Little bit of tinkering aka Tinkertoy - Page 20 - JeepForum.com
post #286 of 3079 Old 10-23-2011, 02:17 PM Thread Starter
aw12345
Originally Posted by Hendrix View Post
Just read that build. So nice.
How is the stak T case doing?
It's the guts of a Dana 300 in a Stack case, once he got the bugs worked out it has been working good. For all the money spend on it he could have bought an Atlas
aw12345 is offline
post #287 of 3079 Old 10-28-2011, 08:20 PM Thread Starter
aw12345
Since it's a battle to figure out where your right front tire hangs out when you try to place it on a rock I tried to do something about it.
Seems to work pretty well
http://www.youtube.com/watch?v=lYUCK...ature=youtu.be
aw12345 is offline
post #288 of 3079 Old 10-28-2011, 09:37 PM
EricsGreen98Tj
Did you put a peice of plexi in the passinger side floor?
Building my junk with more junk, so Im always on the look out for more junk....Free to cheap preferably. :D
My junk http://www.jeepforum.com/forum/f22/survivor-project-driveway-frame-swap-33s-build-1280626/index3.html
EricsGreen98Tj is offline
post #289 of 3079 Old 10-28-2011, 10:41 PM Thread Starter
aw12345
Nope cheapy Chinese backup camera and monitor so I can see the right front tire
aw12345 is offline
post #290 of 3079 Old 10-29-2011, 07:29 PM
EricsGreen98Tj
OH!!! High tech!
post #291 of 3079 Old 10-29-2011, 08:44 PM Thread Starter
aw12345
My wheelin bud just finished his latest round of modifications this week, so of to the mountains we went today to stretch ole Betsy her legs and she how she is doing.
Made for a fun afternoon, nothing to exciting just a nice put about, we are so lucky that the nearest trail is only about 35 mins away. Cannot beat some nice fresh mountain air.
aw12345 is offline
post #292 of 3079 Old 10-29-2011, 10:16 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
what are your spring rates on your coils front and rear?
How come you didn't go with 16s and cut the hood up front?
Thanks.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #293 of 3079 Old 10-29-2011, 11:27 PM Thread Starter
aw12345
14" coilovers are plenty good for rock crawling. 16" would just give a bit more up and down but are a lot harder to stuff in there and not really needed.
Mine is 200 over 200 in front , my buddy has 200 over 250 in front. I run 100 over 150 in the rear. I am pretty sure he runs something similar in the rear
aw12345 is offline
post #294 of 3079 Old 10-30-2011, 12:25 AM
EricsGreen98Tj
So how much "lift" do you think you got over stock? Trying to justify to myself a pair of front coilovers or airshocks, but dont want to raise my Tj much as I want to only run 35's.
post #295 of 3079 Old 10-30-2011, 04:55 AM Thread Starter
aw12345
To me the most important thing was to get around 22-23" belly clearance when going to the Hammers. After some comparing with my yellow Jeep I figured out that the big Jeep has about 4-5" of lift.
aw12345 is offline
post #296 of 3079 Old 10-30-2011, 10:09 PM
JeepRocks86
Thanks, What length are they?
For Sale:
post #297 of 3079 Old 10-31-2011, 07:34 AM Thread Starter
aw12345
Basically what king sells for a 14" coil over, to be truth full I never measured them. The upper collar is 3" down the tube which is what they recommended.
Which gives me the ride height I wanted and the travel I had wanted.
Would be a good idea to weigh the Jeep with the axles under it, but before you start installing the coilover mounts and coil overs. Gives you a pretty good idea what you need for springs. Weigh it with the front wheels on the scale, then the whole Jeep and then the rear wheels only. Divide the weight for the front axle and rear axle in half and that gives you pretty much the weight at each wheel.
The only thing I need to fudge with is the rear coil overs the dampening on the upstroke is to stiff. Same thing with my buddy's Jeep so we will fix that in the next couple of weeks.
aw12345 is offline
post #298 of 3079 Old 10-31-2011, 09:54 AM
JeepRocks86
Thanks, I'm currently searching for a 4 wheel scale to borrow to make it easier.
For Sale:
post #299 of 3079 Old 10-31-2011, 01:10 PM
MO2500
Why do you always have different tires/wheels on this thing Where are the pitbulls?
Instagram: @omsmike
MO2500 is offline
post #300 of 3079 Old 10-31-2011, 03:47 PM
JeepRocks86
I'm guessing the Rockers are the offroad tires. I'm guessing these Krawlers are a drive to the trail tire since he has his flares on and he said it was a 35 minute drive to the mountain trails.
Just a thought.
For Sale:
buggy build , jeep , lots of tinkering , offroading , rock crawling
Project "Tinker Belle" LiftThis Jeep Builds 61 06-08-2011 06:24 PM
Tinkering budget CAI 5.9 MuddSlutt Jeep Builds 4 10-21-2010 03:20 PM
