Louie4's YJ - Page 52 - JeepForum.com
 27Likes
post #766 of 1681 Old 01-18-2013, 03:47 PM
'92 vegas YJ
Originally Posted by Louie4 View Post
Well I found out the welder I was given is a Farmhand 115V MIG. I did some searching and it doesn't seem to be that great. Then again, I can't complain because I didn't pay for it. I actually tacked the upper and lower ball joints in this afternoon with it and it didn't do that great. I may need to just practice and give it some TLC. I do not plan on using it for 1/4" material as it appears to only be for smaller stuff.
Well I might know of a HH140 going up for sale soon.
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
My one ton YJ unlimited build
'92 vegas YJ is offline
post #767 of 1681 Old 01-18-2013, 06:12 PM Thread Starter
Louie4
Let me know when.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #768 of 1681 Old 01-18-2013, 06:33 PM Thread Starter
Louie4
This is what your upper ball joint SHOULDN'T look like installed.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #769 of 1681 Old 01-18-2013, 06:35 PM Thread Starter
Louie4
Here's the new Moog. I tried out my new to me welder but I wasn't impressed. I tacked it on the C because it didn't fit as tightly as I would have liked. The other ball joint opened up the top a lot.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #770 of 1681 Old 01-18-2013, 06:38 PM Thread Starter
Louie4
Oh yeah, I put my spare on the front drivers side. I have never used it and it's been several years since I bought it. That wheel was particularly bad as it had the most dents. I figured I should get some use out of it as I plan on going to 35's for my next set of tires.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #771 of 1681 Old 01-18-2013, 06:47 PM
trailrider787
What's your voltage setting maxed out when you tacked the ball joints
trailrider787 is offline
post #772 of 1681 Old 01-18-2013, 06:57 PM Thread Starter
Louie4
Yes.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #773 of 1681 Old 01-18-2013, 09:00 PM
Carlos14
Louie! Great build. I've been silently watching for a while now!
One quick question! How do you like the 33x10.50 KM2s. They're on my list of choices.
Luck Favours The Prepared
Carlos14 is offline
post #774 of 1681 Old 01-19-2013, 06:11 AM Thread Starter
Louie4
I love those KM2's. They have served me well. They ride great on the road but grab on the rocks and are decent in the mud (which I don't get into if I can help it). They also wear very well and since I drive up to a couple hundred miles to my wheeling sites that's a good thing.
I'm planning on some 35 x 12.50 KM2's next simply because I want more ground clearance. I air mine down around 15 or so but I also lose some height. I end up bashing and smashing rocks (usually regardless of tire size though).
I highly recommend them.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #775 of 1681 Old 01-19-2013, 09:22 AM
Carlos14
Thanks for the info louie. I really like the tall skinny look, but I doubt I'll be ready to run 35s by this summer when I plan to get tires so this may be the next best option. I am glad hear that they have good road manners because it is my daily driver, but I have reached a point where my all terrains are my weakest link on the trails.
Carlos14 is offline
post #776 of 1681 Old 01-21-2013, 12:45 PM Thread Starter
Louie4
I ran some BFG A/T's for a time. They were OK but they didn't have that great of a performance off-road. At least in the terrain I was in. Good luck with the tire selection as that can be a big decision when you start looking at 33's and above.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #777 of 1681 Old 01-21-2013, 01:06 PM
pete1991YJ
You can cut the wire speed way down till it gives a spray-transfer. This has the same effect as cranking the voltage way up. Popular technique when smoothness penetration and strength are the big requirements.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #778 of 1681 Old 01-21-2013, 01:28 PM Thread Starter
Louie4
Thanks Pete. I will give this a shot when I have the space to monkey with it. That should be coming soon once we move at the end of the month.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #779 of 1681 Old 01-22-2013, 04:50 PM
trailrider787
Lou,
Did you have any problems with the steering shaft being to short for once you put the new steering box bracket on? Don't you have a 1" BL also?
post #780 of 1681 Old 01-22-2013, 04:53 PM Thread Starter
Louie4
Lou,
I hasn't caused a problem as of yet but when I noticed I pushed on the shaft at the slip joint and it had some play plus I saw the tension spring peeping out of the outer part.
So while I haven't had any problems, it's best to address it when I can.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
cheap , domination , georgia , poison spyder , YJ
