Louie4's YJ - Page 62 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Louie4's YJ
Unread 05-24-2013, 10:25 PM   #916
WidowYj91
Originally Posted by 95YamJam View Post
Great build! I love my cav/sunfire seats. I still need to get water proof covers for them but it's $180 spent elsewhere. LOL!
Any links to said covers?
WidowYj91 is offline   Reply With Quote Quick reply to this message
Unread 05-25-2013, 08:04 AM   #917
95YamJam
It's been a while. I think they were cover king. I googled it. They made convertible cav s so they are out there. I'll see if I can find the ones I was looking at.
My build: http://www.jeepforum.com/forum/f22/95-yam-project-1527472/?highlight=
95YamJam is offline   Reply With Quote Quick reply to this message
Unread 05-26-2013, 03:41 PM   #918
jeepyj13
Originally Posted by Louie4
One of the guys I went wheeling with got a good video of me spinning up in the muck.
Video Link: http://www.youtube.com/watch?v=lDOh0BdmN3s&feature=youtube_gdata_player
Like a boss!
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline   Reply With Quote Quick reply to this message
Unread 05-27-2013, 02:20 PM   #919
Louie4
Originally Posted by jeepyj13 View Post
Like a boss!
Thanks. I get lucky everyone once in a while.
I put a power steering cooler in the jeep yesterday. My power steering fluid was puking out when it got to hot on the trail. The fluid itself was toast so I got this cooler from Pep Boy's for $30. Came with the cooler, hose, and clamps. Not too bad.
Hopefully it helps out.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Poison Spyder Fender Install
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Reply With Quote Quick reply to this message
Unread 05-27-2013, 08:16 PM   #920
PA_YJ19
Let us no how this works out, may have to add one myself. I switched to a higher pressure ps pump from a 4.7l WJ and mine has been overflowing on the trail. Given I had way too much in there but I didn't like how hot it was getting. I was forced to use the resevoir attached to the pump instead of my stock yj one which was remote. The outlet hose was way big and couldn't b swapped over. The new pump works like a champ n I can steer locked in 4wd again but I don't want it running too hot. I think I might stop at the junkyard and get a tranny cooler tmrw...
PA_YJ19 is offline   Reply With Quote Quick reply to this message
Unread 05-27-2013, 08:37 PM   #921
Louie4
Will do.
A trail ride in the Summer will give me an idea. If it doesn't help then I'm only out $30. At least it gives some peace of mind and it can't hurt. I may look into the better pump. The pump and box on my jeep are the OEM ones from 1993 so they may be due.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Unread 05-27-2013, 08:53 PM   #922
PA_YJ19
If u decide u want to try the pump, ill mayb do a little write up. Unless u want to swap to the newer intake style 99+ it won't just bolt right on to our yjs. I had to tap all the bolt holes and switch a few fittings but man does it make a difference. I def thinks its getting to hot tho because it flowed over as u said n I'm reading that means its too hot. I think that little cooler could b the ticket. I looked into the psc pump and its only 1500 psi, or stock pump is 1450, and the WJ one is 1950psi. I'm not really sure how the psc one would make much of a difference. I can turn my wheel with just my fingers offroad now, I used to have to muscle it on every turn.
Unread 05-28-2013, 03:13 PM   #923
Louie4
I may do the upgrade when my stock pump goes out. Until then I don't have the drive. I'm curious why the PSC is that much better than stock?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Unread 05-29-2013, 03:23 PM   #924
95YamJam
Great vid. I could almost hear you thinking... turn baby, turn baby, turn baby, turn baby. YEAHHHHHHHHHHHH!
Unread 06-01-2013, 08:54 PM   #925
Louie4
My next small project. I'll post up a few more pics and details when I'm done.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Unread 06-01-2013, 09:13 PM   #926
trailrider787
Nice Lou! Can't wait to see how it works!
trailrider787 is online now   Reply With Quote Quick reply to this message
Unread 06-02-2013, 06:40 AM   #927
Louie4
Hopefully well. I'm going to get some return springs from the junkyard and see how it goes.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Unread 06-02-2013, 04:20 PM   #928
Louie4
I went by the junkyard today and got some little things here and there. I found a return spring and some little attachements for the throttle body. Here is how I setup my linkage for the hand throttle. I tried to find a washer for the adjuster screw but had no luck. I was about to give up until I saw a spark plug gapper in my toolbox. The hole looked to be to the right size and what do you know, it fit perfect. It was even countersunk.
I noticed from other write-ups that there was a return spring on the throttle body and since I didn't have one, I looked for one. Couldn't find the spring on a Jeep so I snagged one off an import and made it work with the little plastic head. I think this will help the hand throttle return. I actually got the handle from an exercise bike I saw in the dumpster in Griffin, GA. I even took a pic and posted a good many pages back. I still need a cable crimp sleeve to hold it but I haven't been to Home Depot. I just tied it in a knot to see how it did. Works pretty good by the way.
I also found a nearly untouched Saab 900. Snagged the sensor housing and will most likely do the Porsche 944 temp switch, eventually.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Unread 06-02-2013, 04:28 PM   #929
brzehentmaier
GENIUS!!!!!!! I just lost about 2 hrs going re-going through your thread. Great vid as well.
Bernie
1995 Rio Grande
31 x 10.5 x 15 Tires
1.5 Body Lift - Skyjacker Hydros
2.5 - Auto - Crager "D" Slots
A Work In Progress
2004 Liberty Columbia Pkg.
A new begining
brzehentmaier is offline   Reply With Quote Quick reply to this message
Unread 06-02-2013, 04:30 PM   #930
kjg26
My Saab housing was rusted pretty badly. I covered it with Jb weld
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline   Reply With Quote Quick reply to this message
cheap , domination , georgia , poison spyder , YJ
