MAGNUM FORCE, a Mopar man's build - Page 6 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > MAGNUM FORCE, a Mopar man's build
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 10-30-2012, 07:16 PM   #76
mhopton
Will that motor run regular or premium pump gas?
mhopton is offline   Reply With Quote Quick reply to this message
Unread 10-30-2012, 09:50 PM   #77
Copperhead89
It will easily run on 87 regular. As a matter of fact, we dyno'd it on 87.
My YJ/CJ V8 Magnum Build: http://jeepforum.com/forum/f22/magnum-force-mopar-mans-build-1412306/
Copperhead89 is offline   Reply With Quote Quick reply to this message
Unread 11-01-2012, 08:17 PM   #78
tonkatrucksryan
2014 JK Wrangler
Awesome build I wish I had the skills, talent, and $ to do this too
tonkatrucksryan is offline   Reply With Quote Quick reply to this message
Unread 11-04-2012, 03:33 PM   #79
Copperhead89
I sand blasted the power steering brackets and pulley, purchased a remanned PS pump, rattle canned some paint, and bolted it to the engine. I went to the Garlits Mopar show and swap yesterday, and bought alternator brackets. A new Denso 120 amp alternator is in route.
I still need to decide what color to paint the valve covers.
I painted and installed the steering box.
Unread 11-05-2012, 03:20 PM   #80
Limited-Edition
1979 CJ7
I was wondering what motor mounts you used on the motor side? Great build, I like the shock mount stiffeners!
Limited-Edition is offline   Reply With Quote Quick reply to this message
Unread 11-05-2012, 05:02 PM   #81
Copperhead89
I used engine mounts from a 1983 Chrysler Cordoba with a 318, but just about any 1975 and up Plymouth or Dodge 318 car mounts should be the same.
Unread 11-06-2012, 05:00 AM   #82
Limited-Edition
1979 CJ7
Cool thanks.
Unread 11-06-2012, 07:23 PM   #83
Copperhead89
Picked up these new V8 Magnum fender emblems on ebay.
Unread 11-06-2012, 07:24 PM   #84
Copperhead89
I painted the valve covers with Dupli-Color ceramic engine paint, in a color called Cast Coat Aluminum.
Unread 11-06-2012, 07:31 PM   #85
Copperhead89
Here is a pic showing the now shortened cast trans mount with the welded plate and the factory 1985 Dodge Ramcharger transmission isolators. I cut down the cast trans mount in order to get the driveline height and angle I wanted, and to make it short enough so I had room for the isolators.
The white PVC pipe is in place to simulate the front driveshaft. I'm going to fabricate a set of headers, so I need to know where the d-shaft is going to be, so I can make sure the pipes will not interfere with it during the range of suspension travel.
Unread 11-08-2012, 07:17 PM   #86
Copperhead89
The little stuff is important, too. Take for instance, power steering hoses. I held on to the original hoses from the 2.5L, in hopes that I might be able to re-use them. Once the steering box and pump were installed for the last time, it quickly became obvious that they weren't even close to being able to work, so I hacked up the high pressure hose to the point where it connected A to B, and looked and fit decent. I then took my hose mock-up over to Amazon Hose, where they made a hose to the same dimensions, bends and angles. It fits perfect. The low pressure return hose was easier, I just kept cutting until it fit nice.
Unread 11-10-2012, 10:43 PM   #87
Copperhead89
I liked the color on the valve covers so much, I decided to paint the intake manifold as well.
Unread 11-11-2012, 01:57 PM   #88
Bama_WJ
The engine is looking great!
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Trifecta tuned and 37+ MPG
Wife's Jeep: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers, 3" Gibson Cat-Back
North Alabama Jeep
42RE Vent Mod - Seal your transmission!
YouTube. - My Video Channel
Facebook - Wheeling Pictures/Videos
The Jeep Wave. Bringing it back.
Bama_WJ is offline   Reply With Quote Quick reply to this message
Unread 11-11-2012, 02:04 PM   #89
cavscout187
wow nice build super clean all that effort to paint it up just to cover with mud... i like it i wish i had the time and space to do this to my 5.9 wrangler
cavscout187 is offline   Reply With Quote Quick reply to this message
Unread 11-11-2012, 09:16 PM   #90
Kman1983
1983 CJ5
Very Nice! Subscribed. Any pics of how you did the SOA perches on the front Waggy 44?
Rolled Red Jeep Club Member #258
'83 CJ5, 4.0 MPFI swap, T18/D20, CenterForce II clutch, Dana44/30(73 CJ5) with 3.73's,'79 knuckles and 11" discs, sagged 4" lift, 2" BL, 34x9.50x15 Super Swamper Pizza Cutters
My wifes website The Vermont JeepGirl http://www.vermontjeepgirl.com/
"Good Girls and Dirty Jeeps" a song by Opal Justice http://www.youtube.com/watch?v=9xRtRE45OVQ
Kman1983 is offline   Reply With Quote Quick reply to this message
