Little bit of tinkering aka Tinkertoy - Page 13 - JeepForum.com
post #181 of 3079 Old 08-22-2011, 07:49 PM Thread Starter
aw12345
Cut up a pitman arm last night, tacked it together today and it looks like I am getting a heck of a lot closer to a working high steer
aw12345 is offline
post #182 of 3079 Old 08-22-2011, 09:12 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
I have been thinking about flattening mine out. Got any Ideas how? I know to use a press. But what about cooling it after heating with a torch?
K.C.C.O.
Carpe Diem
Hendrix is offline
post #183 of 3079 Old 08-22-2011, 10:23 PM
IEcrawlerTJ01
Heat with a torch and use the press
Do not!! Do not ever cool it after heating. It is cast and will become very brittle and snap without warning. Just let it cool on it's own and it will be good to go
I just recently helped do this exact thing on a rig. Flatten out the pitman arm for more up travel with out hitting the tie rod
SAVVY,CURRIE,GOODYEAR
Nuff said...
IEcrawlerTJ01 is offline
post #184 of 3079 Old 08-23-2011, 07:24 AM Thread Starter
aw12345
Going to make a pitman arm out of 3/4 flatbar
This is my mockup, I had a bend and twisted pitman arm already. You could try a cj7 one which is flat
Anyway this one I tacked together to check for clearance, it solves pretty much my clearance problems. Will flex and check every7thing today and then built all the final parts
aw12345 is offline
post #185 of 3079 Old 08-23-2011, 07:27 AM Thread Starter
aw12345
heat and air cool or stick it in kitty litter or dry sand to let it cool slowly to keep it from crystalizing
aw12345 is offline
post #186 of 3079 Old 08-23-2011, 05:34 PM Thread Starter
aw12345
Well it looks like I am pretty darn close to fitting 10 pounds of crap in a 2 pound can. Going to get some steel tomorrow and built me a sweet pitman arm
aw12345 is offline
post #187 of 3079 Old 08-23-2011, 09:47 PM
Dirt22
dayom, that's up there! Nice work buddy.
LCG TJ Build ---
DD XJ Build ---
Dirt22 is offline
post #188 of 3079 Old 08-24-2011, 07:20 AM Thread Starter
aw12345
Yup getting tired of those darn rocks jumping up and bending my tierod.
Hammer season is coming up and I want to wheel not wrench
aw12345 is offline
post #189 of 3079 Old 08-24-2011, 10:51 AM
oldtime_ironman
Um, no. The pitman arm is forged hi-carbon steel if you look closely at it. Notice how wide the "seam" is along the sides of it. Either way, its a bad idea in my book to mod any pitman arm. Safety issues.
oldtime_ironman is offline
post #190 of 3079 Old 08-24-2011, 04:32 PM Thread Starter
aw12345
It's a trail Jeep, I take a good custom pitman arm over a drop down one any day seen those break. Had to weld one of those a few months ago, so my friends could get of the trail and back to Vegas
aw12345 is offline
post #191 of 3079 Old 08-25-2011, 07:30 PM Thread Starter
aw12345
Did some more chipping away at my pitman arm project, finished turning the splined hub, and cut the blank for the arm out of a big hunk of 1" steel plate. Once I clean that up some more I'll bore a hole through the plate, that is about 14 degrees of center to give it the twist I want. Going to do that by cutting a piece of pipe at an angle and then tacking it to the back of the blank so I can bore it on my little lathe.
aw12345 is offline
post #192 of 3079 Old 08-25-2011, 09:39 PM
EricsGreen98Tj
^^Thats a heck of an idea!
Building my junk with more junk, so Im always on the look out for more junk....Free to cheap preferably. :D
My junk http://www.jeepforum.com/forum/f22/survivor-project-driveway-frame-swap-33s-build-1280626/index3.html
EricsGreen98Tj is offline
post #193 of 3079 Old 08-26-2011, 07:32 PM Thread Starter
aw12345
Still chipping away
aw12345 is offline
post #194 of 3079 Old 08-31-2011, 07:10 PM Thread Starter
aw12345
The good, the bad and the happy
Got a working pitman arm made , that's good, the draglink and track bar line up pretty darn close to perfect, happy about that. The tierod needs to come down about 1/2" to 3/4", kinda bad, but still close to 2" higher then before I took the front end apart. The happy, it'll work, getting some steel tomorrow and have a long weekend coming up so hope to get close to being finished with it.
A 6-7" front end stretch with less than 5" lift and 14" coilovers with 6" uptravel, makes packaging the whole shebang a pretty hard chore
aw12345 is offline
post #195 of 3079 Old 08-31-2011, 09:19 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
Man you really packed that in there. Looks great.
K.C.C.O.
Carpe Diem
Hendrix is offline
buggy build , jeep , lots of tinkering , offroading , rock crawling
Project "Tinker Belle" LiftThis Jeep Builds 61 06-08-2011 06:24 PM
Tinkering budget CAI 5.9 MuddSlutt Jeep Builds 4 10-21-2010 03:20 PM
