Lo2aY's Chinook TJ - Page 14 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Lo2aY's Chinook TJ
Unread 06-14-2013, 05:23 AM   #196
Lo2aY
Spider LJ
Lo2aY's Avatar
Two more.. i'm working on the images right now
Chinook has 34" tires in the pics above for scale reference
Instagram: Lo2aYJP
LJ Build thread - Spider
TJ Build thread - Chinook
JK Build thread (soon)
J8 Build thread (soon)
Brute Build thread (soon)
This hobby is not about who can shop the best, it's about creating things that did not exist before. It's about giving a machine a soul and making it an extention of your persona.
There is always someone who can spend more than you can. Don't measure your self worth against others. You can create, you can be fast and you can fail. It's all part of life.
Lo2aY is offline   Reply With Quote Quick reply to this message
Unread 06-17-2013, 03:48 AM   #197
Lo2aY
Spider LJ
Lo2aY's Avatar
Has anyone removed the dash completely? I need to get an AC system in my J8 and am stuck with the aluminum behind the plastic dash.
Instagram: Lo2aYJP
Unread 06-17-2013, 10:36 AM   #198
Barrows
What size rim/tire combo are you running with the 34" tires? I like the look.
Barrows is offline   Reply With Quote Quick reply to this message
Unread 06-17-2013, 10:51 AM   #199
Lo2aY
Spider LJ
Lo2aY's Avatar
305/70/17 maxxis buckshot
Instagram: Lo2aYJP
Unread 09-01-2013, 02:59 AM   #200
Lo2aY
Spider LJ
Lo2aY's Avatar
Anyone install the rear poisonspyder tire carrier?
It's rattles bad. and it will not open or close easy.
Instagram: Lo2aYJP
Unread 09-01-2013, 03:04 AM   #201
Oman Jeep
Originally Posted by Lo2aY View Post
And to think I'm worried about my Brute maybe getting high-centred in the dunes!
Sweet truck, looks good, but wow is it huge!
Oman Jeep is offline   Reply With Quote Quick reply to this message
Unread 09-01-2013, 03:18 AM   #202
Lo2aY
Spider LJ
Lo2aY's Avatar
haha.. yea she's a big truck. eye catching in this side of the world. fun all around
Instagram: Lo2aYJP
Unread 09-01-2013, 10:28 AM   #203
zigsz71
I really like this setup you have on Chinook in this pic. What are the specs? Are those the wheels off of your J8?
/__l ,[____],_
l-----L -OlllllllO-
()_)__()_)--o()_)
'06 LJ Rubi on 35's and stuff
zigsz71 is offline   Reply With Quote Quick reply to this message
Unread 09-02-2013, 05:53 AM   #204
Lo2aY
Spider LJ
Lo2aY's Avatar
Thanks!
those are the magnum wheels. There's a thread here about them. they fit good.
2.5" OME lift and 34" Maxxis tires.
trying to find time to do the regear/lockers/shafts and a belly up
Instagram: Lo2aYJP
Unread 10-03-2013, 04:44 AM   #205
Lo2aY
Spider LJ
Lo2aY's Avatar
Has anyone installed the Currie CURRECTLYNC Tierod system?
http://www.currieenterprises.com/ces...9.aspx?id=1219
Instagram: Lo2aYJP
Unread 10-03-2013, 07:00 AM   #206
janesy86
Thats probably the most common ran steering upgrade I'd think. I gots it on mine.
03' Rubi: 2" BDS, 1.25" BL/MML, Hylined rollin' on 35" MTR's
[URL="http://www.jeepforum.com/forum/f22/janesys-03-rubicon-build-1358239"]Hylined '03 Rubi Build[/URL]
[URL="http://www.wm4x4.com/forums/"]Western MA 4x4[/URL]
janesy86 is offline   Reply With Quote Quick reply to this message
Unread 10-03-2013, 10:35 AM   #207
AdamH07
1981 CJ8
I have the PSC carrier on my LJ Rubi with no issues at all. have you tried adjusting the latch? As far as open / close, I ensured I packed the bearings really well and it's smooth.
'81 CJ8 Scrambler
'82 CJ8 Scrambler
AdamH07 is offline   Reply With Quote Quick reply to this message
Unread 10-03-2013, 10:55 AM   #208
jforse
Yes. Great setup. I had it on my last TJ.
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline   Reply With Quote Quick reply to this message
Unread 10-03-2013, 07:20 PM   #209
platinum5.9
2003 WJ
What's the bolt pattern on the magnum wheels?
03 Grand/WJ-White 4.7HO/QD/242HD Clayton 6" LA,5100,Clayton skid,Custom Rockers,JK OME SS,17"Rock Monsters 33"Interco Irok ND,Muffler delete/MF cats,SOLID D30/BTF D44a,Fawkes,Projectors/HID
platinum5.9 is offline   Reply With Quote Quick reply to this message
Unread 10-03-2013, 07:53 PM   #210
jeepwrangler97
I believe its slightly different, but by mm's from the jk pattern, but close enough to work...but he can chime in
Sent by a messenger bird
jeepwrangler97 is offline   Reply With Quote Quick reply to this message
