lolitsdaelan's "I have no idea what I'm doing" build thread ('99 TJ) - Page 3 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > lolitsdaelan's "I have no idea what I'm doing" build thread ('99 TJ)
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 07-09-2013, 07:47 AM   #31
Imped
Imped's Avatar
No ****?
God knows you needed them......
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 07-09-2013, 11:58 AM   #32
lolitsdaelan
Just got a courtesy call from them, should be here in about 2 weeks!
Your HDR looks bad, and you should feel bad
lolitsdaelan is offline   Reply With Quote Quick reply to this message
Unread 07-10-2013, 08:52 AM   #33
tyvanwie
Nice man. Subbed for more
Also jealous that you're by imped...
tyvanwie is offline   Reply With Quote Quick reply to this message
Unread 07-12-2013, 09:11 AM   #34
lolitsdaelan
Thanks! Hopefully I can continue to deliver some quality content (wallet pending)
Unread 07-12-2013, 09:45 AM   #35
lolitsdaelan
I've started to pit Tire Barn and Discount Tire against each other for the best price on some 33x10.5r15 BFG A/T KOs, but I can't help but hear all these great reviews about Duratracs... Should be another week or two before I'm ready to pull the trigger. Decisions decisions...
Unread 07-12-2013, 02:45 PM   #36
Imped
Imped's Avatar
Honestly, I like AT's better than Duratracs. I've wheeled with guys with both and driven rigs with both. If it was my money, I'd go AT. Just damn good tires for a little bit of everything but not great at anything.
OlllllllO
Float Test Build
IndyORV
Unread 07-12-2013, 02:47 PM   #37
tyvanwie
I have been more than happy with my Duratracs so far.
Unread 07-13-2013, 09:51 AM   #38
lolitsdaelan
Hah, each tire has nothing but good things said about them!
I will likely get the BFG since my preference currently lies in a 10.5 tire vs a 12.5... Seeing as it's really a DD with maybe an off road trip every 2-3 months, I think the thinner tire with slightly less aggressive tread will ultimately serve me better. It's just hard to stick to my guns with so many good looking tires out there!
Unread 07-13-2013, 09:58 AM   #39
lolitsdaelan
Got the CB installed (somewhat) yesterday. It's been sitting in a box in my garage for about a month now, and I figured that if I can at least get it mounted, I'll then feel the pressure to get the antenna hooked up and tuned.
Originally I wanted an overhead setup, but I found that it fit quite nicely right up against my center console on the driver side.
I tried putting the mic right on the side of the CB itself, but found that I would be smacking my leg into while driving. No good.
To the right of the steering wheel was a nice clean section of dashboard that
ended up working quite well. The only issue I found was that if I pull the mic off too aggressively, I smack the wind shield wipers on.
My buddy has an SWR meter, so hopefully I can snag some of his time and get my Firestik tuned up!
Unread 07-13-2013, 10:01 AM   #40
lolitsdaelan
New issue to resolve...
Jeep shakes pretty violently when taking off in first. Seems to be one of two things...
1) Clutch plate is shot
2) Motor mounts are shot
I was originally convinced it was the clutch, however, I came across another thread recently where a guy had the same issue, and the indication to check the mounts was that his shifter would rock side to side, which is exactly what mine does. I'm not sure if I want to go with some real heavy duty mount (BombProof mounts have some highly recommended from a friend, but are a bit pricey), or just put one some OEM mounts on ($12 a piece). Time to do more research!
Edit:
Actually, I bet it's a combination of both. The Jeep does just fine when it's cold, but gets worse as it heats up, which some have indicated that this is a clutch issue. I could imagine that bad motor mounts would only amplify the effect of the slipping clutch...
Unread 07-13-2013, 10:28 AM   #41
tyvanwie
Yeah see I had gotten a really good deal on a set of 15x10 wheels, so BFG couldn't possibly work.
Unread 07-13-2013, 12:04 PM   #42
jeepwrangler97
Edit:
Is it the clutch slipping? or is it clutch chatter. ..look up clutch chatter...which is different than it just straight slipping...
Sent by a messenger bird
jeepwrangler97 is offline   Reply With Quote Quick reply to this message
Unread 07-14-2013, 04:32 PM   #43
lolitsdaelan
I believe it's chatter. It only occurs as I'm engaging in either first or reverse, and once fully engaged, I don't have any issues.
Unread 07-14-2013, 05:30 PM   #44
jeepwrangler97
I'm hardly an expert...but mine does the same thing too. ..but only sometimes.
If you search there are a few different causes ,like the TO bearing, I believe & fluid getting onto the flywheel... along with scorched flywheel. ..
Haha wish I could help more but have just been researching it myself
Unread 07-14-2013, 06:30 PM   #45
Imped
Imped's Avatar
Like I said, I'm willing to give you a hand with a new clutch. That's what I think it is and it's really a pretty easy job.
OlllllllO
Float Test Build
IndyORV
