Ludski & The Black Widow - Page 4 - JeepForum.com
post #46 of 201 Old 09-28-2012, 09:58 PM
ashland82391
Originally Posted by NJXJ91 View Post
Im 20 years old. Jealous? Na, its obvious he was just handed this.
His signature should read "Bought, Not Built #1"
Well, im 21 and I have no problem saying im JEALOUS!!!! I dont come from a family of money but if I did I would live it up too!
Anyway thanks for turning this in to some what of a build thread. P.S. the JK looks awesome without the rear bumper.
ashland82391 is offline
post #47 of 201 Old 09-28-2012, 10:24 PM
BchCruzr
Used lift? Did you replace the bushings? Did you you put the lift on yourself?
BchCruzr is offline
post #48 of 201 Old 09-29-2012, 07:00 PM
honda250ex
1987 YJ Wrangler
Bro your obviously jealous... like get over your self
It's better to live one day as a lion than a hundred years as a lamb.
http://www.jeepforum.com/forum/f12/honda250exs-buildup-860712/
honda250ex is offline
post #49 of 201 Old 09-29-2012, 08:02 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
My builds:
and
or follow us on
spyder6 is offline
post #50 of 201 Old 09-30-2012, 12:15 PM Thread Starter
ludski
2009 JK Wrangler
the bushings on the shocks were fine. werent perfect, but they were fine for how long i needed them for.
and yes, like i stated before, i install everything on my jeep in my garage.
Hi there, I'm Ludski. But you can call me Ludski.
ludski is offline
post #51 of 201 Old 09-30-2012, 12:18 PM
Mol
Disclaimer: I'm Polish
Mol's Avatar
He was probably talking about control arm bushings, but you run stock control arms with relocation brackets...
You should reconsider that setup
Mol is offline
post #52 of 201 Old 09-30-2012, 02:31 PM Thread Starter
ludski
2009 JK Wrangler
RAN relo brackets. sold them off when i downsized in lift. my stock arm bushings are fine as well.
Im gonna be running new arms in the future, but not needed yet.
ludski is offline
post #53 of 201 Old 10-01-2012, 12:05 PM
BchCruzr
Thanks for the insight. I'm looking forward to getting my hands dirty putting on a lift.
Happy Trails
BchCruzr is offline
post #54 of 201 Old 10-04-2012, 11:05 AM Thread Starter
ludski
2009 JK Wrangler
no prob. just be careful to make sure everything is tight, but not too tight, or you could break a bolt. ive done it plenty of times.
ludski is offline
post #55 of 201 Old 10-08-2012, 06:28 PM Thread Starter
ludski
2009 JK Wrangler
lost a ujoint cap 2 days ago, while wheeling at badlands. so will be redoing my right ujoint and using a press to make sure it is pressed correctly. and getting the caps tack welded on, just incase.
also will be replacing inner axle seals.
so will be changing diff fluid and doing an oil change while im at it.
ball joints are dam near dead. but i do NOT want to replace them. since i'll be swapping these axles out real soon.
took a few hours to get all the sand out of the Jeep.
swapped in a new ujoint tonight. but still need to figure out my steering issue. think i killed another power steering pump.
ludski is offline
post #56 of 201 Old 10-11-2012, 10:21 PM Thread Starter
ludski
2009 JK Wrangler
as you know, DUB and ballistic off road were working on getting me to SEMA this year to show the Jeep for a tire company. Well, i hadnt gotten a response in a while, so i decided to look around more. So i sent out some messages to a few companies and lo and behold, Coverking called me, and they want my Jeep. They will outfit her with all new seat covers with custom embroidery. they need my exact answer by tomorrow on if i will do it or not.
it all comes down to the transportation method and costs, as Las Vegas, isnt close, and gas isnt cheap.
I'm also gonna have a new hood decal made in matte black (to blend in with the gloss black paint, so you can just see it up close).
ludski is offline
post #57 of 201 Old 10-11-2012, 10:23 PM
HurricaneRZA
i like that idea, not flashy but it's there nonetheless
Originally Posted by YoureverydayXJ View Post
This is the most metal thing I have ever heard.
Originally Posted by doublins View Post
I always get people coming over and saying things like "I wish I knew how to do that," etc- but they don't realize- at some point I didn't know how to do it either- I had to figure it out.
HurricaneRZA is offline
post #58 of 201 Old 10-12-2012, 12:36 PM Thread Starter
ludski
2009 JK Wrangler
new video update
also some shots i took other day showing off the new spiderweb shade.
ludski is offline
post #59 of 201 Old 10-13-2012, 06:33 PM Thread Starter
ludski
2009 JK Wrangler
my other axle is hasnt been responding lately. so i continued my search. found this little bad boy. 1999 F350 D60. 3.73 gears
new brake calipers. new ball joints.
good ujoints, good rotors, good gears, good shafts + inner + outer splines.
was thinking of maybe putting in some Currie unit bearings, that puts me at a 5x5.5 Bolt pattern, with that, id have to replace the outers with 35 spline and either drill the current rotors or get new ones.
then id tie the drag link into the tie rod.
what you guys think?
ludski is offline
post #60 of 201 Old 10-14-2012, 11:09 AM
TroubleNEO
Are you going coilovers or struts?
Looking for: 03-06 interior plastic trim. PM me.
TroubleNEO is offline
want to see how a black tj looks with black light bezels and black trim grill inserts Dutra177 Jeep Picture Requests 33 01-21-2014 11:13 PM
The '88 yj Widow livingdeadjeep1 Jeep Builds 15 12-21-2011 07:18 PM
Black Widow Rebuild WildChild46 Jeep Builds 13 02-14-2011 10:16 PM
Black Widow Roof Basket Project1 Jeep Picture Requests 11 04-27-2010 01:49 PM
Black rock D widow alloys grnsporty Jeep Picture Requests 0 09-29-2009 07:12 PM
