LJ Rubicon AKA "The Wombat" - JeepForum.com
post #1 of 7 Old 06-21-2017, 07:25 PM Thread Starter
JeepingNet
Introduction: Owning and maintaining Jeeps has been a long term hobby/lifestyle of mine since I was 16 (1996). My past projects:
1984 CJ
1988 YJ - http://www.jeeping.net/wp-content/up...016/01/8-1.jpg
1998 TJ - http://www.jeeping.net/wp-content/up...2016/01/j2.jpg
2005 TJ Rubicon - http://jeeping.net/wp-content/uploads/2016/01/j7.jpg
2008 JK Rubicon Unlimited - http://jeeping.net/wp-content/uploads/2016/01/j1-1.jpg
2012 WK Overland - http://www.jeeping.net/photo/var/alb...G?m=1498090567
2007 WK Limited - http://www.jeeping.net/photo/var/alb...g?m=1498090818
New project: Iíve wanted an LJ Rubicon since they were announced back in 2003 but the cost of them have always kept me away. But at the end of 2016 I decided it was my goal in 2017 to find one. After a few failed attempts at finding a Jeep (rusted, too damaged, too slow) I was contacted by someone I knew in the Jeep Community who bought a project LJ Rubicon the year before and it has been sitting since then. I asked a price and it sounded reasonable so I pulled the trigger.
Project Goal:
I like building projects in phases (Iím a Project Manager by trade) since it makes sure I focus on the important stuff first and donít just throw on big coils and tires and call it done. (Yes I have a Kanbana board for my jeep build..)
Phase 1 Goals:
Get the Jeep back on the road and onto the trail (Tail type easy to medium)
Slow down the aging process - rust repair
Keep it as low as possible
Keep a budget below 3k
Have it done by September
Long term I want this Jeep on 36 Iroks, lower COG, tough but light and some comforts for overnight trips but I know realistically that isnít happening tomorrow.
Stock:
Jeep LJ Rubicon - 6 Speed. 100% stock nothing has been touched including a ton of maintenance.
Intro to LJ Project: https://youtu.be/x44j1yrQv-Y
Latest Status:
Reserved for updating currently status and photo (coming soon)
Colin Jennings
Trail - 2005 Jeep LJ Rubicon
Daily - 2007 Jeep Grand Cherokee Limited 5.7L
JeepingNet is offline
post #2 of 7 Old 06-21-2017, 07:29 PM
Aardemae
Looks like a good clean slate to start with! I like where your heads at for your end goals. Excited to watch your progress!
Aardemae is offline
post #3 of 7 Old 06-25-2017, 05:14 PM
esad_b
Hi neighbour, small world! Where in NB? Not an LJR, but a 05 LJ.
esad_b is offline
post #4 of 7 Old 06-26-2017, 10:33 AM Thread Starter
JeepingNet
I'm just down in Saint John! Are a member of any of the clubs? I mostly hang out with the Area 62 crew. I used to work on National4wd years and years ago in Freddy.
FYI if you ever see an LJ soft top let me know!
Colin Jennings
post #5 of 7 Old 06-26-2017, 10:39 AM Thread Starter
JeepingNet
We got her running! It took almost 2 months and around 50 hours.
The symptoms:
  • When you turn the key nothing happens, no fuel pump, no spark and no starter
  • 3 different OBD2 readers wouldnít connect
  • Engine Gauge is on
  • SKIS Light is on
  • When I perform the self-diagnostics on the dash I get the following errors: Bus B0 (MIL Light), Bus B1 (SKIS) and Open Dash.
I thought it could be related to the SKIM key but according to the FSM if the SKIM key is bad the starter should still spin. Next thought was bad a PCM but I decided to troubleshoot rather than throwing parts at it.
Problem solving steps
  • All fuses tested correctly
  • Starter is getting power when ignition is turned on so not a bad ignition switch
  • Starter is NOT getting ground from PCM -- Problem
  • Clutch Safety tested ok
  • Starter will crank engine if I jump the relay
  • Battery tested correct and shows correct voltage
  • Fuel pump gets power but no ground from PCM -- Problem
  • PCM is getting power to pin 1 and all grounds looking correct when testing the wiring harness
  • CPS, CKS, TPS are only showing 1-2 volts but sensors themselves test correctly -- Problem
Then it happened I tried jumping the ASD relay and the Jeep magically comes to life. This made no sense at all. CPS, CKS and TPS are now showing 5v. The only thing that makes sense is a bad PCM and somehow jumping the ASD is back-powering a short in the PCM. So I went searching for a PCM which took 3 weeks. However, after installing the new PCM I still had all the same issues.
I went back to basics and started tracing power again. Suddenly I have 11.4 volts at pin 1 on the PCM. I previously had 12.1v and figured the .3 voltage drop couldnít be the problem. Jump the ASD and I have 12.4. Disconnect ASD and Iím back to 11.9 volts. Wiggle the wiring harness with a voltage meter connected and I see the voltage jumping all over the place.
Another hour of tracing wires and I found it... A corroded wire where it looks like someone pierced the wire to test voltage. So 50 hours of work, $300 for a PCM (at least I have a spare now) and all it was a $2 5 minute fix.
Feels great but also frustrated because checking the power at pin 1 was something I did on day 2 and made the stupid mistake of assuming it was ok at 12.1v.
Next steps undoing years of lack of maintenance.
Colin Jennings
post #6 of 7 Old 06-26-2017, 10:56 AM
kvesi122
Good luck on your journey and thank you for saving another LJ!
kvesi122 is offline
post #7 of 7 Old 06-27-2017, 05:52 AM
esad_b
Nah was way back when but not anymore. I'm actually in Moncton, frequent Quispamsis have a buddy down there also a Jeep guy.
Yah if I see anything I'll let ya know, however LJ specific parts are scarce around here. Might have some luck in NS but even then!
esad_b is offline
