Little bit of tinkering aka Tinkertoy - Page 139 - JeepForum.com
post #2071 of 3079 Old 11-10-2013, 03:05 PM Thread Starter
aw12345
He Nate' after this years Hammers fun, want to try this trail next year?
Since White lightning won't be so pretty anymore, might as well have some more fun!
Speaks for it self I love it
aw12345 is offline
post #2072 of 3079 Old 11-10-2013, 03:36 PM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Originally Posted by aw12345
He Nate' after this years Hammers fun, want to try this trail next year? Since White lightning won't be so pretty anymore, might as well have some more fun! Speaks for it self I love it Video Link: http://www.youtube.com/watch?v=KEKV2N8A0bo
Oh lord I'll need another rig if I hang out with you to much.
gst95dsm is offline
post #2073 of 3079 Old 11-10-2013, 03:42 PM Thread Starter
aw12345
Not really, once the Hammers addiction has it's sharp claws in you, your Whitelightning will morph somewhat. Will make buffing it out somewhat of a waste of time
aw12345 is offline
post #2074 of 3079 Old 11-10-2013, 06:10 PM
tyvanwie
That's insane.
tyvanwie is offline
post #2075 of 3079 Old 11-10-2013, 08:05 PM Thread Starter
aw12345
Originally Posted by tyvanwie View Post
That's insane.
Lil bit of insanity is a good thing
aw12345 is offline
post #2076 of 3079 Old 11-10-2013, 08:44 PM
tyvanwie
Always. Looks fun as hell.
tyvanwie is offline
post #2077 of 3079 Old 11-10-2013, 10:18 PM Thread Starter
aw12345
Big boy Jeepin, in our local desert
aw12345 is offline
post #2078 of 3079 Old 11-11-2013, 07:54 PM Thread Starter
aw12345
Did a bit more welding on the front axle of my buggy, almost done with that part, then on to extending the steering arms a bit.
Will be nice when the front end is all done. Then comes the part where I have to spend money on gears, a detroit for the front and a powersteering pump. On the bright side that will be the major remaining expenditure. The rest is just a bunch of nickle and dime stuff.
Seeing some of the Hammer buggy trails is getting me motivated to get this thing wheelable
aw12345 is offline
post #2079 of 3079 Old 11-11-2013, 07:56 PM
gst95dsm
gst95dsm's Avatar
So is it already turn key as far as powertrain is concerned? Was this a running buggy when you got it and you are just "fixing" it to your liking?
gst95dsm is offline
post #2080 of 3079 Old 11-11-2013, 08:29 PM
JJeeper09
Any pics?
JJeeper09 is offline
post #2081 of 3079 Old 11-11-2013, 08:42 PM Thread Starter
aw12345
Nah didn't run, I got it running after fixing all the engine wiring, still got to find a trans computer and wire that. Damned engine dropped a valve, fixed that awhile back. There is a lot of lil stuff I still got to fix. So there is some tinkering left to be done
aw12345 is offline
post #2082 of 3079 Old 11-11-2013, 08:44 PM Thread Starter
aw12345
Originally Posted by JJeeper09 View Post
Any pics?
Will take some more, when I am a little further ahead.
aw12345 is offline
post #2083 of 3079 Old 11-13-2013, 08:24 PM Thread Starter
aw12345
If somebody is looking for a more extreme Jeep this might be a good deal, price is negotiable
110" wheelbase, D60 Kpin axle XJ springs front and rear 14 bolt rear 40" MTR's
SoCal4X;229795]90 YJ 4.0 FI 110k miles on motor from an XJ
5 speed ax-15 trans, 231 Slip yoke eliminator
AXLES built by RWK Haus in Yorba Linda
-Front axle 86 F350 D60 king pin with all new parts, 1330 yoke Spartan locker, Yukon 35 spline outer chromoly stubs, stock inners, and Yukon drive flanges, Spicer ujoints, 5.38's. Spare calipers and rotors for the D.60, Solid diff cover. Built by shop 0 miles since rebuild.
-Rear axle 14 bolt 1350 yoke with all new parts, disc brake conversion with Ruffstuff brackets, 5.38s, grizzly locker, Ruffstuff pinion guard. Solid diff cover. Built by shop 0 miles since rebuild.
-SOA suspension on XJ military wrapped springs, boomerang shackles, 108" wheelbase, both axles have Ruffstuff axle swap kits. 1" body lift, 1" motor lift. Solid diff covers. Hi steer arms, with Ruffstuff cross over kit .25" dom tubing and 1-ton tie rod ends. Frame rail sits at 26" from ground.
