MAGNUM FORCE, a Mopar man's build - Page 3 - JeepForum.com
post #31 of 1419 Old 09-07-2012, 08:05 AM
woods9898
1995 XJ Cherokee
thats a huge project, good luck
woods9898 is offline
post #32 of 1419 Old 09-07-2012, 11:51 AM
Bama_WJ
Bama_WJ's Avatar
Loving the build so far. Very clean and not taking any short cuts.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #33 of 1419 Old 09-07-2012, 10:10 PM Thread Starter
Copperhead89
Thanks, guys!
Well, that pretty much gets this thread up to where I'm currently at with my build, except for the engine. The engine parts are at my engine builder. The basic engine combo is a 1970 vintage Dodge 318 block bored .030 over, and a 4" stroker crank that will give a displacement of 390 cubic inches, or 6.4 liters for you modern guys. I'm planning on dyno'ing the engine sometime in the last week of this month, assuming the engine builder will have the engine done before then. We're expecting it to make about 350 hp and about 480 ft. lbs. of torque. I'm going to record the dyno session with my camcorder. I'll post a video or two here.
Some random engine parts pics.
My YJ/CJ V8 Magnum Build: http://jeepforum.com/forum/f22/magnum-force-mopar-mans-build-1412306/
Copperhead89 is offline
post #34 of 1419 Old 09-11-2012, 10:10 AM
ecautocrafting
Mopar!
ecautocrafting is offline
post #35 of 1419 Old 09-16-2012, 02:19 PM Thread Starter
Copperhead89
After sandblasting the firewall, I welded up all 26 of the unneeded holes.
After wiping it down with wax & grease remover, I laid down 2 coats of epoxy primer, and then 3 coats of high build primer.
post #36 of 1419 Old 09-16-2012, 06:17 PM
Heliandrew
you got a lot of work to do bro
Heliandrew is offline
post #37 of 1419 Old 09-16-2012, 06:54 PM
MedicJK
2015 JK Wrangler
Awesome build, and you're doing some quality work here. I'll be subscribing.
Sienna Pearl Coat Club Member #24
/l ,[____],
l---L-OlllllllO-
()_)-()_)-o-)_)
MedicJK is offline
post #38 of 1419 Old 09-16-2012, 07:41 PM Thread Starter
Copperhead89
Fear not, I've done builds from the ground up before.
Remember, you can eat a whale. Just take a bite at a time, and it'll happen.
I hope to be driving this thing by the end of next year.
03Jeeper...thanks, man!
post #39 of 1419 Old 09-19-2012, 04:49 PM Thread Starter
Copperhead89
I purchased a 6 pinion planetary and 23 spline input in used, but otherwise excellent condition from a member named gearfather. From a load capacity standpoint, the 6 pinion is a nice upgrade from the 3 pinion that my NP231 originally had. The 23 spline was needed to match the output shaft of my 727 trans.
post #40 of 1419 Old 09-28-2012, 04:13 PM
miguelemm
Dude, i really love your build, it looks pretty clean.
Hopefully, after y save some money, i want to do the same... strip it off and remove all the rust.
Nice build man, its pretty sick, loved it
miguelemm is offline
post #41 of 1419 Old 09-30-2012, 08:20 PM Thread Starter
Copperhead89
Thanks, miguelemm.
I decided to cut my losses and ditch the CJ hood I had originally bought. That first hood had way too many holes to patch up. So, I searched on craigslist last Friday, and found another hood in MUCH better condition for $75. It did have two areas that needed some metal replacement, plus a hole smaller than the size of a dime, but other than that, its overall condition was very good and straight.
Here are the two larger spots that needed metal replacement, already welded up and ground down. I'm going to shoot a coat of epoxy primer on before doing the plastic filler work.
post #42 of 1419 Old 10-01-2012, 10:14 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Looks great!
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #43 of 1419 Old 10-12-2012, 07:59 PM Thread Starter
Copperhead89
The Northern radiator came in today. Perfect fit.
I have a new 1995 Ford Thunderbird electric fan assembly on the way from rockauto.com. It has a two speed fan motor. It will be controlled by a DCC controller.
post #44 of 1419 Old 10-12-2012, 08:09 PM
Luke95
I like the engine idea
Can I ask what are your plans for compression?
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #45 of 1419 Old 10-12-2012, 08:20 PM Thread Starter
Copperhead89
My engine builder hasn't figured out the exact compression ratio yet, but it will be around 9.3:1, give or take a tenth.
Jeep 97 4cyl conversion to a Magnum v8 5.2 in Mexico miguelemm Jeep Builds 5 09-28-2012 03:57 PM
5.2L magnum (318) + AW-4 rhythmofrock Jeep Builds 0 02-16-2012 11:01 PM
Air Force or Fighter Plane painted Jeeps Sledhead44 Jeep Picture Requests 4 07-03-2011 07:05 PM
Light Force Lights muddy8jeep8 Jeep Picture Requests 25 05-16-2011 12:46 AM
Your Jeep with Air Force One grogie Jeep Picture Requests 28 07-23-2009 05:11 PM
