MAGNUM FORCE, a Mopar man's build - Page 6 - JeepForum.com
post #76 of 1419 Old 10-30-2012, 07:16 PM
mhopton
Will that motor run regular or premium pump gas?
mhopton is offline
post #77 of 1419 Old 10-30-2012, 09:50 PM Thread Starter
Copperhead89
It will easily run on 87 regular. As a matter of fact, we dyno'd it on 87.
My YJ/CJ V8 Magnum Build: http://jeepforum.com/forum/f22/magnum-force-mopar-mans-build-1412306/
Copperhead89 is offline
post #78 of 1419 Old 11-01-2012, 08:17 PM
tonkatrucksryan
2014 JK Wrangler
Awesome build I wish I had the skills, talent, and $ to do this too
tonkatrucksryan is offline
post #79 of 1419 Old 11-04-2012, 03:33 PM Thread Starter
Copperhead89
I sand blasted the power steering brackets and pulley, purchased a remanned PS pump, rattle canned some paint, and bolted it to the engine. I went to the Garlits Mopar show and swap yesterday, and bought alternator brackets. A new Denso 120 amp alternator is in route.
I still need to decide what color to paint the valve covers.
I painted and installed the steering box.
post #80 of 1419 Old 11-05-2012, 03:20 PM
Limited-Edition
1979 CJ7
I was wondering what motor mounts you used on the motor side? Great build, I like the shock mount stiffeners!
Limited-Edition is offline
post #81 of 1419 Old 11-05-2012, 05:02 PM Thread Starter
Copperhead89
I used engine mounts from a 1983 Chrysler Cordoba with a 318, but just about any 1975 and up Plymouth or Dodge 318 car mounts should be the same.
post #82 of 1419 Old 11-06-2012, 05:00 AM
Limited-Edition
1979 CJ7
Cool thanks.
post #83 of 1419 Old 11-06-2012, 07:23 PM Thread Starter
Copperhead89
Picked up these new V8 Magnum fender emblems on ebay.
post #84 of 1419 Old 11-06-2012, 07:24 PM Thread Starter
Copperhead89
I painted the valve covers with Dupli-Color ceramic engine paint, in a color called Cast Coat Aluminum.
post #85 of 1419 Old 11-06-2012, 07:31 PM Thread Starter
Copperhead89
Here is a pic showing the now shortened cast trans mount with the welded plate and the factory 1985 Dodge Ramcharger transmission isolators. I cut down the cast trans mount in order to get the driveline height and angle I wanted, and to make it short enough so I had room for the isolators.
The white PVC pipe is in place to simulate the front driveshaft. I'm going to fabricate a set of headers, so I need to know where the d-shaft is going to be, so I can make sure the pipes will not interfere with it during the range of suspension travel.
post #86 of 1419 Old 11-08-2012, 07:17 PM Thread Starter
Copperhead89
The little stuff is important, too. Take for instance, power steering hoses. I held on to the original hoses from the 2.5L, in hopes that I might be able to re-use them. Once the steering box and pump were installed for the last time, it quickly became obvious that they weren't even close to being able to work, so I hacked up the high pressure hose to the point where it connected A to B, and looked and fit decent. I then took my hose mock-up over to Amazon Hose, where they made a hose to the same dimensions, bends and angles. It fits perfect. The low pressure return hose was easier, I just kept cutting until it fit nice.
post #87 of 1419 Old 11-10-2012, 10:43 PM Thread Starter
Copperhead89
I liked the color on the valve covers so much, I decided to paint the intake manifold as well.
post #88 of 1419 Old 11-11-2012, 01:57 PM
Bama_WJ
Bama_WJ's Avatar
The engine is looking great!
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #89 of 1419 Old 11-11-2012, 02:04 PM
cavscout187
wow nice build super clean all that effort to paint it up just to cover with mud... i like it i wish i had the time and space to do this to my 5.9 wrangler
cavscout187 is offline
post #90 of 1419 Old 11-11-2012, 09:16 PM
Kman1983
1983 CJ5
Very Nice! Subscribed. Any pics of how you did the SOA perches on the front Waggy 44?
Rolled Red Jeep Club Member #258
'83 CJ5, 4.0 MPFI swap, T18/D20, CenterForce II clutch, Dana44/30(73 CJ5) with 3.73's,'79 knuckles and 11" discs, sagged 4" lift, 2" BL, 34x9.50x15 Super Swamper Pizza Cutters
My wifes website The Vermont JeepGirl
"Good Girls and Dirty Jeeps" a song by Opal Justice
Kman1983 is offline
Jeep 97 4cyl conversion to a Magnum v8 5.2 in Mexico miguelemm Jeep Builds 5 09-28-2012 03:57 PM
5.2L magnum (318) + AW-4 rhythmofrock Jeep Builds 0 02-16-2012 11:01 PM
Air Force or Fighter Plane painted Jeeps Sledhead44 Jeep Picture Requests 4 07-03-2011 07:05 PM
Light Force Lights muddy8jeep8 Jeep Picture Requests 25 05-16-2011 12:46 AM
Your Jeep with Air Force One grogie Jeep Picture Requests 28 07-23-2009 05:11 PM
