MAGNUM FORCE, a Mopar man's build - Page 5 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > MAGNUM FORCE, a Mopar man's build
Get 5% Back On Rugged Ridge-Omix-ADA-Alloy at ExtremeTerraGibson Exhaust Rebate - ExtremeTerrain!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 10-19-2012, 08:38 PM   #61
yellow_snocone
Love the build I wish I could take on a build like this.
Military Jeepers
S.W. New Mexico region
[URL="http://www.jeepforum.com/forum/f22/chesters-tj-build-1420405/"][COLOR="Green"]Chester TJ build[/COLOR][/URL]
[URL="http://www.jeepforum.com/forum/f330/rubicon-trail-august-9th-11th-2014-a-1550022/"][COLOR="Blue"]2014 JF RUBICON TRIP[/COLOR][/URL]
yellow_snocone is offline   Reply With Quote Quick reply to this message
Unread 10-20-2012, 03:48 PM   #62
topalmer4
You should linex the frame and under the tub to perminately stop any and all corosion, now would be easyer than later.
[COLOR="Navy"][FONT="Arial Black"]Say Goodbye To your Bank Account, Say Hello To Your New Jeep :D[/FONT][/COLOR]
topalmer4 is offline   Reply With Quote Quick reply to this message
Unread 10-20-2012, 06:37 PM   #63
rusty762
rusty762's Avatar
Love the build man, never gets old seeing an old rust bucket go under the knife and come out better than new. Great work, subscribed.
Rusty
“If I had eight hours to chop down a tree, I’d spend six sharpening my axe.”- Abraham Lincoln
My Build
My Videos
My Work
Have you hugged a Firefighter today?
rusty762 is online now   Reply With Quote Quick reply to this message
Unread 10-21-2012, 10:28 AM   #64
Copperhead89
The frame was sandblasted, and then sprayed with 2 coats of epoxy primer, plus I coated the insides of the frame rails with Eastwood Internal Frame Coating, so this frame is good to go for another 30 years, at least. I'm going to epoxy prime and Monsta-Liner both sides of the tub floor, so that will be protected as well.
My YJ/CJ V8 Magnum Build: http://jeepforum.com/forum/f22/magnum-force-mopar-mans-build-1412306/
Copperhead89 is offline   Reply With Quote Quick reply to this message
Unread 10-21-2012, 08:58 PM   #65
Copperhead89
The stroker engine was dyno'd yesterday, and I'm happy to report that it survived with no parts flying through the oil pan. She made 367 hp and 407 ft. lbs. of torque. I'd say there will be a seat of the pants difference from the 2.5L 4 cylinder its replacing.
Here's a link to the dyno video. http://www.youtube.com/watch?v=JZuDj...ature=youtu.be
Unread 10-27-2012, 09:40 AM   #66
BRay
Sounds like a strong running 318. Did you use the 318 heads and what cam?
BRay is offline   Reply With Quote Quick reply to this message
Unread 10-28-2012, 08:26 PM   #67
Copperhead89
I used stock magnum truck heads. The only things done to them was bowl port them, correct any crappy factory machining,and swap in the appropriate valvesprings.
Here are the specs of the cam I used. Due to the higher 1.6 rocker ratio of the factory magnum heads, the actual valve lift on my engine is .517 for the intake and exhaust.
Unread 10-28-2012, 08:29 PM   #68
Copperhead89
This afternoon, we installed the engine and trans for the last time.
Unread 10-29-2012, 08:37 AM   #69
Jeepenjimmy440
hell ya you sound like me a mopar muscle guy, i had a 1970 dodge dart 340 car, ran the best of a 11.98. but all my friends are jeep guys so i got into it. nice build man im watching this for sure!!!!
Jeepenjimmy440 is offline   Reply With Quote Quick reply to this message
Unread 10-29-2012, 09:32 AM   #70
monsonman
monsonman's Avatar
subscribed. awesome work so far, never thought a frame and engine could look so purrdyy.
monsonman is offline   Reply With Quote Quick reply to this message
Unread 10-29-2012, 06:37 PM   #71
87yellowyj
subscribed. what a beautiful and clean build. I commend you for the perseverance, I dont think I could ever go through with this bug of a build. this will be a monster when she's done though.
87yellowyj is offline   Reply With Quote Quick reply to this message
Unread 10-30-2012, 11:31 AM   #72
Copperhead89
Thanks for the positive comments, guys!
The next step is to epoxy prime and Monstaliner the bottom of the tub.
Unread 10-30-2012, 11:49 AM   #73
Tblack
Do you happen to know the difference in width of the D44 waggy front and the Standard D30 front? The only answers I have found so far is...... "Eh, should be pretty close". I can get the D44 out of a wagoneer if i want it.
Safety 3rd!
Tblack is offline   Reply With Quote Quick reply to this message
Unread 10-30-2012, 07:01 PM   #74
Copperhead89
I didn't measure the D30 that was in there originally, but I did measure my D44 front, and it is 60.5" from wms to wms.
Unread 10-30-2012, 07:08 PM   #75
Tblack
Hey, thanks! I pulled the tape and measured mounting surface to mounting surface and it is exactly 60.5" on my standard D30.
So hopefully by confirming this, people will be able to finally find this in the search bar and won't have to ask.
Safety 3rd!
