MAGNUM FORCE, a Mopar man's build - Page 3 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > MAGNUM FORCE, a Mopar man's build
Get 5% Back On Rugged Ridge-Omix-ADA-Alloy at ExtremeTerraGibson Exhaust Rebate - ExtremeTerrain!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 09-07-2012, 08:05 AM   #31
woods9898
1995 XJ Cherokee
thats a huge project, good luck
woods9898 is offline   Reply With Quote Quick reply to this message
Unread 09-07-2012, 11:51 AM   #32
Bama_WJ
Loving the build so far. Very clean and not taking any short cuts.
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Trifecta tuned and 37+ MPG
Wife's Jeep: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers, 3" Gibson Cat-Back
North Alabama Jeep
42RE Vent Mod - Seal your transmission!
YouTube. - My Video Channel
Facebook - Wheeling Pictures/Videos
The Jeep Wave. Bringing it back.
Bama_WJ is offline   Reply With Quote Quick reply to this message
Unread 09-07-2012, 10:10 PM   #33
Copperhead89
Thanks, guys!
Well, that pretty much gets this thread up to where I'm currently at with my build, except for the engine. The engine parts are at my engine builder. The basic engine combo is a 1970 vintage Dodge 318 block bored .030 over, and a 4" stroker crank that will give a displacement of 390 cubic inches, or 6.4 liters for you modern guys. I'm planning on dyno'ing the engine sometime in the last week of this month, assuming the engine builder will have the engine done before then. We're expecting it to make about 350 hp and about 480 ft. lbs. of torque. I'm going to record the dyno session with my camcorder. I'll post a video or two here.
Some random engine parts pics.
My YJ/CJ V8 Magnum Build: http://jeepforum.com/forum/f22/magnum-force-mopar-mans-build-1412306/
Copperhead89 is offline   Reply With Quote Quick reply to this message
Unread 09-11-2012, 10:10 AM   #34
ecautocrafting
Mopar!
ecautocrafting is offline   Reply With Quote Quick reply to this message
Unread 09-16-2012, 02:19 PM   #35
Copperhead89
After sandblasting the firewall, I welded up all 26 of the unneeded holes.
After wiping it down with wax & grease remover, I laid down 2 coats of epoxy primer, and then 3 coats of high build primer.
Unread 09-16-2012, 06:17 PM   #36
Heliandrew
you got a lot of work to do bro
Heliandrew is offline   Reply With Quote Quick reply to this message
Unread 09-16-2012, 06:54 PM   #37
MedicJK
MedicJK's Avatar
2015 JK Wrangler
Awesome build, and you're doing some quality work here. I'll be subscribing.
Sienna Pearl Coat Club Member #24
/l ,[____],
l---L-OlllllllO-
()_)-()_)-o-)_)
My totaled TJ rebuild
MedicJK is offline   Reply With Quote Quick reply to this message
Unread 09-16-2012, 07:41 PM   #38
Copperhead89
Fear not, I've done builds from the ground up before.
Remember, you can eat a whale. Just take a bite at a time, and it'll happen.
I hope to be driving this thing by the end of next year.
03Jeeper...thanks, man!
Unread 09-19-2012, 04:49 PM   #39
Copperhead89
I purchased a 6 pinion planetary and 23 spline input in used, but otherwise excellent condition from a member named gearfather. From a load capacity standpoint, the 6 pinion is a nice upgrade from the 3 pinion that my NP231 originally had. The 23 spline was needed to match the output shaft of my 727 trans.
Unread 09-28-2012, 04:13 PM   #40
miguelemm
Dude, i really love your build, it looks pretty clean.
Hopefully, after y save some money, i want to do the same... strip it off and remove all the rust.
Nice build man, its pretty sick, loved it
miguelemm is offline   Reply With Quote Quick reply to this message
Unread 09-30-2012, 08:20 PM   #41
Copperhead89
Thanks, miguelemm.
I decided to cut my losses and ditch the CJ hood I had originally bought. That first hood had way too many holes to patch up. So, I searched on craigslist last Friday, and found another hood in MUCH better condition for $75. It did have two areas that needed some metal replacement, plus a hole smaller than the size of a dime, but other than that, its overall condition was very good and straight.
Here are the two larger spots that needed metal replacement, already welded up and ground down. I'm going to shoot a coat of epoxy primer on before doing the plastic filler work.
Unread 10-01-2012, 10:14 AM   #42
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Looks great!
06 WK Hemi Overland.. stock DD
87 MJ project on 37s.. Waggy axles, 6 speed, flipped D300 and Bobbed 10" so far. 3 link coming soon.
Sold:
05 LJ.. Low and on 37s
79 FSJ.. 360/4speed on 38s
85 CJ-7 Renegade
Buy my AEV Pintler TJ Beadlocks. See the classifieds.
dayriesw is online now   Reply With Quote Quick reply to this message
Unread 10-12-2012, 07:59 PM   #43
Copperhead89
The Northern radiator came in today. Perfect fit.
I have a new 1995 Ford Thunderbird electric fan assembly on the way from rockauto.com. It has a two speed fan motor. It will be controlled by a DCC controller.
Unread 10-12-2012, 08:09 PM   #44
Luke95
I like the engine idea
Can I ask what are your plans for compression?
Resident XJ lowlife. 35 general reds on 3inches of lift.
Luke95 is offline   Reply With Quote Quick reply to this message
Unread 10-12-2012, 08:20 PM   #45
Copperhead89
My engine builder hasn't figured out the exact compression ratio yet, but it will be around 9.3:1, give or take a tenth.
