Little bit of tinkering aka Tinkertoy - Page 12 - JeepForum.com
post #166 of 3079 Old 08-05-2011, 07:17 AM
Dirt22
Very cool!
Did you router the edges?
LCG TJ Build ---
DD XJ Build ---
Dirt22 is offline
post #167 of 3079 Old 08-05-2011, 08:12 AM Thread Starter
aw12345
Nope, die grinder with a carbide bit for aluminum, it chews through it in a heartbeat
aw12345 is offline
post #168 of 3079 Old 08-07-2011, 01:22 PM Thread Starter
aw12345
Spend last night and part of the morning on the trail had a great time with a few friends. We met this fella and some bees later on to add to the entertainment
aw12345 is offline
post #169 of 3079 Old 08-13-2011, 09:32 PM Thread Starter
aw12345
I was getting tired of straightening the tierod after a few runs so the Jeep went on blocks and the torch i9s coming out to resolve this situation. Notched the frame and the draglink sits on top of the steer arm. Now the radiator needs to move back a bit. Going to double sheer the drag link mount on the steer arm.
Raise the tierod close to 3 " make new steering ram brackets on the axle new spacers for the tierod. Move the trackbar around a bit, maybe built some kind of truss for the front axle . Will be a busy boy for awhile.
aw12345 is offline
post #170 of 3079 Old 08-14-2011, 09:51 PM Thread Starter
aw12345
When you cut a frame like this make sure you turn the steering left and right, after I welded the insert in the frame I found that turning to the right would hit the frame sleeve, so some judicious grinding fixed that. Well first part is fixed. On to messing with the pitman arm and raising the tierod up
aw12345 is offline
post #171 of 3079 Old 08-15-2011, 05:56 PM Thread Starter
aw12345
This is where the tierod is going to go, will make Bulldozing without to many ill effects an easier task to acomplish
aw12345 is offline
post #172 of 3079 Old 08-15-2011, 09:17 PM
mallard15
Looks great man.
Bestop Extendatrunk for sale (150$) PM me
Yukon 4.10 R&P Gears Set (300$) PM me
mallard15 is offline
post #173 of 3079 Old 08-17-2011, 06:33 PM Thread Starter
aw12345
Ordered some flathead bolts yesterday and did some more mocking up. Also found oud I need a bigger countersink drill bit, with some luck that will be here tomorrow. Once I finish that and drill the new spacers for the tierod I can start flexing it and see what I need to do with the trackbar and ram mount.
aw12345 is offline
post #174 of 3079 Old 08-20-2011, 10:59 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
It'll never work!
You need to start all over again, but this time, buy a bunch of off the shelf prefabbed aftermarket stuff (like I mostly did).
GREAT job Art.
Joe Dillard is offline
post #175 of 3079 Old 08-20-2011, 03:32 PM Thread Starter
aw12345
It'll never work!
GREAT job Art.
It works Joe, got the spacers machined yesterday, will have to countersink my plates some more and the tierod part will be done today
aw12345 is offline
post #176 of 3079 Old 08-20-2011, 06:29 PM
Joe Dillard
Very cool. I hope you know I was just kiddin' with you earlier. Awesome build!
post #177 of 3079 Old 08-20-2011, 08:32 PM Thread Starter
aw12345
I know Joe
aw12345 is offline
post #178 of 3079 Old 08-20-2011, 09:23 PM
EricsGreen98Tj
Man will you please fix the crooked "tune up" sign on the rear wall of your garage?
Building my junk with more junk, so Im always on the look out for more junk....Free to cheap preferably. :D
My junk http://www.jeepforum.com/forum/f22/survivor-project-driveway-frame-swap-33s-build-1280626/index3.html
EricsGreen98Tj is offline
post #179 of 3079 Old 08-20-2011, 11:12 PM Thread Starter
aw12345
When I have some time in between fixing my Jeeps, fixing the house and going to work. darn there need to be several more days in the week
Anyway made some progress today, the tierod mod is done, still have to straighten it
aw12345 is offline
post #180 of 3079 Old 08-21-2011, 09:41 PM Thread Starter
aw12345
Hot doggy, it takes a big shoehorn to get all this stuff in there where want it.
Got the trackbar bend up and made some dummy mounts. So I could check for clearance, need to notch the frame a bit to clear the trackbar at full stuff and then recheck and if that works I can weld some proper mounts together.
My next step is to make a dummy pitman arm, the draglink and the tierod get into a fight the way I have stuff now. Making the high steer work with about 4.5" lift and maintaining close to 6" of up travel is a serious pain in the neck.
Wifey gave me 2 weeks to get it done before she bugs me again with home remodeling so I will be a busy beaver for awhile.
aw12345 is offline
buggy build , jeep , lots of tinkering , offroading , rock crawling
Project "Tinker Belle" LiftThis Jeep Builds 61 06-08-2011 05:24 PM
Tinkering budget CAI 5.9 MuddSlutt Jeep Builds 4 10-21-2010 02:20 PM