-Steering box is tapped for hydro assist setup. I have hoses but no ram.
-X9 superwinch not mounted.
-40" Goodyear MTR kevlars mounted on H2 aluminum wheels.
-Almost all hardware has been replaced with grade 8 bolts on axles and suspension.
-Shock towers and Rancho 5000 shocks installed.
-Rear genright comp corners LED round lights.
-Homemade sliders
-Front and rear bumpers 1/4" wall 2x4 square tubing.
-Crossmember sits 1/2" below frame rails. I don't have skid plate.
-One ton master cylinder.
-Bestop seats.
-dom tube bull nose mounted on front bumper.
-New RCI 2161 fuel cell mounted in the bed
-New drivelines F&R (Tatton) .120 wall DOM spicer parts
-Front cage has been added on but not tied to frame, just has plates on the floor.
-New .120" DOM driveshafts professionally built and balanced. All spicer parts. (Tatton drive lines)
Things needed to be done to wheel, I have most of the stuff just needs installation and time which I don't have with 5 kids.
-Front tube fenders need to be assembled and mounted. (White Rhino Fab kit) I got it
-Add ram for assist steering if desired. Box is already tapped.
-I have rear cage DOM tubes bent up that need to be installed onto cage and tie into frame. (White Rhino Fab kit) I got it
-Genright tire carrier style swing down needs to be welded up and mounted. Local fab shop bent it up.
-Anti wrap bar kit needs to be installed which I have (Ruff Stuff) I got it
-Skid plate, I was planning to stick 1/4" plate under it. I don't have
-Add bumpstops
Its been always garaged since I have owned it and previous owner from this board. Probably more stuff but will update if missing something.
CA title registered non op.
Would like trade for more of a streetable wheeler or muscle car (Charger). We can negotiate price differences either way. I prefer a Moderate built TJ, but will entertain a good looking XJ, ZJ or shoot what you got, Jeeps, yotas locked and running. Something that I can wheel and drive to a local trail for the day. I want something to pull behind the MoHo and run local trails. Reason I am getting rid of this rig is I haven't touched it in over a year. With 5 kids and sports and school, it just seems like I have no time and crazier by the day. So there for I think someone with some time to button things up can enjoy this rig more than me having it sit in my garage. I was originally building this to play in JV, but maybe someone else can still hit the Hammers with it.
Let me know what you got. Shoot! Prefer to trade straight up but we can negotiate if needed. Location 92532. So let's say $8,500. Feel free to text or email. 9five1 83zero- 22four2. Embroideryneeds at gmail dot com. Pics following.
Come on by and take a look!
Originally Posted by SoCal4X View Post
Here's what I had on my phone. If you want any specific pics let me know.
Older pic while setting up shock mounts with the help of the Famous Art from here. Swampers are gone, currently sitting on the MTRs.
aw12345 is offline
post #2084 of 3079 Old 11-13-2013, 10:06 PM
JeepSpeed18
That toyota is awesome! I wouldn't think those tires would get good traction.
_=====ooooo
//__l_l_,\____\,_____
l_/-\_l__l_/-\_|lllllll|
_\_/==== |; _\\ \\_|;
_(o)_)___(o)_)--o-)_)
96 Jeep Cherokee 4" lift with 32" KM2's
94 Jeep Cherokee 3" lift with 29's!
JEEP Just Empty Every Pocket my life moto. :)
White Jeep Club Member #109
But yeah my 4.0 has been hydrolocked twice, ran upside down for 7 seconds it still keeps coming back for more. its like that crazy ex-girlfriend that just wont quit..but unlike her, its a good thing haha
JeepSpeed18 is offline
post #2085 of 3079 Old 11-13-2013, 10:18 PM Thread Starter
aw12345
It's a Toyota body on a International scout frame, with a 4.3 Chevy mid engine in the bed and Rockwell axles and rear steer. It's different for sure, but actually works pretty wel. He is planning on tweeking it a bit more and using smaller tires
aw12345 is offline
buggy build , jeep , lots of tinkering , offroading , rock crawling
Project "Tinker Belle" LiftThis Jeep Builds 61 06-08-2011 06:24 PM
Tinkering budget CAI 5.9 MuddSlutt Jeep Builds 4 10-21-2010 03:20 PM
