Little bit of tinkering aka Tinkertoy - Page 14 - JeepForum.com
post #196 of 3079 Old 09-01-2011, 05:59 AM Thread Starter
aw12345
Originally Posted by Hendrix View Post
Man you really packed that in there. Looks great.
Pretty full and busy under the front
aw12345 is offline
post #197 of 3079 Old 09-01-2011, 09:01 PM
EricsGreen98Tj
How did you cut the splines in the PA?
Building my junk with more junk, so Im always on the look out for more junk....Free to cheap preferably. :D
My junk http://www.jeepforum.com/forum/f22/survivor-project-driveway-frame-swap-33s-build-1280626/index3.html
EricsGreen98Tj is offline
post #198 of 3079 Old 09-02-2011, 06:21 AM Thread Starter
aw12345
Cut an old drop pitman arm and turned it nice and round on the lathe.
Mounted it on a piece of sector shaft
The round piece in my hand is the splined part
aw12345 is offline
post #199 of 3079 Old 09-03-2011, 10:50 AM
EricsGreen98Tj
Oh cool!
post #200 of 3079 Old 09-04-2011, 09:16 PM Thread Starter
aw12345
Tight business
Can I say it's pretty darn tight under there?
Progress is slow, since the plasma cutter needs new consumables. My torches are at a friend's house and he is on vacation in Utah.
So everything gets cut and shaped with a angle grinder.
On the bright side, even though stuff is very tight under there, it works!!
Tomorrow it's time to make a mount for the drag link on the steering arm and some bracket for the steering ram. Getting that in there and the hoses run is going to be an adventure also. Then flex flex and flex if after that everything is to my liking it's time to burn everything together
aw12345 is offline
post #201 of 3079 Old 09-06-2011, 06:46 PM Thread Starter
aw12345
I sure opened a Pandora's box with this one, however a couple of tubes of KY jelly later I am getting close to slamming the lid back on that darn box
Need to make a top plate for the passenger steering arm and then on to making a assist ram mount and skid plate.
Mounting the ram and routing the hoses is going to be fun also
aw12345 is offline
post #202 of 3079 Old 09-06-2011, 07:04 PM
mallard15
I have been completely oblivious to the fact you aren't running full hydro... Any reason why other than you may drive it on the road some (if you do like to)?
Bestop Extendatrunk for sale (150$) PM me
Yukon 4.10 R&P Gears Set (300$) PM me
mallard15 is offline
post #203 of 3079 Old 09-06-2011, 08:31 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
You really stuffed all that in a small space. Good luck. Looks like you about have it.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #204 of 3079 Old 09-06-2011, 09:25 PM
EricsGreen98Tj
Man you have WAY WAY more patience than i could ever hope to have. And better fab skills too. +12
post #205 of 3079 Old 09-06-2011, 09:57 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
Hey, I have a few questions for you. I'm toying with either pit bulls or Iroks. I really like the pit bulls, but they are so wide in the 39.5s
How do you like your pitbulls?
What size are they again?
What size wheels are you running? Backspacing?
What is your overall width of the jeep?
Thanks
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #206 of 3079 Old 09-07-2011, 06:08 AM Thread Starter
aw12345
Among other things money, double ended ram plus mount and orbital valve is not cheap. Also I have driven and operated heavy equipment with full hydro steering and do not care for how that equipment steers.
aw12345 is offline
post #207 of 3079 Old 09-07-2011, 06:11 AM Thread Starter
aw12345
Thanks
39.5 x 16.5 wide, 12" wide rims 4.75" back spacing
It's wide but pretty darn stable, If I am not mistaken it's 87" from outside tire to outside tire
aw12345 is offline
post #208 of 3079 Old 09-07-2011, 08:40 AM
JeepRocks86
Thanks I appreciate it. I picked up a set of H2 wheels a while back to use, and I'm not sure how well they would work with the wide Rockers. I've seen them mounted, but I think they would rub pretty badly
As for the overall width, I'm trying to plan for trailer modifications, Drive over Fenders, etc.
For Sale:
post #209 of 3079 Old 09-07-2011, 04:27 PM Thread Starter
aw12345
made the fenders on my trailer removable, works well and is a lot lighter than drive over fenders. Pull 4 pins and pull the fenders off
aw12345 is offline
post #210 of 3079 Old 09-07-2011, 05:54 PM Thread Starter
aw12345
To darn hot to do much of anything today, still kinda positioned the steering ram where it roughly needs to go. Looks like rotating it and pointing the fittings to the back will be my best bet. Going to make a skid/ integrated mount for the ram. Ordered some new electrodes for the plasma cutter so this weekend might turn into a cut fest lol. Snapon sure is proud of their stuff though.
aw12345 is offline
buggy build , jeep , lots of tinkering , offroading , rock crawling
Project "Tinker Belle" LiftThis Jeep Builds 61 06-08-2011 05:24 PM
Tinkering budget CAI 5.9 MuddSlutt Jeep Builds 4 10-21-2010 02:20 PM
