Louie4's YJ - Page 50 - JeepForum.com
 27Likes
post #736 of 1680 Old 12-11-2012, 07:45 AM
CDW_327
Originally Posted by Louie4
Question to the JF guru's.
My pass. side axle seal is leaking. I still have the CAD system and will most likely just refill the diff until warmer weather comes. I have spare shafts for the CAD system so I'm not in a rush to do a solid shaft conversion.
The question, if I were to replace the seal in the CAD would it be beneficial to put some seals in the pumpkin on the pass. side? I know there isn't a machined surface on the shafts so it would inevitably eat them up. I've seen other guys put (2) seals stacked in the pumpkin. I would put some gear oil in the CAD as well to keep it lubed.
I figure it would keep the fluid in for the most part. Or it would drain to the axle tube and keep it from getting back in.
On another note, I am riding at Morris Mountain this weekend in Alabama. Will be driving 260 miles just to wheel the jeep. We'll see if I make it home.
I just replaced my pass side CAD seal to. It's actually really easy and only took about an hour and a half. I used a piece of threaded rod and washers to press the seal in. There's no need to put a seal in the diff if your still running the CAD and two piece shafts. There's a write up on here showing the method of pressing the se in with the threaded rod but I'm sure you've seen it.
CDW_327 is offline
post #737 of 1680 Old 12-11-2012, 07:49 AM
NHfireLJ
NHfireLJ's Avatar
I'd just do the CAD seal... Like you said the inner seal may not last long due to the lack of machine surface, It's worked for years like that. a double seal is uneccessary
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #738 of 1680 Old 12-11-2012, 09:45 AM Thread Starter
Louie4
Thanks guys. I'll just replace the CAD seal when Spring rolls around. I've see the threaded rod and washer write-up. Seems a lot easier than when I did it. I used a steel rod that went into a 3/4" drive extension to a 3/4" drive socket. I hit that with a hammer from the driver side axle opening...dumb.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #739 of 1680 Old 12-11-2012, 06:32 PM
trailrider787
Don't forget that I have those xj shafts, so next spring you should convert over and do the CAD delete. Then you won't even need to replace the outer seal.
trailrider787 is offline
post #740 of 1680 Old 12-11-2012, 08:39 PM Thread Starter
Louie4
I forgot about this. You got the 30 spline solid shafts right?
I will snag those shafts from you this Spring. Just toss them next to the t-case you're holding for me, haha!
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #741 of 1680 Old 12-12-2012, 04:29 AM
trailrider787
Yes I got the 30 splines, and I'll put them with the t case. What am I...your storage man?
post #742 of 1680 Old 12-12-2012, 06:27 AM Thread Starter
Louie4
Storage Facility Manager to be precise.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #743 of 1680 Old 12-13-2012, 06:24 AM Thread Starter
Louie4
If anyone around East Alabama wants to wheel, a buddy and I are going to Morris Mountain ORV this weekend. We'll be there Saturday morning and leaving Sunday afternoon. Camping of course. The fee is $30 for the weekend.
If you're interested just PM me.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #744 of 1680 Old 12-16-2012, 07:47 PM Thread Starter
Louie4
Got back from MM today. The jeep did well. Got a few new dings and breaks. My bumper side piece was not welded too well obviously. That or I just bash it too much with rocks. My buddy busted his shackle mount on the front of the frame, my under carriage is taken on a new shape, my pass. door will not close with out a lot of persuasion, and the end of my winch cable came out of the lug on the end that threads into the drum.
Great trip though. I'll post pics tomorrow.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #745 of 1680 Old 12-16-2012, 08:32 PM
zte87
GIVE IT THE ONION
zte87's Avatar
Sounds like you were doing it right than, can't wait to see you pics!
zte87 is offline
post #746 of 1680 Old 12-17-2012, 11:47 AM
trailrider787
Here are a few pics of you I had on my phone.
post #747 of 1680 Old 12-17-2012, 12:42 PM
kjg26
kjg26's Avatar
I'm on the mobile app what is your suspension lift set up
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #748 of 1680 Old 12-18-2012, 09:59 AM Thread Starter
Louie4
It's a 3.5" Black Diamond with booms front and rear. I also have a 1" BL but the mounts have gone concave. I need to replace them and then I'll gain 1/2" of clearance back.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #749 of 1680 Old 12-18-2012, 10:44 AM
kjg26
kjg26's Avatar
And you're running 35s?
kjg26 is offline
post #750 of 1680 Old 12-18-2012, 12:58 PM
zte87
GIVE IT THE ONION
zte87's Avatar
I think he is running 33/10.50.......
zte87 is offline
cheap , domination , georgia , poison spyder , YJ
