MAGNUM FORCE, a Mopar man's build - Page 22 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > MAGNUM FORCE, a Mopar man's build
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 09-01-2013, 04:05 PM   #316
Copperhead89
The 14 bolt is finally under the Jeep. At least, for the time being. I still need to weld the spring perches and the shock mounts, and paint the housing black. I want to wait for the Tom Woods driveshaft to come in, so I can set up the pinion angle before burning in the perches.
Six lug conversion hubs allowed me to keep my new wheels. There's one thing I must note. The diameter of the hub is 4.207, whereas, the center hole on my wheel is 4.188. I had to enlarge the wheel center holes by about .030 to allow the wheel to mount onto these hubs. I did this to the back wheels and the spare as well. With the right tools, it only took me about 15 minutes per wheel. Also, the flanges on the axles need to be turned down to 4.207.
My YJ/CJ V8 Magnum Build: http://jeepforum.com/forum/f22/magnum-force-mopar-mans-build-1412306/
Copperhead89 is offline   Reply With Quote Quick reply to this message
Unread 09-11-2013, 10:36 PM   #317
Copperhead89
The brown Santa dropped off some goodies for the Jeep today.
Inexpensive Grant wheel, but I sprung for the Jeep horn button. I will need to do something about that chrome, though.
New steering column with tilt from Summit racing.
New speedo and tach. I had to buy the programmable speedo, due to the hall effect sensor on the SS SYE.
Unread 09-12-2013, 05:33 AM   #318
Copperhead89
The existing steering column mounting bracket wasn't going to work with the new column, so I made a new one.
Unread 09-12-2013, 08:09 AM   #319
hasan1988
Real Example of Hard Work Mate!! Keep it up =)
hasan1988 is offline   Reply With Quote Quick reply to this message
Unread 09-12-2013, 05:40 PM   #320
Copperhead89
Thanks!
Unread 09-14-2013, 07:06 PM   #321
Copperhead89
The center console is almost done. Another decision must be made, but I'm torn between two options: paint the dash and center console panels to match the body color, or wrap them in 3M carbon fiber vinyl. I'm probably going to paint the Jeep bright red.
Unread 09-14-2013, 07:21 PM   #322
Shobes
I vote body color, looks bada$$ by the way, really nice work!
My "hard way" build - [URL="http://www.jeepforum.com/forum/f22/tj-rubi-9s-learning-hard-way-1483373/"]http://www.jeepforum.com/forum/f22/tj-rubi-9s-learning-hard-way-1483373/[/URL]
Shobes is offline   Reply With Quote Quick reply to this message
Unread 09-14-2013, 08:54 PM   #323
Copperhead89
Thanks, man! And thanks for your input, I'm leaning towards body color. Painting them bright red would add some pop to the interior.
Unread 09-14-2013, 09:01 PM   #324
Copperhead89
New steering wheel and Summit column are installed. I'll have to make a filler panel to cover up that huge hole where the column goes through.
I scanned the speedo and tach, printed them out, and stuck them to the dash to see if I could read them through the steering wheel. I can, so that's where they will go.
Unread 09-15-2013, 08:22 AM   #325
lovett86
awesome work
its a rusty one
http://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/
lovett86 is offline   Reply With Quote Quick reply to this message
Unread 09-15-2013, 07:38 PM   #326
Copperhead89
Originally Posted by lovett86 View Post
awesome work
Thanks, I appreciate it! I enjoy this kind of thing, so it doesn't feel like work to me. With a project like this, it's one challenge to overcome after another, but I like challenges, and I like challenging myself to do things I've never done before. Building a center console is one example.
Unread 09-16-2013, 12:03 PM   #327
87yellowyj
I agree with painting it to match the outside, I wish my interior had a little more color!
87yellowyj is offline   Reply With Quote Quick reply to this message
Unread 09-16-2013, 01:33 PM   #328
Kodiak17
Killer build, been lurking for awhile. I think a CF dash would look awesome.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline   Reply With Quote Quick reply to this message
Unread 09-22-2013, 04:10 PM   #329
Copperhead89
Thanks! I still haven't ruled out the CF vinyl yet.
I cut the holes for the stop-turn-tail lamps and the backup lights. Instead of spending around $50 for some 3" and 4-1/2" hole saws (which I'd probably never use again), I decided to cut out the holes with my old Skil jigsaw.....until about 30 seconds into it, the plastic housing completely cracked open and wouldn't cut straight anymore. So, I wound up spending $70 at Lowe's for a better quality Porter jigsaw. So much for trying to save a few bucks.
Unread 09-26-2013, 08:14 PM   #330
Copperhead89
I had a local auto upholstery shop stitch up a nice pad for my console lid. I think they did a great job on it. I'm sure my right elbow will enjoy it.
