
And put one of these thingies in it
Need to torque it down tomorrow and drop it back in, slide in the new shafts, and it'll be good to go.
-Andrew
Marn is offline
post #1568 of 1805 Old 04-24-2014, 06:19 AM
Sundowner
No not yet.
There's something indescribably awesome about Polish girls... and I would know because I married one.*
Also, nice axle!
*- Technically, she's half Polish. The other half is Hungarian. That's a Power Combo.
Sundowner is offline
post #1569 of 1805 Old 04-24-2014, 11:02 AM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Oh I see
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #1570 of 1805 Old 04-24-2014, 11:08 AM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Originally Posted by Grewe02
Oh I see
-Andrew
Marn is offline
post #1571 of 1805 Old 05-07-2014, 09:06 AM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Well I gave it a ride with the unicorn and it was much much better than with the offset axle but I was still getting vibes under similar conditions, but not as severe.
I measured my angles. T case yoke angles down 3*, pinion yoke angles up 10*
That is opposite but it sure as hell ain't equal! And definitely ain't equal when under load.
Turns out the shims that were installed long ago are 8*
Pulled those out and measured everything again, still about 3* down on the engine side (measured on starter, bell housing, and a flat spot of the T-case, all the same) and now the pinion is at about 2* up. Wayyyyyy better.
Took her for a ride and it's about 90% better. Had it up to almost 90mph and I can hear/feel some vibration but it's nowhere near what it was before. It's probable that what I am feeling is because of the new poly transmission mount.
I am satisfied.
-Andrew
Marn is offline
post #1572 of 1805 Old 05-07-2014, 09:17 AM
JoonHoss
2011 JK Wrangler
What, no money shot?
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is online now
post #1573 of 1805 Old 05-07-2014, 09:41 AM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Originally Posted by JoonHoss
What, no money shot? Hoss
Money shot of what?
-Andrew
Marn is offline
post #1574 of 1805 Old 05-07-2014, 10:11 AM
JoonHoss
2011 JK Wrangler
Of the jeep w/ the new diff, in place and finished off.
(i'll take just about any reason to look at your jeep)
Hoss
post #1575 of 1805 Old 05-07-2014, 10:46 AM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Hopefully welding up some shock mounts tonight
-Andrew
Marn is offline
1973 , build up , dr. marneaus , grand wagoneer , jeep , wagoneer
73 Wagoneer JYDToo Jeep Builds 9 06-15-2010 06:27 PM
84' Wagoneer (XJ) TheBrute Jeep Builds 4 05-01-2010 08:14 AM
My 89 Wagoneer SCFishinGuy Jeep Builds 1 01-28-2007 04:06 PM
1987 Wagoneer mopar_man Jeep Builds 3 05-29-2002 09:53 AM
My '86 Wagoneer CHVYPWR Jeep Builds 2 08-02-2001 03:20 AM
