MAGNUM FORCE, a Mopar man's build - Page 4 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > MAGNUM FORCE, a Mopar man's build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineForever Wave Flags at JeepHutRubicon Express lift kits w/shocks are on sale!
Unread 10-12-2012, 08:24 PM   #46
Luke95
so then you can run pump gas nice!
Resident XJ lowlife. 35 general reds on 3inches of lift.
Luke95 is online now   Reply With Quote Quick reply to this message
Unread 10-13-2012, 07:13 AM   #47
Copperhead89
Absolutely. If it had aluminum heads, I could have run another full point to a point and a half more compression.
My YJ/CJ V8 Magnum Build: http://jeepforum.com/forum/f22/magnum-force-mopar-mans-build-1412306/
Copperhead89 is offline   Reply With Quote Quick reply to this message
Unread 10-13-2012, 04:16 PM   #48
Copperhead89
Originally Posted by woods9898 View Post
thats a huge project, good luck
You should have seen my last project. Just to cite one example, I had to completely cut out the firewall, and move it back 2.5" just to fit the engine in. This Jeep project is a walk in the park compared to that one.
Unread 10-14-2012, 09:06 PM   #49
contdevelop
Great choice on the CJ front end...i admit i was disappointed with the YJ at first, but after reading you are making a killer jeep!! Cant wait to see more. How hard was it to keep the frame square since you built the back half?
contdevelop is offline   Reply With Quote Quick reply to this message
Unread 10-15-2012, 06:48 PM   #50
Copperhead89
Thanks, man. About keeping the frame square, I just took my time, and kept measuring from various body mounting points, and using an angle finder, sometimes two of them. I'm a mechanical designer by trade, so the frame work, particularly maintaining the proper geometry of it, wasn't too difficult for me.
Unread 10-15-2012, 07:04 PM   #51
Copperhead89
My engine builder sent me some progress pics. The bullet is almost done! We'll be breaking her in on the dyno in a week or two.
Unread 10-16-2012, 09:05 PM   #52
Copperhead89
Bilstein 5125's for the rear came in today. The 5165's that I ordered for the front are on national back order. I'm hoping that I'll get them before Christmas.
Unread 10-17-2012, 08:53 AM   #53
Diverdown87
Sweet!!!! Subbed for Mopar Madness!!!!
98 TJ 4.0L, 5spd, 4.25 Zone lift, D-locked D30/D35 w/4.56 gears, MCE GEN I Flares, 33" Trxxus ATs, Engo 10K# winch, rear disc brake conversion.
My idea of help from the man above is a sniper on the roof.
Diverdown87 is offline   Reply With Quote Quick reply to this message
Unread 10-17-2012, 09:25 AM   #54
1Badboy
Enjoyed your build progress...Sub'd
1Badboy is offline   Reply With Quote Quick reply to this message
Unread 10-18-2012, 06:38 PM   #55
Copperhead89
The T-Bird electric fan came in today. I laid it on the radiator the typical way (top side up), and saw how much it covered the side tanks, along with one of the hose tubes. For kicks, I rotated it 90º, and BAM!!, it instantly became an absolutely perfect fit between the side tanks. I'm going to mount it like that, but first, I need to shorten the now bottom portion of the shroud as much as possible, and then close it off and seal it. Better to have the hacked part on the bottom where it won't be noticeable. Of course, the four useless mounting ears will need to go, too.
Unread 10-19-2012, 07:53 AM   #56
Diverdown87
When doing the shroud mod I would measure and cut a strip from it to try and splice it back together using the bottom part of the shroud for a more factory seal and not have to fab some sort of lip for it to fit the bottom of the radiator like it does the top.
Would be kind of a pain but it is possible.
Unread 10-19-2012, 12:37 PM   #57
bigdhamYJ
Oh man... This rig looks to be coming along nicely! I love that color orange man, you should repaint it that color once you get it all back together! Looking forward to watching this one.
"Who knew coolant keeps the motor cool?"
Check out my Heep "build"
http://www.jeepforum.com/forum/f22/bigdhamyjs-1993-yj-build-slow-1284516/
bigdhamYJ is offline   Reply With Quote Quick reply to this message
Unread 10-19-2012, 06:30 PM   #58
Copperhead89
No go on the orange paint. Whenever I see an orange vehicle, I see it as a 4 wheeled pumpkin. At this point, I'm going with Intense Blue Pearl. I like red, but there's a million red Jeeps, and I'm wanting to do a color that isn't common.
Unread 10-19-2012, 06:51 PM   #59
bigdhamYJ
Mmm yea go with blue! Everybody loves a good blue jeep! My blue YJ and my buddy's blue CJ7 behind mine. Looking forward to seeing the rest if your build!
Unread 10-19-2012, 07:38 PM   #60
topalmer4
I will second the blue idea plus it goes along with the mopar emblem
[COLOR="Navy"][FONT="Arial Black"]Say Goodbye To your Bank Account, Say Hello To Your New Jeep :D[/FONT][/COLOR]
topalmer4 is offline   Reply With Quote Quick reply to this message
