Little bit of tinkering aka Tinkertoy - Page 163 - JeepForum.com
post #2431 of 3079 Old 03-30-2014, 06:56 PM Thread Starter
aw12345
That floor came out real clean. Nice job
Thanks Luciano
aw12345 is offline
post #2432 of 3079 Old 03-30-2014, 11:47 PM Thread Starter
aw12345
Sure looks better with a bit of sheetmetal
Guess it's time for the dreaded list
Regear axles, make front driveshaft.
Plumb ARB compressor and tank.
Weld on grille
Clean all wiring
Finish sheetmetal work on floor use some sheet metal grating to stop gravel spray and still allow to see the front tires.
Make new fuel lines.
Install and wire gauges
Finish welding on cage
Make a rack for cooler and tool bag
Finish exhaust and install muffler.
Install hi volume powersteering pump and make brackets for it
Plumb powersteering cooler
Install trans cooler fan
Install winch
Install rear suckdown winch
Rig some led lights up front
Machine wheelspacers.
Well that just about should get me to a shakedown run
aw12345 is offline
post #2433 of 3079 Old 03-31-2014, 06:36 AM
TJRHD
Hey art, does anyone make a cooler that you could run both your power steering fluid and trans fluid through it?
NOT A HATER
TJRHD is offline
post #2434 of 3079 Old 03-31-2014, 09:36 AM Thread Starter
aw12345
They might, just as easy to stack 2 same sized coolers above each other.
aw12345 is offline
post #2435 of 3079 Old 03-31-2014, 09:41 AM
holdren4100@cyb
PSC MAKES one.
holdren4100@cyb is offline
post #2436 of 3079 Old 03-31-2014, 10:07 AM Thread Starter
aw12345
Originally Posted by holdren4100@cyb View Post
PSC MAKES one.
There you have it Andrew.
Had fun at idtt Curtis?
aw12345 is offline
post #2437 of 3079 Old 03-31-2014, 10:44 AM
holdren4100@cyb
Had a blast with Fred and the guys on Friday at Stoddard Valley. How was JV ?
Fred's new steering is great.
post #2438 of 3079 Old 03-31-2014, 11:30 AM Thread Starter
aw12345
Didn't make it out there, slept in, worked on my buggy, saved some money for my AZ trip.
Somehow getting up at 5 AM didn't sound that appealing.
Fred did a great job on the custom steering, very cleverly done. Proves you don't have to have full hydro with a 111 to 112 wheelbase and no comp cut
aw12345 is offline
post #2439 of 3079 Old 03-31-2014, 01:39 PM
MO2500
Either of you have any pics of how Fred re-did his setup to go back to hydro assist? I remember Art saying he didn't like the full hydro and was working on changing it again.
I know how tough it is trying to stretch the front out there all while keeping a steering box, uptravel, and approach angle in check. So much easier to go full hydro with a trail rig but definitely not desireable on a Jeep driven on the street.
Instagram: @omsmike
MO2500 is offline
post #2440 of 3079 Old 03-31-2014, 02:49 PM
holdren4100@cyb
I will get some pictures for you. The box is mounted inside the frame above the axle. Then a rod goes through the bottom of the grill to a bell crank down under the frame over to the knuckle. So you can put the axle where you want an not worry about linkage.
post #2441 of 3079 Old 04-07-2014, 02:49 PM Thread Starter
aw12345
Did a bit of milling yesterday to avoid more of this happening
Ended up looking like this, needs some machining of the bolt heads for clearance, but looks like I got that figured out, didn't want to cut to deep into the wheel spacers. Bolts gonna end up looking like button heads.
Buddy also gave me some sheetmetal, which led to this
Gonna hit the steel yard in a lil for some angle iron to built some more tabs and frame to mount the sheetmetal on.
aw12345 is offline
post #2442 of 3079 Old 04-17-2014, 10:32 AM Thread Starter
aw12345
Got my crap loaded on the truck and trailer and off to AZ I go.
Table Mesa AZ here I come for a fun filled 5 day sojourn yeahhhh!!!!
On the way I might even do some Jeep wrenching
aw12345 is offline
post #2443 of 3079 Old 04-17-2014, 02:05 PM
AngryTJ
Dam you for always making me jealous!
AngryTJ is offline
post #2444 of 3079 Old 04-17-2014, 05:08 PM
84jeepcj7rock
Got my crap loaded on the truck and trailer and off to AZ I go. Table Mesa AZ here I come for a fun filled 5 day sojourn yeahhhh!!!! On the way I might even do some Jeep wrenching
84jeepcj7rock is offline
post #2445 of 3079 Old 04-17-2014, 10:39 PM
MO2500
Have fun Art! Take some good pics for the rest of us wishing we were with ya
Instagram: @omsmike
MO2500 is offline
buggy build , jeep , lots of tinkering , offroading , rock crawling
Project "Tinker Belle" LiftThis Jeep Builds 61 06-08-2011 05:24 PM
Tinkering budget CAI 5.9 MuddSlutt Jeep Builds 4 10-21-2010 02:20 PM
