Little bit of tinkering aka Tinkertoy - Page 174 - JeepForum.com
post #2596 of 3079 Old 06-25-2014, 09:46 PM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Originally Posted by aw12345 View Post
One life to live Nate, make sure you get to do the things you want to do.
Seems you got a pretty good angle on that too buddy
Honesty I don't.... but am working at it. Big changes for me coming in the next couple years.
gst95dsm is offline
post #2597 of 3079 Old 06-25-2014, 09:49 PM Thread Starter
aw12345
Good for you Nate, just do not let work overtake your life. Family and fun first
aw12345 is offline
post #2598 of 3079 Old 06-27-2014, 10:17 PM Thread Starter
aw12345
Did some pondering tonight, to see how well my wonderful idea of mating a TJ powersteering pump to a Nissan V6 would work.
Surprise of all surprises it actually work out pretty well. Need to drill one mounting hole out, swap a pulley, machine a spacer and make the adjusting bracket which looks to be fairly easy and straight forward. Pretty happy about all that.
Now see if I can find a larger fitting for the reservoir and Monday the tinkering will be on. Drilled the fitting on the pump out allready, haven't messed with the pressure relief yet. Will leave that alone for now
picture098 by aartjestaartje, on Flickr
picture097 by aartjestaartje, on Flickr
picture099 by aartjestaartje, on Flickr
aw12345 is offline
post #2599 of 3079 Old 06-28-2014, 06:53 PM Thread Starter
aw12345
Will know Monday night if this pump will cut the mustard, got 3/4"powersteering hose, another 3/4" fitting so fluid going in the pump shouldn't be an issue. Brought my powersteering pulley puller and installer home from work. So Monday is tinker time. Tomorrow is swap tires day and of to the Hammers for some night time tooling around
aw12345 is offline
post #2600 of 3079 Old 06-29-2014, 01:38 PM Thread Starter
aw12345
Pump tensioner bracket is made as well as the spacer. So I hope it found a permanent home on Scrappy.
aw12345 is offline
post #2601 of 3079 Old 06-30-2014, 01:25 PM Thread Starter
aw12345
Joe had asked Fred and me for awhile now to do some crawling to see how his Sammi does.
Well to sum it up quick it does very well. Nicely built buggy. Even though it was quite hot we had a great time at the Hammers.
Met up at 7PM was still over a 100 degrees, fudged with the air shocks some then started off easy. Hit Clawhammer made short work of it, then on to Wrecking ball and Bender Alley. Managed to get crossed up there for a bit, but worked my way out of it.
From there to Jack north, down to the end of sledge from there to Tackhammer and and Chocolate thunder. There Fred wanted me to light up the sky so had to fudge with the wiring of the light bar a little and then lit er up and drove up the rocky hill, sure lit it up nicely. Man I love that bar best 150 bucks I have spend in a long time. Don't want to light it behind somebody though.
The clear night time sky was gorgeous, man the Milkyway looked beautiful, yup we spend a bit of time stargazing.
At 3 AM we decided it was enough fun for the day, was still 90 degrees out. Anyway lets do this again it was a hoot for sure
aw12345 is offline
post #2602 of 3079 Old 07-01-2014, 12:42 PM
vstre
Amazing rigs!
vstre is offline
post #2603 of 3079 Old 07-01-2014, 09:14 PM Thread Starter
aw12345
Originally Posted by vstre View Post
Amazing rigs!
Thanks man
aw12345 is offline
post #2604 of 3079 Old 07-05-2014, 10:00 PM Thread Starter
aw12345
Gave my Tinkertoy some love, added a relay for the light bar. Had it piggy backed on one for the rock lights. Wasn't a very good idea, had either rock lights and blinded everybody or no lights, got even better when a 25 amp fuse couldn't handle the load of both sets of lights. Man that there desert and it's canyons are dark without light. Anyway added a relay , fused it added the wiring for it, relay switches to ground. Wire is fed into the tub, just got to drill a hole and add a switch and hook that up.
aw12345 is offline
post #2605 of 3079 Old 07-06-2014, 03:21 PM Thread Starter
aw12345
Lights are wired, on to my powersteering project. Not in any kinda hurry since I am sorta wandering around in an oven
Also don't want the pump housing to hot while I weld the inlet fitting on
aw12345 is offline
post #2606 of 3079 Old 07-06-2014, 05:28 PM Thread Starter
aw12345
Pump is on the buggy, looks like it belongs there. Came out nice, now on to welding a bigger bung on the reservoir, getting a shorter belt and making a high pressure hose and it's testing time. Ever so curious if it works.
aw12345 is offline
post #2607 of 3079 Old 07-21-2014, 09:09 PM Thread Starter
aw12345
Mighty glad to announce that my steering tinkering paid off. Still needs a cooler plumbed in and make a decent pressure hose instead the hokey thing I rigged together. However most importantly it works like a charm. Not bad for some used parts, some welding and brazing and a 40 dollar pulley.
On to gearing the axles, installing the locker and a ton of other do thats
aw12345 is offline
post #2608 of 3079 Old 07-31-2014, 03:35 PM
bigsnafu
I just gotta say thanks. I just found your videos on youtube and spent the day at work watching them and man I want to go to Johnson Valley so dang bad now!!! Please post more videos.... i'm really behind on paperwork now. Thanks again!
I'm un-decided...
bigsnafu is offline
post #2609 of 3079 Old 07-31-2014, 08:49 PM Thread Starter
aw12345
Your very welcome. Been needing to make some more videos has been awhile
aw12345 is offline
post #2610 of 3079 Old 08-05-2014, 12:29 AM Thread Starter
aw12345
Let my lil un of the leash in the local mountains, wheelin on rocks after a big down pour is fun had a blast slip sliding and mudding on rocks. Best time on John Bull I have had in atleast 6 years
aw12345 is offline
buggy build , jeep , lots of tinkering , offroading , rock crawling
Project "Tinker Belle" LiftThis Jeep Builds 61 06-08-2011 05:24 PM
Tinkering budget CAI 5.9 MuddSlutt Jeep Builds 4 10-21-2010 02:20 PM
