Louie4's YJ - Page 47 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Louie4's YJ
The ULTIMATE "Selectable" Locker System! Brough**Flash Weekend Sale** Rockridge4wd.com Only!RIGID LED Light Blowout Sale - All Sizes, All Series, all
Unread 11-18-2012, 01:34 PM   #691
Louie4
Powah Injanir
Louie4's Avatar
Originally Posted by nibstools View Post
So where did that bracket come from?
Parts Mike. They had good service and came with grade 8 hardware for bolting the bracket to the box. I bought replacement grade 8 for the bracket to frame and kept the longer bolts because of their size.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Poison Spyder Fender Install
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Reply With Quote Quick reply to this message
Unread 11-18-2012, 03:03 PM   #692
nibstools
thanks! I like parts mike!
Check out "my little YJ" in the Jeep builds section.
http://www.jeepforum.com/forum/f22/my-little-yj-1127802/
nibstools is offline   Reply With Quote Quick reply to this message
Unread 11-20-2012, 01:15 PM   #693
Louie4
Powah Injanir
Louie4's Avatar
No problem. I just need to put my TJ pitman arm on over the holidays and I should be ready for the trails in December. Planning on a run to Morris Mountain the 15th.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Unread 11-24-2012, 07:37 AM   #694
Louie4
Powah Injanir
Louie4's Avatar
Got the old arm off. If anyone wants it I'll ship it for the cost to get it there. I also found out my radiator is leaking.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Unread 11-24-2012, 07:50 PM   #695
trailrider787
I removed my console for you. It indeed tore my seats a little. I'm going to look for a thinner one in the meantime. Do you want me to bring it to Morris mtn? Do you think Eddie might come with the new jeep?
trailrider787 is offline   Reply With Quote Quick reply to this message
Unread 11-25-2012, 08:43 AM   #696
NHfireLJ
Jeeper Creeper
NHfireLJ's Avatar
Did you have to install a longer steering shaft with the steering box bracket?
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495 Build thread. http://www.jeepforum.com/forum/f9/my...hread-2778642/
BETTY...94 SE, Stroker 4.6, 4.5,lift,35"s,D30 Aussie, 8.8. Sold
NHfireLJ is offline   Reply With Quote Quick reply to this message
Unread 11-25-2012, 09:10 AM   #697
Louie4
Powah Injanir
Louie4's Avatar
Nope. Unlike the CJ's, the steering shaft on a YJ will extend and collapse. A few years ago when I replaced my lower steering column bearing I took the steering shaft apart and cleaned it thoroughly and greased it. So there were no issues.
I'll post pics today. I test drove the jeep to Autozone last night to check on a new radiator, get gas, and test the steering. It took 30 minutes to find my warranty info. Luckily the guy there was persistent and found out that the replacement from July was done as a damage so the warranty info was gone. However he found where I swapped it and that it's a lifetime warranty so we got it sorted out.
The steering is back to normal and I have every bit of my turning radius back. I wish I would have just done it properly the first time. Luckily it only cost me 30 more dollars (shorty pitman arm).
I also chopped the exhaust some more and tightened it up at the manifold because it was loose.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Unread 11-25-2012, 09:40 AM   #698
zte87
GIVE IT THE ONION
zte87's Avatar
Where did you chop it at?
95 jeep yj double main leaf stock spring soa, locked front and rear 30/8.8 with chromo shafts, full cloak armor and 35 inch mtrk tires
zte87 is online now   Reply With Quote Quick reply to this message
Unread 11-25-2012, 10:10 AM   #699
Louie4
Powah Injanir
Louie4's Avatar
Right where it curves down over the rear axle tube. My last trip I bent the tail pipe back to an acute angle. I cut it on the trail with a battery powered angle grinder but it was pointing at the corner of the fuel tank/skid. So now it's pointing down to the ground I need to route it out the side somehow.
I'll post a pic later. It's definitely not idea but better than before.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Unread 11-25-2012, 12:45 PM   #700
'92 vegas YJ
R.I.P. Ratmonkey
'92 vegas YJ's Avatar
My exhaust got in the way of my rear shocks, so i just chopped it right after the muffler. I dont run any pipe at all
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
'92 vegas YJ is offline   Reply With Quote Quick reply to this message
Unread 11-25-2012, 01:59 PM   #701
zte87
GIVE IT THE ONION
zte87's Avatar
I may be doing the same thing when I install my teraflex rear shock bar, do you notice and fumes in the cab?
Unread 11-25-2012, 02:23 PM   #702
CDW_327
My exhaust is dumped right before my rear axle, it's loud, it smells, I plan to get a tail pipe...
CDW_327 is offline   Reply With Quote Quick reply to this message
Unread 11-25-2012, 03:03 PM   #703
NHfireLJ
Jeeper Creeper
NHfireLJ's Avatar
Tried it. Hated it. Stinky!!!
Unread 11-25-2012, 03:03 PM   #704
'92 vegas YJ
R.I.P. Ratmonkey
Haha well i run no floor plugs, doors, top ect. So no i don't really notice any fumes while driving. plus i rarely drive it on the street
Unread 11-25-2012, 03:05 PM   #705
CDW_327
Yup, dumping the exhaust before the axle really only works for pickups where the exhaust dumps under the bed and its back far enough not to allow fumes an noise into the cab...
cheap , domination , georgia , poison spyder , YJ
